Look up how to set the failsafe for your DL system, and do it again with the throttle at zero position.
Latest blog entry: My 2012 FPV year in Review
I tried banking to regain video, however after a few seconds, I gave up and switched off my TX to activate RTH on the RVOSD5, but she never made it back... It was very windy today, and I was having a hard enough time flying her manually... I know roughly where the plane was when I lost video, but since it had RTH, I have no idea where the plane managed to fly itself before it finally crashed... I'm going to print a bunch of REWARD fliers promising a cash reward tomorrow, and leave them on all the mailboxes in the vicinity of where it went missing. Its mostly just farmland, so hopefully someone will find it on their farm, and see one of my fliers... I'm pretty bummed, considering I spent over a year building this Skywalker, but at this point, I'll just settle for getting the wreckage back so I can recycle the electronics...
the CG and much of it on a long lever arm. It doesn't need to be all that heavy to make it hopelessly tail heavy. The SW is not tail heavy. It can be built that way though. The laminating film is likely the largest contributor, particularly on the tail vertical. Quote:
The bad news is, you're still going to have to do something else to get there, and you're going to have to decide for yourself what that is. ian |
Yeah... looks like that. Film is still a good thing I believe (tailboom becomes far, far, far more rigid when laminated!) but next time I will probably look for thinner film if there is any.
Well, having to go 3 cm ahead is not as bad as having to go 6, but really few things come to my mind besides pumping helium into the tail cavity. I will surely get some solution but it is a lesson to learn. One more question Ian, you say 3 cm behind is OK, some say servo line and not a micron farther to the back - what is that 3 cm limit about? Is it a more or less typical line for CG or it is a ultimate dead limit that can only be accepted when no other hope is left? Thank you. |
Some say they still use that factory recommended CG and it works for them, but those who prefer not to fly an inefficient nose heavy pig, and take the time to work the CG back until the plane flies well, usually find that somewhere around 30mm behind the servo wires works quite well. Some of us even fly behind that, but 30mm will work ok for most anyone who also dials in some down elevator trim and they may also need to reduce elevator rates a bit (becomes more sensitive as CG moves back). Fact is *a lot* of people fly with the CG there, so it's certainly a goal to shoot for if you're coming from behind that. ian |
Joined Jun 2011
"Why bother?" -- Read what I wrote in that paragraph. The paragraph is actually more helpful than you know. It discusses relevant issues that you may encounter if you continue your build the way your proposing.
Regardless though, this is exactly why some people become hesitant to help others... the lack of appreciation. You know.... maybe you should ignore my whole post from earlier all together and continue the build the way you had suggested. Maybe after you've built the plane.... you'll have a better understanding of why I "bothered". |
Latest blog entry: Mystery summit FPV adventures
| Thread Tools | |
| Question Best plane for FPV while on vacation? | patricklupo | Video Piloting (FPV/RPV) | 23 | Aug 08, 2010 06:27 AM |
| Cool FPV plane rescue with an FPV truck :-) | AnthonyRC | Video Piloting (FPV/RPV) | 17 | Feb 24, 2008 10:45 PM |
| For Sale Skywalker plane and a bunch of extras | moody07747 | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 19, 2006 09:34 PM |
| Discussion Aviator Skywalker RC plane given to me | moody07747 | Electric Plane Talk | 46 | Sep 12, 2006 11:45 AM |
