This thread is privately moderated by 3DTRYER, who may elect to delete unwanted replies.
Old Apr 05, 2010, 02:48 PM
3DTRYER is offline
Find More Posts by 3DTRYER
Trader Rating: 81
United States, CA
Joined Oct 2002
Trader Rating: 81
Sold
Aurora 9 - 9 Channel 2.4GHz Aircraft Computer Radio
For Sale: NIB. Hitec Aurora 9 - 9 Channel 2.4GHz Aircraft Computer radio with 7-ch receiver $385.00 shipped to the lower 48 states plus 3% paypal fee.
Basic Features
AFHSS 2.4GHz / PPM / PCM Compatible
Easy to Read 5.1 Inch Wide Backlit Touch Screen
Customizable Menus
One-Stop Model Type Setting
3 Multi-Tasking Digital Trims
Fully Assignable Control Switch, Knob, Stick and Digital Trims
Highly Sensitive 8 Ball-Bearing Gimbals with Adjustable Tension
Full-Sized Comfortable Hand Grips Featuring Top Quality Elastomer
Selectable Control Stick Mode / Change Hardware without Opening Case
Power Management System (Adjustable Backlight & Auto Shut-off Time)
Digital Trim Nano-Adjuster (Approx. 0.025deg per step up to 5deg)
Standard Programming Features
9 Assignable Control Channels
3 Model Types (ACRO/GLID/HELI) Programming
30 Model Memories
20 Character model name
8 Flight Conditions with 10 Characters
Throttle Lock
Fail-safe
Channel Function
EPA
Dual Rate & EXP*
Sub-Trim
Servo Reverse
Servo Speed (Up to 25 sec in Each Direction)
Servo Monitor (Monitor & Servo Test)
8 Programmable Mixes (5 x 2-Point , 3 x 7-Point Curves)**
Trainer Port
Advanced ACRO Programming
9 Wing Type (6 Main Wings, 3 Flying Wings)
5 Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
Quick Model Options Select (Dual Engine, Retracts gear, Airbrake, Fuel mixture)
7 Point Throttle Curve*
Throttle Cut
Idle Down
Fuel Mixture*
Airbrake
Airbrake to Elevator Mix**
Aileron to Rudder Mix**
Elevator to Camber Mix**
Rudder to Aileron Mix**
Aileron Differential*
Aileron to Flap Mix**
Camber Mix**
Flap Control*
3 x Gyro Sensitivity (ex: AILE/ELEV/RUDD)*
Snap-Roll (4-Way Switching Multi Direction)**
V-Tail**
Delta Mix**
Ailevator**
Advanced GLIDER Programming
9 wing Type (6 Main Wings, 3 Flying Wings)
Five Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
Quick Model Options Select (Motor, Retracts Gear, Airbrake)
Motor Control (Switch on/off)**
Airbrake
Launch (Stick Position Auto Cut Function)**
Camber Mix**
Flap Control*
Butterfly**
V-Tail**
Delta Mix**
Ailevator**
Advanced HELI Programming
6 Swash Types (90 Type: 1 Servo, 3 Servos, 4 Servos; 120 Type: 3 Servos; 140 Type: 3 Servos; 180 Type: 2 Servos
Quick Model Options Select (Governor, Needle Control, Fuel Mixture)
7 Point Pitch Curve*
Throttle Cut
Gyro Sensitivity*
Needle Control*
Swash to Throttle Mix*
Rudder to Throttle Mix*
Fuel Mixture*
Throttle Hold***
Swash Mix (Swash Rate/Calibration )***
Revolution Mix*
Governor (Three Rates)*
* Capable of a Maximum of 24 rates by 8 flight conditions and 3 switch positions
** Capable of a Maximum of 8 Rates by 8 Flight Conditions
*** Capable of a Maximum of 3 Rates Using 3-Swicth Positions
3DTRYER is offline Find More Posts by 3DTRYER
Old Apr 05, 2010, 04:37 PM
yaitsfast is offline
Find More Posts by yaitsfast
Trader Rating: 10
Is everyone from California?
yaitsfast's Avatar
Orange County, NY
Joined May 2007
Trader Rating: 10
Why are you selling a brand new radio & receiver?
yaitsfast is offline Find More Posts by yaitsfast
For Sale Futaba 6EX 2.4GHz FASST Computer Radio TX, Battery, Charger, Manual, Box, etc. - $85 snoopy Aircraft - General - Radio Equipment (FS/W) 4 Apr 03, 2010 01:49 PM
Discussion Hitec Aurora 9 Channel TX 2.4Ghz - Coming to Australia? panzerd18 Australia 59 Feb 14, 2010 05:27 PM
Sold Eurgle 2.4Ghz 3-Channel Computer Radio and 4 Rx's! Kmot Boats (FS/W) 5 Jan 23, 2010 10:46 PM
Sold Eurgle 2.4Ghz 3-Channel Computer Radio and 4 Rx's! Kmot Cars - Accessories (FS/W) 2 Jan 23, 2010 07:51 PM
Wanted 9 Channel Computer Radio FM scolen3 Aircraft - General - Radio Equipment (FS/W) 7 Dec 03, 2009 08:33 AM
