Old Aug 31, 2012, 07:23 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Thanks sub, but why is separation better?
heinduplessis is offline Find More Posts by heinduplessis
Old Aug 31, 2012, 09:28 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Originally Posted by heinduplessis View Post
I currently have 5 servo leads on my wing to plug in to my fuse. That's 15 wires. In theory I can make up a new connector, have a single - and + (from UBEC), and then 5 signal wires coming from receiver, camera and ap, splitting the power supply wing-side. This way I can speed up the attachment process and have 1 plug with 7 wires in stead of 5 plugs with 15 wires.
Does it make sense??
Use a sheilded CAT5E or CAT6 cable.
You have 8 wires.
+ -, and 6 for signal.
Plus it is shielded to remove interference.
Shadrack is offline Find More Posts by Shadrack
Old Aug 31, 2012, 09:31 AM
Foam Snow
Joined Aug 2011
You have 8 wires.
Got tonnes of those - what connector would you propose?
Old Aug 31, 2012, 09:37 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
You have 8 wires.
The shielding with CAT5E or CAT6 is around the 8 wires not the individual 8 wires. Therefore, if shielding is required between 2 or more of the wires within the CAT6 bundle it will not help.
hendrnk is offline Find More Posts by hendrnk
Old Aug 31, 2012, 10:01 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
You don't need to shield servo signals from other servo signals. If you were running video in there, sure, but just servo signals I don't think will have a problem running together. This will keep their signal from affecting things outside the cable though, or will help.
Old Aug 31, 2012, 10:02 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Use a CAT5 connectors. Don't know why that wouldn't work.
Old Aug 31, 2012, 10:09 AM
Foam Snow
Joined Aug 2011
There is a video wire :/ Maybe sound, too, later.
I haven't seen a female CAT5 connector that wasn't metal. Heavy..
Old Aug 31, 2012, 10:24 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
We sell female cat5 connectors all the time that are plastic. Keystone jacks that we snap into plates.
Old Aug 31, 2012, 10:25 AM
Foam Snow
Joined Aug 2011
Thanks - I'll do some searching..
Old Aug 31, 2012, 10:30 AM
hendrnk is offline
Joined Apr 2012
The plastic Cat 5 connectors are not shielded. The cable shielding needs to be earthed through the connector to a earthing point.
Old Aug 31, 2012, 11:19 AM
snelan is offline
Find More Posts by snelan
snelan's Avatar
Joined Jul 2012
Originally Posted by powerstroke01 View Post
Im sure its been asked a million times. But what battery setup for an fpv skywalker?
Im thinking a 3s 5000mah batt for motor since its a 1400kv motor.. But what about the camera and stuff?
I fly a 3s 5000 for my motor (1200kv)/etc, and a 3s 850 for my FPV equipment. However, a lot of guys just prefer something like a 4s 5000 with a 12v step down for FPV equipment. You could also do it with a 3s 5000 and a step-up step-down unit without any problems. It's really just personal preference, there's no right or wrong.
EDIT: If you are using a one battery solution, you need an LC filter on the power line going to your video equipment, else you will see lines when throttling up.
snelan is offline Find More Posts by snelan
Old Aug 31, 2012, 12:03 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Ok.
Forget using that cable then. Wow.
Pretty sure that he won't have problems.
None of the connectors he is using now are shielded.
He isn't running a 1Gb network.
He wants an easy way to hook up his wing.
Old Aug 31, 2012, 12:04 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
With the Immersion stuff, I run an LC filter between the current sensor and the vTx. No lines. Perfect signal.
Old Aug 31, 2012, 08:46 PM
Opus44 is offline
Find More Posts by Opus44
United States, CA, Redding
Joined Jul 2004
almost done
So I'm almost done with my SW1900 build also. It's taken a long to time build but look forward to flying it. It's hard to fine time to build with two children under 3, house work, a wife, a job and life........ Here are some pictures..
The RVGS is not mounted to the back of that patch antenna it's just sitting there.
let me know what you think.
Opus44 is offline Find More Posts by Opus44
Old Aug 31, 2012, 10:32 PM
hendrnk is offline
Joined Apr 2012
Looks like a new ducted fan experimental SW in the works...
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
