Old Jul 17, 2012, 07:46 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Adding carbon spars to prevent the wing breaking is different than adding them for rigidity.
I'm primarily concerned with rigidity because this wing will flutter at high speeds.
That one piece wing decision may come back to bite you, as it doesn't take all that much
to break the stock joiner and then there's no way to replace it. Happened to someone
a few pages back.
ian
Daemon is online now Find More Posts by Daemon
Old Jul 18, 2012, 05:22 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
It may not be as ridged as top and bottom but it must increase rigidity considerably. The flex is as much part strech on the bottom as it is compression on the top. Adding CF strip on the bottom takes all the strech out of the bottom.
Doesn't worry me any way as I have added top and bottom, although not in the thickest part of the wing as you pointed out previously.
a few pages back.
ian
Thats why my CF stips pass right across the middle without joins.
joel0407 is offline Find More Posts by joel0407
Old Jul 18, 2012, 08:33 AM
Dogzilla is offline
Find More Posts by Dogzilla
Joined Jun 2004
The downside I can see to having them both on one side only is that when pulled in one direction the spars can pull out of the foam. With one on each side, at least one spar is resisting that as it has foam above it.
I think I've negated much of that by using 10mm wide strip which I took great care to squeeze in as tight and deep and nicely wicked in CA. Certainly they are vastly improved in stiffness already.
Dogzilla is offline Find More Posts by Dogzilla
Old Jul 18, 2012, 09:05 AM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Here's another video...mixed Skywalker and Zephyr, see if you can tell which is which
Just discovered the DVR was set for "High Compression" on the OSD shot towards the end which I have been disappointed in the resolution so am glad to see it should be improved for future footage not that I changed the setting
Shoe Factory FPV 7-15-12 (3 min 15 sec)
AdamChicago is offline Find More Posts by AdamChicago
Old Jul 18, 2012, 03:31 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Think the shadows give it away!
I want that flying field!!
Shadrack is offline Find More Posts by Shadrack
Old Jul 19, 2012, 12:54 AM
digitalCAM is offline
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
https://vimeo.com/45949778
Looks like the Zepher has a GoPro. Is the Skywalker camera a GoPro with a different lens ? -- JOHN
digitalCAM is offline Find More Posts by digitalCAM
Old Jul 19, 2012, 02:03 AM
Alyas is offline
Find More Posts by Alyas
Australia, VIC, Dandenong
Joined Jul 2010
is it appropriate if i post a few pics of the skywalker V6 here? and get a few building tips of it, and people could get a glimpse of it as well.
Alyas is offline Find More Posts by Alyas
Old Jul 19, 2012, 02:14 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
Go for it, the more the merrier.
RolandS888 is offline Find More Posts by RolandS888
Old Jul 19, 2012, 02:25 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Go for it. Lets see it.
Old Jul 19, 2012, 06:34 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Hey guys.
Today was the maiden for my Skywalker. The plan was a little trimming and some Dragon OSD Auto Pilot testing.
I was surprised by how much trimming it took. I haven't measures the control surface adjustments yet but it seemed like a lot when I was clicking the trim again and again.
Anyway while trimming I got into more of a dive than I wanted. I pulled back more and more. The more I pulled with little effect the faster I pulled until the following happened (see Vid). I suspect my wing lifted. It just flipped so quick. I thought it was just going to fall right out of the sky.
Also need to add that I haven't calibrated the Current sensor yet. The OSD showed 10amp cruising but my Castle ESC recorded 6amp.
And I crashed at the end. It was only very minor with no damage. The Skywalker just kept on floating. It floated right past where I was standing at the beginning of the runway. I thought I would get it down by the end but it over shot. I couldn't throttle up and come around again because I was too late to to get height over some trees at the end. I landed before the trees but in a ditch.
With OSD
Skywalker Flip (0 min 25 sec)
In my youtube rendered HD vid, now 480p
HD Skywalker Flip (0 min 36 sec)
Old Jul 19, 2012, 08:32 AM
Chicago, IL USA
Joined May 2010
Nope flew the same cam/lens on both planes...there's a chance I changed the setting for which level of wide-angle, now I'm going to have to back and analyze
Old Jul 19, 2012, 05:22 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Originally Posted by joel0407 View Post
Hey guys.
With OSD
Wow that was a wild ride I assume that was a LOS flight?
Two things I'd recommend.
1) Try using some of the "other" power settings.
2) It certainly looked like your wing lifted off when at a high power setting in a dive. You would never intentionally fly the aircraft this way, but it makes sense to have enough elastic tension so that if it did happen accidentally things will stay together. you just need to add more bands, a different type, or do as I did with the stock bands and doubled them over, using all 4 supplied.
subsonic is offline Find More Posts by subsonic
Old Jul 19, 2012, 10:24 PM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Yep, LOS, testing Dragon OSD Auto Pilot and trimming the Skywalker.
I was backing off, trying not to make any sudden movements. I'm sure I had my rates far too high. I might not have been right off the throttle but It wasn't on much. The OSD shows 6amp but it's not calibrated. 10amp on the OSD is only about 6 so 6 must be only 3 - 4 amp.
Old Jul 19, 2012, 11:19 PM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Ah, it just sounded like high power then. Yep, with the CG where it needs to be on this plane, control throws should be set farile low on the elevator. I think mine only has about 10mm up and down. It is ample.
Definitely need to re assess your wing retention then. More rubber I say!
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
