Old Oct 09, 2012, 08:02 AM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by Cathay Stray View Post
I'm slowly moving along assembling my SW
Never had a need to use BEC before but it seems like a commonly accepted thing that a bird as fat as a SW should be equipped with a BEC...
Now, I am going to use 4S setup with a 60A ESC (or 80A if 60A gets alarmingly hot during tests) and a bigger motor that together with a 10*6 prop will draw about 40A at 80 %.
ESC has a built-in switching 3A BEC.
4 digital servos + currently 1, later 2 analog servos for camera control.
Camera and video Tx are going to be fed from a separate 3S battery.
Do I really (really-really) need a 5A BEC for the servos only?
I do have it already, so it is not a question of money. I just see no point in adding an extra piece of equipment. People usually say, we might need BEC in case the ESC fries, but in my setup ESC will have more than enough power (and if I go for an 80A one it might only get slightly warm at all).
I'm a fan of less is better and use an ICE 50A with its internal 5A BEC on a 3S setup. That said, to be sure, you should measure your current in a worst case scenario. Some digital servos consume a moderate amount of current and 3A may be on the edge or create a "brown out" situation.
CN I Dawg is offline Find More Posts by CN I Dawg
Old Oct 09, 2012, 08:13 AM
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by tom3holer View Post
Hi,
Dumb question sorry. Just putting my SW together. I guess its a version 3 from what I can tell.
Bought it about a year and a half ago.
I have 6000Mah 4s I am planning on using along with a 2200 ish 3s. Just for rough planning purposes where will I be placing the batteries to achieve proper cg?
Tom
Tom, not being a wise guy but in the front. It's the only real place with room for the 6,000 mAh 4S. Just a note, your AUW is going to be really high. >800g for batteries alone. Be sure to re-enforce the wings and use an appropriate propulsion system.
Old Oct 09, 2012, 08:24 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by ffinybryn View Post
Further to earlier posts, I also made the mistake of not fixing the motor well enough. With disastrous results!! I was able to glide to land with the prop embedded in the rear.
Repaired with expanding foam. Motor fixed to ply with 50mm bolts extending into fuselage (and plenty of epoxy). Good as new...
Nice paint job. What type of expanding foam did you use if you don't mind me asking.?.
hendrnk is online now Find More Posts by hendrnk
Old Oct 09, 2012, 12:12 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
+1 ! Awsome looking SW
carguy1994ca is offline Find More Posts by carguy1994ca
Old Oct 09, 2012, 12:24 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Group answer on a few posts.
Use a BEC.
You are putting a lot of amps through your esc. If that goes, then a good chance that SBEC whether it is 3 or 5 amps goes.
I can deal with no motor, but I can't deal with no servos, or in some cases, no autopilot (FY31).
I use a CC BEC that is 10A and it is almost nothing weight wise.
As for the extra battery. As Sander has said numerous times, go with a single battery solution, especially since you will have a 6000 mA battery, you have a lot.
Great paint job on that SW BTW.
Hey, CG, when I fly around my flat lands, at least I know that those flat lands still want to belong to Canada.
Shadrack is offline Find More Posts by Shadrack
Old Oct 09, 2012, 12:48 PM
Quebec, Canada
Joined Sep 2006
And you said it flat out to me
Old Oct 09, 2012, 12:54 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I did. there wasn't any separation.
Old Oct 09, 2012, 04:12 PM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
Thanks guys, Another dumd question. I have the need for 5V for the OSD and servos and also 12v for the Vtx. Do the BEC's come available with dual voltages?
Tom
tom3holer is offline Find More Posts by tom3holer
Old Oct 09, 2012, 04:23 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I have not seen that. You can just take the feed off your battery and step it down to 12V for your camera using a step down, and use your BEC for the 5V needed.
Alternatively, a 5V camera to keep everything at 5V. (This is how I did it)
Thirdly, you could step up the 5V to 12V for the camera but that isn't a suggested way.
Old Oct 09, 2012, 04:33 PM
muduck is offline
Find More Posts by muduck
muduck's Avatar
Australia, NSW
Joined Apr 2004
Tom
Twin leads from battery..one to BEC, & the other straight to the VTx
muduck is offline Find More Posts by muduck
Old Oct 09, 2012, 04:36 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Tom
They sure do! 12V on one side, and 5V on the other!
subsonic is online now Find More Posts by subsonic
Old Oct 09, 2012, 04:45 PM
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
In my experience, I've been able to have 4 digital servos bring in internal BEC voltage down to brownout levels a few times in flight. Granted, it was in 3D planes, but from then on, I've always used a BEC as soon as I run 4 digital servos or more on one system.
I'd say there is no "really-really need" level, but in your system, given that you run 4S, (higher input voltage and more load on the BEC), have 4 digitals + others for pan / tilt etc, If it were mine I would definitely add one to allow you some system headroom.
Also, with the decision to go with a 60A or 80A ESC should have almost nothing to do with the outside temperature of the ESC. You should go by the current draw first and foremost. Do you have a meter? Stay within 80% of the ESC's rated capacity and you're golden.
Old Oct 09, 2012, 04:48 PM
Cape Cod
tom3holer's Avatar
Joined Sep 2010
Ok, If I am going to use one battery, a 4S as mentioned earlier, then I need to step it down to 12V for the Vtx and camera and the 5 v I can get from a seperate BEC. The question is how do I get a reliable 12v in that type of setup?
Old Oct 09, 2012, 05:02 PM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
Use a separate 12v battery for the vtx. There is always noise from servos and motor and you want yours vtx supply to be clear. SW can easily handle the weight of a 3s 800mah battery for the vtx
kstmark is offline Find More Posts by kstmark
Old Oct 09, 2012, 05:37 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
got to disagree kstmark.
even the guys that build the stuff say one battery.
extra weight, and if you build a small lcfilter, you can clean up the power perfectly. I have no noise at all and run a one battery system.
To me, I would just get a good 5v camera, I use a 600 line rmrc wdr and it is great.
Cost me 100 bucks, but love that my system runs very efficient, I see my amp usage as a total of servos, camera, motor, and osd/receiver.
My current sensor feeds 12V to my vTx, which gives 5V to my camera. I have an LC filter on the power from the current sensor to the vTx.
Have no noise at all.
I plug in one battery.
I can hold altitude at about 40 kph and 4 amps into a slight wind. That is 4 amps total including my osd, autopilot, limited servo use, 600mW vTx, and uhf diversity receiver. Plus the camera, and 2 servos for pan and tilt.
Still have rssi values in the high 60's and low 70's at 3km away.
Love this setup.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
