Old Oct 17, 2012, 10:22 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It's the stock antenna on Hitec 2.4Ghz receivers.
It does appear to provide better range than the typical whip that most 2.4Ghz Rxs sport, but
that's no huge surprise given basic antenna theory. Some people make their own, or can
be bought as replacements for other brand Rxs.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 17, 2012, 10:30 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
When are you writing a book Ian?
Shadrack is offline Find More Posts by Shadrack
Old Oct 17, 2012, 10:50 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I meant the above as flattery...please take it that way. You have a lot of great answers and I have probably learned more from your posts than any other.
Old Oct 17, 2012, 11:52 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Great idea ! Or make a website ? You do explain very well.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Oct 18, 2012, 07:01 AM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
Originally Posted by ashdec87 View Post
I like it. Two suggestions tho. Try to pack it into a smaller, more streamlined box, otherwise the drag it too much. Second, I would go for a smaller chute. Maybe like 50 inch. Its better to have it come down faster and need to glue a little an having it float off really far.
You want it to come down at arond 8fps. A smaller chute will cause damage on impact with the ground. Ask me how I know this The way I have it setup, I can give it throttle to steer it to where I want it to land.
rsowder is offline Find More Posts by rsowder
Old Oct 18, 2012, 07:56 AM
Quebec, Canada
Joined Sep 2006
So its more of a RTE (return to earth) than RTH if you lose RC Its great fun to see it in action.
Old Oct 18, 2012, 11:09 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
But if you're in an "emergency" situation you may well have no throttle control... or any other control for that matter.
erkq is online now Find More Posts by erkq
Old Oct 18, 2012, 02:41 PM
rankfussa is offline
Find More Posts by rankfussa
rankfussa's Avatar
Joined Aug 2012
Originally Posted by subsonic View Post
That's amazing. I literally spend weeks and weeks (months?) building my Skywalker, but it was with all the FPV gear from the first flight, and I really do take way too much care during a build process.
What is that thing stuck to the outside of the left fuselage door?
Are the second antenna BODA from Hitec Optima 9 Rx.
If you look again, you will see one antenna on the right side, and another (left fuselage door) on the left side.
One horizontal position, and another in vertical position.
Thanks for comment
rankfussa is offline Find More Posts by rankfussa
Old Oct 18, 2012, 06:26 PM
rankfussa's Avatar
Joined Aug 2012
Guys,
I present my SW. Sorry for talking in Portuguese, but I will input what I said:
- Happyness for my Airplane
- About Lights. Strobe are normally put in another place, but I insert in middle Wing, with the normal lights.
- I will wait for more 1 day (48 horas total) to stripe the adesives about the glue.
- I change my Landing Gear to another model on last minute.
- I insert 2 ima in lateral door
- Fixed Otima9 with double tape 3M
- I explain about TrottleLock Key in Aurora 9.
- Test Motor
- Show Flaps and another commands
- Test Pan and Tilt
- My CG 1/3 from Leading Edge
Thanks for Watching.
Skywalker FPV - Comentários sobre a Construção (6 min 46 sec)
Old Oct 18, 2012, 07:45 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
CG should be around 30mm behind the servo wires.
That works very well.
Old Oct 18, 2012, 09:57 PM
rsowder is offline
rsowder's Avatar
San Francisco
Joined May 2009
I'm just doing this for fun, not for practical perposes. So, I would prefer not to damage my plane on impact with the ground.
Old Oct 18, 2012, 10:00 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Ah, that's a WHOLE different story then. In that case, your chute works great!
ashdec87 is offline Find More Posts by ashdec87
Old Oct 18, 2012, 10:58 PM
Quebec, Canada
Joined Sep 2006
Any more " air refueling " vids in the near future ? I loved those !
Old Oct 19, 2012, 02:02 AM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by rankfussa View Post
Guys,
http://www.youtube.com/watch?v=6cZdV1K6Y6I
your propeller is mounted incorrectly. the lettering on the propeller should be at the front of the plane.
try to turn it round. it will give you twice as much thrust...
rcmonster99 is online now Find More Posts by rcmonster99
Old Oct 19, 2012, 09:29 AM
rankfussa's Avatar
Joined Aug 2012
I will do that. Thanks for your comment, and help.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
