Old Apr 05, 2010, 09:46 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Question
Difference between 4S2P and 4S1P?
What is the difference between a 4S2P and a 4S1P pack? In other words, what does the 2P vs 1P mean and how does that relate to power, longevity, etc? Is one better than the other, etc?
Bombay is offline Find More Posts by Bombay
Old Apr 05, 2010, 10:04 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Picture worth many words. Set the drawing up for 4S and 1P, then 4S and 2P.
Power, longevity, etc depends on the cells. A 4S1P can have the same capacity as a 4S2P, depending on the capacity of the cells.
Note the explanation printed under the picture.
Bill
ebill3 is offline Find More Posts by ebill3
Old Apr 05, 2010, 10:55 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
The P is for Packs, so a 4S2P is 2 4 cell packs. Now whether or not that is wired in series or parallel depends. Technically you can consider your regular lipo packs as a 1S3P for a 3 cell, or 1S4P for a 4 cell.
Xpress.. is offline Find More Posts by Xpress..
Old Apr 05, 2010, 11:01 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Wrong. S is for number of cells series, P is for number of cells parallel (for each serial connection).
Naming conventions shown in sticky.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 05, 2010, 11:19 PM
EricJ320 is offline
Find More Posts by EricJ320
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
Uh yeah, thats exactly backwards. 1S3P 1200mah, for example, would be a 3.7v pack with three 400mah cells in parallel. What would be more normal is a 3S1P 1200mah, or 3 1200mah cells in series, only 1 in parallel. It's kind of redundant to say 1 in parallel so the 1P is often dropped, unless it is more than 1.
The number before the S increases the voltage of the pack, the number before the P increases the capacity.
EricJ320 is offline Find More Posts by EricJ320
Old Apr 06, 2010, 06:28 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Thanks for the replies. I have a better understanding now. The link provided by eBill3 is great. Same goes for the sticky provided by mrforsyth.
http://scriptasylum.com/rc_speed/_lipo.html
So, in comparing the two batteries below...not counting brand, price, or C rating, why would a person go for a 4s2p instead of a 4s1p (or vice versa)? Is there any benefit of having a greater number of cells (all other things being equal)?
http://hobbycity.com/hobbyking/store...idproduct=7656
http://hobbycity.com/hobbyking/store...idproduct=9463
Old Apr 06, 2010, 07:32 PM
ebill3 is offline
ebill3's Avatar
I'll take the 4S1P. Usually lighter and smaller. There are fewer interconnects, which means less chance for that type of failure. And, if an interconnect does fail and a person is so inclined, much easier to rectify.
Not too long ago, 4000 mA cells were unheard of, therefore cells in parallel were quite common. Are the high capacity single cells of decent quality compared to lower capacity? I do not know - perhaps someone else has a thought on that.
Bill
Old Apr 06, 2010, 08:19 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Lol, somehow my example got messed up...
Good thing there's more people here
Discussion what is the difference between and in bec/out bec/ubec ? mortonj69 Power Systems 23 May 18, 2010 02:16 AM
Question Difference between low and high end chargers Thews Batteries and Chargers 19 Mar 23, 2010 08:15 AM
Discussion actual difference between neu 1515 1y and castle/neu 1515 1y hydromaddicted NeuMotors 2 Mar 03, 2010 02:01 PM
Question difference between Futaba 35MHz rf modules Ahmed Radios 1 Feb 26, 2010 05:15 PM
