Old Jul 20, 2012, 11:27 AM
asaak is offline
Find More Posts by asaak
asaak's Avatar
Joined Mar 2012
Hi!
I've been reading how you guys build your skywalkers, and there is something that comes up to my mind. How do you guys would replace rear servos in case that you have to? As far as I've seen, you glue them to one side of the fuselage during the build up process...but what if, for example, the rudder servo brakes up and you need to replace it? Wires are hot glued inside...
Thank you!!
asaak is offline Find More Posts by asaak
Old Jul 20, 2012, 11:55 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Originally Posted by asaak View Post
Hi!
Thank you!!
I've had a rudder servo not work on me after it was installed, and to make things worse I didn't run the extensions down the tube, I glued them in next to it!
So I had to do some fine surgery and now run extensions down the outside of the tail boom with the original extensions in there for good!
Now I've glued the servos in, but have cut access hatches on the opposite side of the vertical stab.
Teamsherman is offline Find More Posts by Teamsherman
Old Jul 20, 2012, 02:00 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Whenever I have an issue with a servo like that (in any plane), I just cut the wires and
solder the new servo wires onto the old ones, rather than worry about trying to pull
the wires through wing/fuse/whatever. If you can, just leave a little bit of slack
in the wires near the servo inside the wing/fuse/stab when you install it.
ian
Daemon is online now Find More Posts by Daemon
Old Jul 20, 2012, 02:04 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
BTW.. please don't use hot glue. It is just pure weight. Most other adhesives are either
lighter to begin with, or they rely on evaporation to cure, so they become
lighter.
ian
Old Jul 20, 2012, 02:23 PM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
Too bad, have a cordless rechargeable hot glue gun to do a quick fix at the field.
I know, for that purpose it will be no problem, thanks for the tip anyway....
Mauro
mauromassari is offline Find More Posts by mauromassari
Old Jul 20, 2012, 05:30 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I am going to sell my Skywalker .. pictures and listing soon - just if someone is ordering one in the next couple hours.. will come as a 80% FPV system with DragonOSD+GPS and DragonLink Antenna (just the Antenna) built into the fuselage. More to this later...
flyandi is offline Find More Posts by flyandi
Old Jul 20, 2012, 09:07 PM
AdamChicago is online now
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
ok I forget...rudder & elevator servo wires through the boom CF rod good or bad? I'm rebuilding the fuselage from a spare body I ordered for parts and thought it would be easier and less messy to fish it through the CF rod.
Of course wires would be heavily twisted to reduce signal interference
AdamChicago is online now Find More Posts by AdamChicago
Old Jul 20, 2012, 09:11 PM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
Wires through the boom are a good thing, very neat and tidy. The problem is shrinking the connector....
cliffkot is offline Find More Posts by cliffkot
Old Jul 20, 2012, 09:27 PM
Chicago, IL USA
Joined May 2010
gracias
Old Jul 20, 2012, 09:28 PM
Chicago, IL USA
Joined May 2010
Oh hey Cliff, I responded before I realized it was you...thanks for the advice, hope your FPV is going well and thanks again for the help.
Old Jul 21, 2012, 12:12 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, WA, Jane Brook
Joined Oct 2010
Shrinking? I just remove and then reinstall the pins.
This was one of the few wires in my plane that aren't twisted beacuse I thought I'd lose too much length and add too much weight. Since it's inside the CF tube it's protected a little from RF anyway. I have no problems at all using 800mw of 1280mhz with a Hitec HS65KB (rudder) and a Align Metal gear (elevator).
As I've stated before. Just make sure you glue the CF rod into the same half as the servos install. Makes joining the halves so much easier when you dont have to worry about connecting the servos while your glueing.
Happy Days
joel0407 is offline Find More Posts by joel0407
Old Jul 21, 2012, 08:59 AM
Shadrack is online now
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
ian
This makes the most sense.
Isn't hard to do this, lot less work than pulling everything out.
Shadrack is online now Find More Posts by Shadrack
Old Jul 21, 2012, 10:22 AM
Chicago, IL USA
Joined May 2010
Well it turns out I'm not going to run the servo wires through the boom CF rod anyhow. I devised a tail stabilization plan, based on one I saw here a while back, that will block off the one end of the rod.
I'm going to drill a small whole through the end of the CF rod to fit another smaller vertical rod through it and then put a good amount of epoxy around that whole area to lock it all together and maintain the strength of the CF where the whole was drilled...maybe a fiber sheet around it to.
I'm not too worried about tail weight because I'm nose heavy now with a 5800 4s and 1500 3s (OSD/Vid batt) in the nose
Old Jul 21, 2012, 11:03 AM
texasdrifters is offline
Find More Posts by texasdrifters
Joined Apr 2011
AdamChicago,
I drilled a small hole in the tail boom and inserted a small carbon fiber rod angled upward into the tail. I think this is a good strategy for strengthening the tail. Unfortunately, during one of my crashes, the tail broke off at this point. I did not use epoxy for the bonding. I think this is a good approach for stiffing up the tail section, however, during my beginner stages of learning to fly, I was tough on the Styrofoam.
Good Luck,
Hector
texasdrifters is offline Find More Posts by texasdrifters
Old Jul 21, 2012, 01:24 PM
Chicago, IL USA
Joined May 2010
Hey thanks Hector, usually when I post my "good ideas" they're shot full of holes LOL. I actually didn't have a whole lot of trouble with the tail on my current Skywalker but thought since I'm re-building, why not.
I would say the tail snapping at that point was probably more coincidence than anything else, and I know a sure fire way to resolve that...don't crash! haha
Originally Posted by texasdrifters View Post
AdamChicago,
Good Luck,
Hector
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
