Old Apr 04, 2010, 12:01 PM
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
FMS/Airfield F4U Corsair 1400mm EPO Warbird
Have heard on the grapevine that FMS are developing yet another big foamie in the form of a F4U Corsair. A european website is already listing the mini version which is yet to be released, apparently the Corsair will be coming after the big P-47, Spitfire and Bf 109 which are scheduled to be released later this month
NOW THIS IS A PLANE THAT I MUST HAVE!
Scheduled release is for August 2010
FAQ's
Where to buy: Aerialhobby, PW-RC, RC-Castle, Nitroplanes(Airfield brand), Ready2fly, ChargedRC, XtremeRC
Battery sizes: 2200-4500 mAh 20-30C 4S
Prop replacement/upgrade: 13x8-13x10 2 blade
Motor replacement/upgrade: Stock G&C 3648 520-600kv, Turnigy SK 4250 650kv, Turnigy SK 5055 580kv
Stock ESC has in some cases reported to have had problems, this is a manual that has been reported to work for programming http://www.giantcod.co.uk/forum/viewtopic.php?f=9&t=888
Advisable to run an External BEC 3A minimum or atleast an ESC that uses a SWITCHMODE onboard BEC.
CG has been revised by FMS and is now recommended at 90mm from the leading edge. (Was originally 125mm with many reports saying it was just way to tailheavy and nose weight needing to be added) personally I have mine at 87mm from LE.
FMS Airfield CORSAIR F4U (Modified): Full Flight & Box Review (10 min 25 sec)
jbc is offline Find More Posts by jbc
Old Apr 04, 2010, 12:37 PM
Tally Ho!
kusunokimasahige's Avatar
The Netherlands
Joined Apr 2006
Hahaha FMS is filling the gap we all were hoping would be filled !!
KM
kusunokimasahige is offline Find More Posts by kusunokimasahige
Old Apr 04, 2010, 01:08 PM
USA, FL, Hudson
Joined Dec 2009
Kinda curious what kind of wing flex we are going to see with a large bent foam wing.
One thing is for sure, I am gonna need another job and a larger garage.
Troy S is offline Find More Posts by Troy S
Old Apr 04, 2010, 11:34 PM
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Bigger garage, bigger house, more money lol that's a good point about possible wing flex it's not like you can simply just whack a CF tube in it, maybe it'll be be nice and beefy in close to the fuselage and then a flat strip out to the wingtips
Old Apr 05, 2010, 06:11 AM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
They need to slap some EPS into their molds so we can glass these easier. Then the wing would be plenty strong
MYC is offline Find More Posts by MYC
Old Apr 05, 2010, 07:13 AM
Tally Ho!
The Netherlands
Joined Apr 2006
Eerm.... ever heard of epoxy resin which you can just brush on the entire wing ?? no need for glassing then...
KM
Old Apr 05, 2010, 07:32 AM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
Just adding epoxy resin would do little more than provide some dent resistance KM. The glass/epoxy combo gives the strength to turn foam into a solid aircraft. I have been doing this for years, starting with Combat Models planes in the 90's, and more recently with FlyFly jets, proper application adds very little weight for awesome gains in strength and airframe rigidity
Old Apr 05, 2010, 07:42 AM
Tally Ho!
The Netherlands
Joined Apr 2006
Ah okay !! i use clear resin which i mix with some glass fiber, but not like a thick weaved mat.
stays light and strong like that. However not on all planes mind you, the really small epo eps foam planes i dont use it on cuz of weight ratio.
KM
Old Apr 05, 2010, 08:07 AM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
If you can get .5oz f/g cloth by you, try it... you'll like it At .5oz for the entire yard (3' x 3') there would be little added from resin alone and this amount should be enough to cover a 1400mm bird like this one.
I can't wait to see this one. I love my Parkzone Corsair and the step up in size is going to be nice!
Old Apr 05, 2010, 08:10 AM
Tally Ho!
The Netherlands
Joined Apr 2006
Thanx, ill try to find some !!
Indeed the corsair is on my wish list too, i wanted a new one after crashing my FSK f4-U...
And this size might even allow for a folding wing mod.... who knows !
KM
Old Apr 05, 2010, 08:17 AM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
That would be cool. I need a machine shop The fold up part would be easy enough, heck until I added carbon to the mustang it was trying to fold the wings up... in flight!
Old Apr 05, 2010, 08:37 AM
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Nice for a foam 40 size corsair, but aside from maybe easier to repair then balsa, I dont need one as Ive got both the Kyosho 40 size Corsair with fiberglass fuse/center wing and the H&M Performance Corsair.
Ive not built the H&M one yet, but the Kyosho is a great flier. Too bad they stopped making them because it flies better the most 60 size planes even though it weighs the same as a 60 size.
I did find a listing for a kyosho corsair on ebay. Grab it while you can cuz you probably wont see another one for a long time if ever.
http://cgi.ebay.com/Kyosho-F4U-Corsa...item20b04faa27
kahloq is offline Find More Posts by kahloq
Old Apr 05, 2010, 08:46 AM
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
MYC why do you say EPS??? I wouldv'e thought EPO would be just as easy to glass
Old Apr 05, 2010, 09:09 AM
zup
United States, PA, Oakdale
jbc
the EPO would have to be filled in with featherweight spackling compound thinned with water and sanded down before applying the fiberglass and expoy.
zup
zup is offline Find More Posts by zup
Old Apr 05, 2010, 09:12 AM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
EPO doesn't sand as well as EPS and as such the texture tries to show through the glass. Also, the z-poxy doesnt seem to stick as well either. Oh, and EPS is lighter to start with...
AND I was beaten to the answer by Zup
New Product Giant FMS EPO P-51.....NICE kydawg1 Electric Warbirds 16797 Today 06:48 PM
Discussion FMS/Airfield Giant P-47 EPO 1400mm Warbird jbc Electric Warbirds 3599 Yesterday 01:28 PM
New Product New Giant FMS EPO BF 109 fletchace Electric Warbirds 20 Nov 23, 2010 07:53 PM
Discussion Chance Vought Giant F4U Corsair Brian Coleman Giant Scale Airplanes 4 Nov 14, 2006 04:38 PM
Discussion Giant scale F4U Corsair Brian Coleman Giant Scale Airplanes 12 Sep 27, 2006 05:52 PM
