Old Jun 02, 2003, 10:49 AM
Kraeuterbutter is offline
Find More Posts by Kraeuterbutter
Kraeuterbutter's Avatar
Europe, Austria, Burgenland
Joined Mar 2002
and again: new LiPO-cells: http://www.cymbet.com
look at this:
http://www.cymbet.com/features.php#top
some outtakes:
  • Discharge Rate Capability: Continuous up to 5C; intermittent pulses up to 15C
  • Extremely High Energy Density: Up to 300 Watt-hours per kilogram
  • Fast Recharging: Up to 50C rates at 80% efficiency
a graph:
Kraeuterbutter is offline Find More Posts by Kraeuterbutter
Old Jun 02, 2003, 10:54 AM
Joined Mar 2002
Old Jun 02, 2003, 12:09 PM
Capt. Electron is offline
Find More Posts by Capt. Electron
Senior Moment Member
Virginia Beach, Va.
Joined Jan 2002
Kraeuterbutter,
That is indeed a very interesting product. I noticed you can even charge it through induction and RF.
The only problem I see though it says "up to 1ma per square cm". That would seem to be quite a bit of surface area for the cell sizes we use, unless they could fold or roll it up after applying the layers. But it reads as though it's resin cast or something similiar to a chip and seems to be more for use as low power and manufactured right on the device or chip it's powering.
But the technology will probably lead to bigger and better I'm sure.
Let's see, with a 4x8 sheet of fanfold coated, I could get about 45,000ma. If I got 6 planes out of that, less waste, I'd have about 5000mah per plane. or 2,500 at 7.2V. Capacity would probably diminish after each crash, depending on how much of your "battery" you left at the crash site. I could modify the microwave and stick it in there for about 45 seconds to recharge, and I'm off again.... I mean really off, just kidding, don't try that at home.
Jimmy
Capt. Electron is offline Find More Posts by Capt. Electron
Old Jun 02, 2003, 12:57 PM
Joined Mar 2002
well..
i have to say: English is difficultly for me, and many many things i may no have got the right way...
"charge it through induction and RF" ???
inducation = without mechanically connecting them, "charging through the air" ??
RF ??
i have also noticed that on there application-site they mention many things that sound for "low-power"-mashines...
but they nevertheless speak about 5C continously and 15C peaks..
Old Jun 02, 2003, 01:02 PM
Joined Mar 2002
i will go with LiPO when they do following things for me:
1.) 6C continously 10C peaks
2.) charging with 2C
3.) price lower
ad 1) on a 8000mAh-pack that would mean 50A continously, and 80A for short..
so the values a good NiCD 2400-pack can give
ad 2) my 2400-packs i charge with 8A.. they are full in aoubt 25minutes
a 8000mAh-pack: i want 16A charge-rate, so its full in about 30-40min
Old Jun 02, 2003, 09:41 PM
ShamelessMale is offline
Find More Posts by ShamelessMale
In need of a new name...
Clarkston, MI
Joined Dec 2002
3.) price lower
Items one and two are definately available now with E-tec, and are possibly / likely available now with Kokam HD series. Send Dave or Electroman some money, you have to pay to play!
PS I gave number 2.) an rating because it still takes more than half an hour to get more than say an 80% charge even if you start out at 2C since the current tapers off...
ShamelessMale is offline Find More Posts by ShamelessMale
Old Jun 03, 2003, 07:53 AM
Joined Mar 2002
cool would be a charging-time of 10min *gg*
with my small NiCd-batts for my slowflyers thats possible..
10min and they are full..
well in the moment: the price...
with 300 Euro pocket-money (iam a student, not working in the moment) its not really possible to spend 200Euro for a single batt-pack
Old Jun 03, 2003, 07:57 AM
rinninsland is offline
Find More Posts by rinninsland
Germany
Joined Sep 2002
With 50C it will last < 2min :-))
rinninsland is offline Find More Posts by rinninsland
Old Mar 26, 2005, 06:37 PM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
Old thread revived 2003
has anything new happened from this???
Ralf
treehog is offline Find More Posts by treehog
Old Mar 26, 2005, 06:41 PM
TeamSME is offline
Find More Posts by TeamSME
40%, 5% whats the diff?
TeamSME's Avatar
Baltimore Greenbelt, Maryland, United States
Joined Jul 2003
It's 50c charge rates!
TeamSME is offline Find More Posts by TeamSME
Old Mar 27, 2005, 09:54 AM
HARRomeo is offline
Find More Posts by HARRomeo
1 Clown short of a Circus
HARRomeo's Avatar
Merrimack, New Hampshire, United States
Joined Jul 2003
Are you acknowledging that TeamSME or asking?
HARRomeo is offline Find More Posts by HARRomeo
Old Mar 27, 2005, 12:25 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Wonder what "80% efficiency" means on those claimed, but apparently not yet verified in production, 50C charge rates?
Dave Hederich is offline Find More Posts by Dave Hederich
Old Mar 27, 2005, 05:44 PM
katobaggins is offline
Find More Posts by katobaggins
Not now, Kato! Not now!
katobaggins's Avatar
Sheridan, OR USA
Joined Jan 2005
It seems that this product would be great for RC. For the sake of arguement, lets take a look:
A 100x30 mm (30 sq. cm) cell constructed of 100 layers in parrallel of this material would 3000 sq. cm delivering 3000 mah @ 3.6V. I roughly estimate that these 100 sheets would be about 10 mm thick if no spacing is needed between layers. Each 100x30x10mm cell would about 45 gr, or 15 gr/1000mah.
A 7.2V 3000mah 2S pack would be 100x30x20 mm at 90 gr., being capable of delivering 15 amps continuous (the reason I choose this size to work with) with bursts of 45 amps possible. According to MotoCalc, I should be able to fly an Omega 1.8 E with a geared Hacker B20 18L swinging a 13x9 prop at full trottle for about 22 min, with a 1200 ft/min climb and barely go over the 15 amp mark. At half throttle, I could fly it for about 2.5 hrs! This is a 30% improvement over the nearest cell in weight that I could find, the Tanic 2100 2S.
The 50C charge rate is mind-blowing though! It would take 150 amps to charge the above pack at the 50C rate. It would be done in under 2 minutes. Not even long enough to take a leak. I'm betting there are some heating/fire issues at that rate. I also would bet that 50C rate is not with 100 sheets stacked on top of each other either. But even a 5C charge rate would cut the charge time to 12 minutes at 15 amps. It's still beyond any Li-Po/Ion charger of which I am aware. It gets more possible with smaller packs though.
If you take into account the "unlimited" number of recharges (over 70,000)and the very low self discharge rate (1% per year), it would seem ideal for RC. This material must be really expensive not to have made it to our neck of the woods yet.
katobaggins is offline Find More Posts by katobaggins
Old Mar 27, 2005, 08:25 PM
Joined Feb 2000
Please note that this thread was started more than 2 years ago. Where are the production cells?
New brand on http://www.aircraft-world.com/ - Hyperion ViktorF Power Systems 224 Sep 04, 2005 07:33 AM
Creating backup parts.. http://www.gmfoam.com ?? jrotor Foamies (Kits) 6 Sep 19, 2002 06:50 PM
http://www.rcgroups.com/forums/showthread.php?s=&threadid=13932 markdam Sport Planes 0 Oct 13, 2001 06:41 PM
is http://www.modelresearchlabs.com/ still in business? rayc Parkflyers 0 Jun 18, 2001 03:34 PM
