Old Apr 05, 2010, 08:11 AM
United States, TN, Jackson
Joined Mar 2007
EDF Motor for 64mm fan unit using 4S???
I ran my Exceed RC 5000kv motor in my G&C Mini F-16 w/64mm fan...The motor smoked on the first flight.....What motor can I run on 4S with this fan unit??? I'm running a 30-40C 1600 mAh 4S Turnigy battery pack...The motor I need must have a 3mm shaft...Would a lower kv rating motor work???...Please help ASAP as I want to get this back in the iar quickly...The wife gave this to me for a get well gift and is miffed that it's non-flyable after the first flight...Please include all necessary spcs with your recommendations as I'm new to the EDF aspect of the hobby..
By the way..This plane was SMOKIN' FAST (pardon the pun) with this motor and pack!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Apr 05, 2010, 08:55 AM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
Don's wicked 4000kv motor:
http://www.donsrc.com/cart/index.php...d&productId=92
ex-racr is offline Find More Posts by ex-racr
Old Apr 05, 2010, 05:34 PM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Ditto what he said.
I have the 4400kv in an almost 70mm sized airframe making 800+ watts on 4s.
32oz planes cruises easily at less than half throttle.
Check out the vertical at 1:55 in this video.
Julian
Boogie_ is offline Find More Posts by Boogie_
Old Apr 05, 2010, 09:19 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Considering your small 1600 mah battery I'd suggest a the KD450H from Hobbycity, 3200 kv. On 4S 2200 pack in a 65mm Wattage fan it pulls about 30 amps and 400 watts, on your smaller pack I think a bit less. I usually go for a lower than average amp draw that I see on here, I'm not trying to break any speed records!
Ed Waldrep is offline Find More Posts by Ed Waldrep
Discussion EDF Hi Performance motor/fan combo, anyone using this? I am! fatjet Power Systems 2 Mar 19, 2010 02:31 PM
Wanted EDF 64mm fan unit from Starmax Red Viper GiusedtoBe Aircraft - Electric - Jets (FS/W) 3 Feb 18, 2010 11:31 AM
For Sale 64mm EDF fan unit with motor and 25 amp ESC! UAV_PILOT Aircraft - Electric - Power Systems (FS/W) 0 Jul 27, 2009 09:32 PM
Found 64mm EDF motor or EDF unit with motor latinlax01 Aircraft - Electric - Power Systems (FS/W) 3 May 25, 2009 01:14 AM
EDF 64mm fan Cox/Estes fan unit. airmcn_3 Electric Ducted Fan Jet Talk 7 Aug 11, 2005 02:10 PM
