Old Sep 04, 2012, 10:33 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Originally Posted by jeff82 View Post
I've tested with the antenna pointing up and i was having many issues when coming home at 1,3 km. The video is totally clear in the other direction. So I think i've a masking effect and I'm looking for another setup for my antenna.
I've tried also to put the antenna not in the alignment of the fuselage but the issue is the same when coming home with a little shift.
What are you running for your receiving antenna?
Shadrack is offline Find More Posts by Shadrack
Old Sep 04, 2012, 12:53 PM
jeff82 is offline
Find More Posts by jeff82
France
Joined Feb 2010
DUO5800 V2 with SP and Helical 9.5dbi antennas.
jeff82 is offline Find More Posts by jeff82
Old Sep 04, 2012, 12:56 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I have a helical 7T with a windmill Tx and a fan Rx with the duo5800.
Old Sep 04, 2012, 01:12 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Thanks for the dive test info guys and for the added explanation !
carguy1994ca is offline Find More Posts by carguy1994ca
Old Sep 04, 2012, 07:01 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
So you think that the spar would break, or show signs of stress, before the foam was affected?
Maybe, I'm just saying that the permanent deformation or yielding of one material is not an indication of the state of the other.
So if we braced one side of the wing so it can't move, and inserted the spar fully, and then grabbed the exposed end of the spar and started to move it to the side, you say that the spar would snap before the foam would deform?
That would not be a close test, but but I don't think quite the same as the flight load because the compression force on the foam should be evenly distributed, not a point load.
I have had the wing lift and cause multiple high G loops that were unintended. People watching from the ground were surprised that the wing didn't snap.
Which probably shows that your spar is strong enough for normal aeros. If you can seriously abuse it like you have already, you should be fine provided you don't push it beyond that. Maybe others have just been unlucky.
Sub
subsonic is offline Find More Posts by subsonic
Old Sep 04, 2012, 10:02 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I think a lot have not had the wing strapped down tight enough.
I have witnessed that on a few planes that were flyable, but under the right load that elastic comes up and funny things happen. Have a friend with an apprentice. Did the same thing. Elastic got old and dry, and problems. Lucky enough I told the guys to land and checked it out. Sure enough, replacing them fixed the problem.
Now instead of watching it from the outside, pick up on that from the video from inside. Harder to pick up. Once that lifts up then crazy things happen and there is a lot of force that now doesn't have the extensions fully within the fuselage so the wing can now separate.
I try to tell the guys I fly with that at the first sign of trouble, or a funny noise, land.
Had a friend go across the field asking everyone...."you hear that buzzing? What do you think it is?"
My answer "the nut that is vibrating off the bolt as you keep on flying by. You will see what I mean right away."
He landed to find out it was the spinner starting to come loose on his prop.
I think if you keep this wing on the plane, bolts, or enough elastics, that a lot of these "wing problems" go away. How many people still needed to be told how to use the elastics. We had to have a video on youtube just to make sure people understood the concepts of "tight enough".
Something like that should be easy to check and easy to fix.
One of the little things that causes lost planes.
Old Sep 04, 2012, 10:15 PM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
"That video" that keeps getting posted wouldn't work for me. The only way I was able to get enough tension in the elastics to give me what I felt was enough tension (not measured, just going by experience and feel), was to double the elastics over, and use all 4.
My personal view, is that if I'd used the elastics singly, or as shown in the video, I'd have crashed by now.
Old Sep 04, 2012, 10:39 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The stock rubber bands installed the way that video shows, works just fine.
Full power loops, rolls, dives, aggressive turns, couple hundred hours of
flying in the last year and a half, and never had the wing lift.
There are various sources for standard #7 bands, which appear to be
a little tighter than the stock bands. Good idea to get some new bands
for when the stock ones get degraded by the sun and fail (they all will).
ian
Daemon is offline Find More Posts by Daemon
Old Sep 04, 2012, 10:47 PM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
I agree. I installed the same as the video and lost the wing... I can only assume the rubbers were not tight enough, so now I double them over and its so much tighter, no problems since, just a bent nose after the rebuild from the vertical drop from 500 meters...
Haych is offline Find More Posts by Haych
Old Sep 05, 2012, 12:25 AM
Lpbug is offline
Find More Posts by Lpbug
United States, CA, Santa Monica
Joined Jul 2011
Is there a US supplier for this plane?
Lpbug is offline Find More Posts by Lpbug
Old Sep 05, 2012, 08:15 AM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
got it fixed
Michael
mikenc is offline Find More Posts by mikenc
Old Sep 05, 2012, 01:14 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
ian
Ian, I know my new rubber bands after getting torqued in one flight, were useless afterwards. I ended up buying some SIG #67 bands that I use 6 of and am very safe. I couldn't use the stock ones anymore and I was using the video method. Maybe some of them are subpar.
Old Sep 06, 2012, 12:37 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by rcimports View Post
Video?
Practice and attempt at filming mountain bike race with drone (9 min 11 sec)
heinduplessis is offline Find More Posts by heinduplessis
Old Sep 06, 2012, 08:40 AM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Looks good, but I'd scrap all of the wood...that's just a lot of extra weight. Where's the HD cam going?
Originally Posted by Opus44 View Post
So I'm almost done with my SW1900 build also. It's taken a long to time build but look forward to flying it. It's hard to fine time to build with two children under 3, house work, a wife, a job and life........ Here are some pictures..
The RVGS is not mounted to the back of that patch antenna it's just sitting there.
let me know what you think.
AdamChicago is offline Find More Posts by AdamChicago
Old Sep 06, 2012, 08:53 AM
Chicago, IL USA
Joined May 2010
Antenna on the wingtip will give you the best video reception
On the pan behind the motor is just problems galore...been there, did that. Even if you're getting a decent signal back there now, just wait until you try the wingtip and then you'll be wondering why you ever put it behind the motor ...this is even more true with 5.8mhz where line of sight is even more important than it is at 2.4mhz or 1.3mhz.
Anyone has tried to put the antenna like this on its video TX ?
The antenna seems do not touch the ground when the SW is landing. But il's limit
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
