Old Apr 04, 2010, 08:26 PM
Fast Guy is online now
Find More Posts by Fast Guy
Canada, ON, Thunder Bay District
Joined Apr 2007
Sig 1/5 Scale J3 Piper Cub Kit on Floats
I built this plane as my first kit build. It took a long time but I really enjoyed it. I went a little over board on lightening the but I managed to save just over a pound on the pair of 60 size Great Planes floats. The Cub flies nicely with or without the floats. Very satisfying project. Electric power to boot.
Fast Guy is online now Find More Posts by Fast Guy
Old Apr 04, 2010, 11:36 PM
moes is offline
Find More Posts by moes
Frozen Flyer
moes's Avatar
Twin Cities, Minnesota
Joined Feb 2009
nice..
moes is offline Find More Posts by moes
Old Apr 06, 2010, 04:24 PM
JGuilty13 is online now
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
very nice build!
JGuilty13 is online now Find More Posts by JGuilty13
Old Apr 06, 2010, 07:19 PM
Joined Apr 2007
I enjoyed the build very much. Don't know if I could find that much time to spend on another build like this but I smile when I think, did I really build that. Flys great too even with floats. Thanks, happy you liked it.
Old Apr 06, 2010, 11:36 PM
Steve Ebel is offline
Find More Posts by Steve Ebel
Knoxville, Iowa
Joined Feb 2007
Fast Guy,
That kit is designed for gas engine. How did you do the lightening? Did you just cut away wood or re-design the kit. Did you use carbon fiber?
Steve Ebel is offline Find More Posts by Steve Ebel
Old Apr 07, 2010, 07:44 PM
Joined Apr 2007
Originally Posted by Steve Ebel View Post
Fast Guy,
I built the kit as per instructions as it was my first attempt at a build and that was challenge enough. I did fill the firewall with holes to lighten that and provide cooling to the ESC and battery. I also had to replace the tail stay wires with carbon fiber to lighten the tail and balance the plane. I put most of the effort into the floats shaving just over a pound off their total weight. There is lots of potential to make this plane lighter by the experienced builder for electric power even though it has the capacity to carry some serious wattage that can easily make up for the extra weight.
Old May 05, 2010, 01:25 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
what covering material did you use? what motor/esc/battery?
TexasClouds is offline Find More Posts by TexasClouds
Old May 05, 2010, 04:43 PM
Joined Apr 2007
I used Top Flite MonoKote Cub Yellow fo the covering.
Motor: Great Planes Rimfire .80 50-55-500 Outrunner Brushless
ESC: Castle Creations Phoenix-80 Brushless ESC
Battery: FlightPower EON 30 LiPo 6S 22.2V 3300mAh 30C
Hyperion CX 25c 4000mAh 6s 22.2V
Prop: Xoar 16x6 Sword
Hope this helps.
Old May 05, 2010, 04:50 PM
Joined Feb 2010
Hope this helps.
thanks.
still amazed at your end result...
Old May 11, 2010, 11:37 AM
Grits is offline
Find More Posts by Grits
USA, GA, Darien
Joined Dec 2009
Hope this helps.
Hey LastGuy...
I'm thinking of going electric on this same kit.....
If you were doing it over again, would you improve on your present set up, go to Gas/Glow, or just do it the same again?
Is this a real top notch....... good elec set up?
How long is flight time?
What about sound vs 4cycle?
Andy
Grits is offline Find More Posts by Grits
Old May 11, 2010, 06:17 PM
Joined Apr 2007
Originally Posted by Grits View Post
Hey LastGuy...
Andy
This kit is way over built for an electric and an experienced builder could lighten it up for sure. My plane ended up being 7 1/4lbs AUW with wheels, which is close to a glow-powered cub. I live on a lake and have lots of neighbors so electric means early morning flights without annoying anyone. As for sound the power system can be almost silent to sounding really cool under full power when the prop starts to roar. Does it sound like a 4 stroke? No, I like the sound it makes much better but thatís just me. I would build another electric if doing it again. Electric is just getting better and better. Batteries are making huge advances. Getting about 12 to 15 min. on a 6s 5000 mah battery. About 5min. longer than my attention span. I chose the Rimfire motor because I have had good success with them and they are a mid priced motor. The Castle Creations ESC is very good and the Rimfire works well with it. I just got some new generation Lipos (Hyperion G3) and without changing anything but the battery my power system jumped from 48a/ 900watts (FlightPower EON) to 69a/1600watts with the Hyperions. The Cub would almost hover on 900watts so 1600watts should be interesting. This is within the limits of my power system but I haven't had a chance to try it out yet.
One change I made to better balance the plane was move the rudder and elevator servos ahead to about mid door. This allows the battery to be placed rearward so it is easier to tie in. Hope this helps.
Old May 11, 2010, 07:13 PM
Grits is offline
USA, GA, Darien
Joined Dec 2009
Thanks Fast Gay,
I may be following your lead here.....
This may be the nicest Bird I've ever seen!
....Andy
Old May 12, 2010, 08:04 AM
Joined Feb 2010
Thanks Fast Gay,
....Andy
+1!
Old May 12, 2010, 09:45 AM
Grits is offline
USA, GA, Darien
Joined Dec 2009
Hacker?
What about the Hacker Motor.....Better?
Andy
Old May 12, 2010, 04:50 PM
Joined Apr 2007
I haven't had any Hacker motors but they do cost more than the Rimfire motors and many have reported that they work very well. With their lower internal resistance they produce more power and less heat on the same amp draw. I do have some Axi motors that I'm very pleased with in my larger 3D planes running on 12s. They are priced the same as Hackers. I don't think you could go wrong with a Hacker.
Build Log PIPER CUB Clipped Wing 1/4 scale SIG kit - Davide72 Scale Fuel Planes 157 Aug 09, 2012 02:17 AM
Discussion 1/5 Scale Piper Cub on Floats thewatergoblin Scale Fuel Planes 4 Apr 27, 2010 12:46 PM
Sold Receiver ready 1/4 scale Sig J3 Cub - Local pick up only Hoverup Aircraft - Fuel - Airplanes (FS/W) 8 Mar 24, 2010 03:56 PM
Discussion Funbuild 2. 1/5 Scale Sig J3 Cub kit build RyanPSU21 Scale Kit/Scratch Built 83 Jun 23, 2009 09:28 PM
