Old Nov 12, 2012, 03:07 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
More dense foam obviously doesn't help when the single joiner is the weakest link.
Daemon is offline Find More Posts by Daemon
Old Nov 12, 2012, 04:00 PM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Originally Posted by raRaRa View Post
V5 and V6 have the same wing, no difference afaik. Go for the V6 or wait for the "new" Skywalker.
Wow! When is this one coming out and where can I buy one?
williamjames is offline Find More Posts by williamjames
Old Nov 12, 2012, 08:23 PM
mmbbb is offline
Find More Posts by mmbbb
Australia, TAS, Hobart
Joined Jun 2012
The tail is already weak in the current and past Skywalkers. Why make it even weaker?
mmbbb is offline Find More Posts by mmbbb
Old Nov 12, 2012, 09:10 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
depends on how well that CF boom is secured. The CF wouldnt twist or bend. But the lack of continuity in the body would increase drag a little, and I could see the tail portion catching things on landing instead of the whole plane just sliding over
ashdec87 is offline Find More Posts by ashdec87
Old Nov 12, 2012, 09:15 PM
mmbbb is offline
Joined Jun 2012
Remind you, the current version also has CF boom but you all know how weak it is. If people want discontinued tail plane, there is already one (Hobbyking EPP FPV). Please, please don't make skywalker this way.
Old Nov 12, 2012, 09:22 PM
Joined Jun 2011
Is it really that bad? I don't know much about the pros and cons about having just a CF rod instead of a boom.
Old Nov 12, 2012, 09:47 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I know and the problem is that the foam around the boom flexes. The CF itself cant flex without breaking.
Old Nov 12, 2012, 10:09 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
This is my first flight after moving to Michigan. I was having issues with my HD camera, but the FPV footage came out well. I finally have something other than flat farm fields to fly over!
First flight in Michigan (3 min 32 sec)
Old Nov 13, 2012, 12:43 AM
heinduplessis is online now
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
I think they're actually trying to fix the problem - that CF boom looks much thicker than the current one, so I agree with ashdec87 (Thanks for the flight vid btw), if it's nice and secure, it should be very stiff.
heinduplessis is online now Find More Posts by heinduplessis
Old Nov 13, 2012, 12:24 PM
carguy1994ca is online now
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
The low tail wing could also be a problem on landing and catch in weeds, rocks and other foam rippin' things
carguy1994ca is online now Find More Posts by carguy1994ca
Old Nov 13, 2012, 02:39 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Hey guys. How did u go about attaching the horizontal stabilizer to the vertical stabalizer? I think my kit is missing hardware.
blueprint is offline Find More Posts by blueprint
Old Nov 13, 2012, 03:10 PM
raRaRa is offline
Find More Posts by raRaRa
Joined Nov 2010
You get two small wooden plates and 2 screws. When you glue the plane together you should insert the wooden plate inside the vertical stabilizer and the other one on top of the horizontal stabilizer. Then you put the 2 screws in to secure it together.
Screenshot of it assembled:
[IMG]http://api.ning.com/files/z7f*7oRHFFUp5GgHZdtnUl6WnnQd3m8vAbuaoPSBunsSCuIQpt 2S2xoLWisfAqP1OAZw0LxlW8mO4OfBLxmsyyg2vRYtgdT5/2.png[/IMG]
raRaRa is offline Find More Posts by raRaRa
Old Nov 13, 2012, 04:16 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Originally Posted by Daemon View Post
Not all generations of Skywalker have the same wings.
And people *have* folded them in the air running them without reinforcements. I know
two personally.
ian
Version 5 or 6 wings?
Those are the ones I am talking about, not the early ones.
Shadrack is offline Find More Posts by Shadrack
Old Nov 13, 2012, 04:19 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Originally Posted by heinduplessis View Post
Were those pre V4? Or not on rubber bands? Must have been carrying very heavy loads!
I've pulled so many G's on my V4 it tore the fuse horizontally, wings in tact. I've been through 4 serious crashes and all that remain are the wings!
Same.
Mine have been through hell, a motor coming off, and 100 yards or so down, and I pulled up at the end to try lesson the damage, and the worst has been that the root of the entry holes for the CF tube were a little loose. I wrapped one layer of good fiber tape around the middle of the CF tube and it is snug on both again.
I use rubber bands, ones from a SIG plane, that work very well.
Old Nov 13, 2012, 06:00 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Couple folks have snapped the v5 single joiner in the air.
ian
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
