Old Nov 24, 2012, 02:56 PM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Originally Posted by TexasAggie View Post
I've been trying to decide between two motors for my Skywalker build. I'm going to run on 4S, so I'm shooting for about 1000kv. The two I've found are:
Firepower 30 (http://www.headsuprc.com/servlet/the...h-10%29/Detail)
Power Up 15 (http://www.headsuprc.com/servlet/the...5-Sport/Detail)
The first makes about 60 oz of thrust at about 28 A with 9x6 or 9x4.5.
The second makes a bit less: 56oz @ 32A. This motor also weighs nearly an ounce less.
The data seems to indicate that the first is more efficient, at least at full throttle. Though, it weighs more so any gain will likely be burned with the extra induced drag. Anyone have any thoughts?
The second motor is 42mm in diameter. I have a hunch this is too big for the motor mount. Can someone confirm this?
TexasAggie is offline Find More Posts by TexasAggie
Old Nov 24, 2012, 03:52 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Since you're just putting together a new setup. Try to get a motor that will swing a 10x6 prop and pull 30A WOT. I'm guessing a motor in the 800-900KV on 4s will do that. That'll be the most efficient setup.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 24, 2012, 04:26 PM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Sorry to hear about your bird man. My skywalker did the same thing.
Originally Posted by Efti View Post
I have the failsafe on about 60% throttle, but the RTH did not engage all the time. I pulled up all I could, but nothing happened. Also put the throttle down. It is so strange.
Full throttle is somewere about 40Amps
Anyway the plane can't be fixed.
After 120KM/H it look like this....
williamjames is offline Find More Posts by williamjames
Old Nov 24, 2012, 06:08 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Man, that's a bummer. Hope you can rebuild! I would suggest setting the FS for 0 throttle. Can be dangerous to someone on the ground otherwise..
Old Nov 24, 2012, 07:41 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
The reason being that a 6" pitch is ideal and a 10" spinning more slowly than a 9" will be more efficient for the same amount of thrust? Problem is, I don't see any electric 10x6 props. I'd rather sacrifice a bit of efficiency to have readily available parts.
Old Nov 24, 2012, 09:00 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I run an APC folding 10x6, meant for electrics.
ian
Daemon is offline Find More Posts by Daemon
Old Nov 24, 2012, 09:27 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
ian
I know; I've been reading. That's just another thing that I'd rather not mess with, though.
Old Nov 25, 2012, 07:56 AM
mich75 is offline
Find More Posts by mich75
Joined Dec 2010
What kinda deflection do you guys have on the ailerons?
Standard horns on the CS929MG seem a little short, I can only get 15mm down & 30mm up before things bind and I would like to use flaperons...
mich75 is offline Find More Posts by mich75
Old Nov 25, 2012, 09:09 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Found one
http://www.hobby-lobby.com/10x6_apc_...ueryId=4041446
And yes, the 6" pitch flies the plane at roughly the right speed 25-35mph, and the slower the prop spins the more efficient it is. Quieter too.
Old Nov 25, 2012, 09:43 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Found one
Wow. I had no idea that existed. Nice find!
Old Nov 25, 2012, 02:05 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
http://innov8tivedesigns.com/Scorpio...90%20Specs.htm
Interesting that in this case, the 10x6 is less efficient in terms of thrust / power than the 9x6.
According to the data, the 10x5 looks like a good choice for this motor. However, WebOCalc argues that the 10x6 is a slightly better fit. Nothing is cut and dry...
Old Nov 25, 2012, 02:39 PM
mich75 is offline
Joined Dec 2010
Old Nov 25, 2012, 06:12 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
That is more than enough. I have about 10mm down and 17 up and can easily do rolls with aileron only. I use flaps as flaps because my OSD won't let me have two aileron channels or flaperons.
subsonic is online now Find More Posts by subsonic
Old Nov 25, 2012, 06:22 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Ah but see the thing is that you would want to keep the amps roughly the same for both props. The 9x6 is drawing 24 amps, 10x6 is pulling 33. So just ball parking, you'd want a motor with 1000kv for a 9x6 prop vs. a 800kv for a 10x6. Its not necessarily more thrust, but its done more efficiently.
Old Nov 26, 2012, 03:54 PM
VizBizTas is offline
Find More Posts by VizBizTas
Joined Sep 2012
Right - bought this yesterday. Going to run 2 x 5800 4s with D3542 -1000k. Using a Aeronaut 9x7 folding prop
1 x 38mm centerpiece.
VizBizTas is offline Find More Posts by VizBizTas
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
