Old Apr 04, 2010, 08:17 AM
kylevn is offline
Find More Posts by kylevn
Joined Dec 2007
Seawind parkflyer ( plan and model)
Hi everyone!
I have got a opportunity to share my design's plan by Icon_A5 http://www.rcgroups.com/forums/showthread.php?t=1211295
That is my'second bird, my first project is The Seawind, and today I wanna share with you :
Seawind come with 2 option:
- wing can remove :http://www.megaupload.com/?d=UPB59JWK (PDF file)
- fix wing : http://www.megaupload.com/?d=O41YCBOP (PDF file)
- Assemble drawing : http://www.megaupload.com/?d=O41YCBOP
The Seawind with wing can remove is a plan delivery because I must ship this airplane for my friend. If don't like to transport , fix wing is a better choice.
there are some spec and imagine of her:
Spec:
Wing span: 1000mm
Length: 890 mm
Weight RTF:520-550 gram
Wing area: 16 sq.dm
Wing loading: 32,5-34,4 gram/sq.dm
Electric:
- Motor 1400kv + prop APC 8x6 or Motor 2200kv + prop 5030x3
- ESC 25-35A
- Battery: 1500 -1800mah
- Futaba 10c with ASSAN module
Control:
- Ailerons
- Elevetor
- Rudder
Some pic of real plane: http://www.youtube.com/watch?v=pUETk...eature=related
and model:
and she fly
I'll post step by step contruction and more clip late!
Nguyen Long
kylevn is offline Find More Posts by kylevn
Old Apr 04, 2010, 08:27 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
kylevn, that looks really nice!
leadfeather is online now Find More Posts by leadfeather
Old Apr 04, 2010, 08:53 AM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Looks a little bit like Polaris... Nice.
LittleG is offline Find More Posts by LittleG
Old Apr 04, 2010, 09:28 PM
Russ40 is offline
Find More Posts by Russ40
Fort Smith Ar
Joined Oct 2005
Looks great. Can;t wait for the plans. Thanks
Russ40 is offline Find More Posts by Russ40
Old Apr 04, 2010, 11:04 PM
cubbuddy is offline
Find More Posts by cubbuddy
United States, CO, Craig
Joined Apr 2010
I will watch for plans... Looks like great fun!
cubbuddy is offline Find More Posts by cubbuddy
Old Apr 05, 2010, 06:23 AM
m25 is offline
m25
Find More Posts by m25
m25
m25's Avatar
Joined Oct 2009
Very clean and relatively easy build, that prop looks a bit small though and the mounting is big enough to obscure a lot of air flow, can you try something bigger?
m25 is offline Find More Posts by m25
Old Apr 05, 2010, 08:26 AM
kylevn is offline
Joined Dec 2007
thanks for your idea!
you can fly with 2200kv motor and 5030x30 prop, I had been fly with them! but it is not a best setup because the out put just 80-85%( I think) cause the necelle scale (don't have the nose of prop)
If you are pay attention seawind fly image. you can see longer prop because I use 1400kv with APC 8X6, a litter bit slower but she fly ok!
Old Apr 05, 2010, 08:53 AM
rshep is offline
Find More Posts by rshep
crashology student
Ontario, Canada
Joined May 2008
kylevn ... any chance you could provide a pdf (if/when you get time). I cannot open the DWG with anything I have.
I fly the Seawind EP but find it a little fast for my aged reflexes but yours has only about 2/3 the wing loading - which will be more comfortable for my internal CPU. ... Bob
rshep is offline Find More Posts by rshep
Old Apr 05, 2010, 09:27 AM
kylevn is offline
Joined Dec 2007
there are some image:
printed the plan:
start with vertical tail:
Finish but not yet sanding
the second is main fuselage
Two side of the main fuselage ,
nacelle:
use heat gun to bend the bottom nacelle fix with nearly vertical tail
Sanding the vertical tail :
install bottom nacelle plane and try to fix with main fuselage
After glue servo with 50cm wire:
The plane is very easy to build because everything can fix together with the support of dap!
Old Apr 05, 2010, 09:48 AM
kylevn is offline
Joined Dec 2007
the PDF file is in the first post! You can download there
Old Apr 05, 2010, 11:18 AM
Russ40 is offline
Fort Smith Ar
Joined Oct 2005
Good pics. Looks like it will be a fun build.
Old Apr 05, 2010, 03:17 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Great looking plane Nguyen! This would be fun to build and fly!
Can you post a video of it flying from and landing on water?
DaDesign is offline Find More Posts by DaDesign
Old Apr 06, 2010, 04:01 AM
kylevn is offline
Joined Dec 2007
I thinks so, they are the same structure ! I like the Polaris of Steve Shumate so much! that is a perfect plan.
Old Apr 06, 2010, 04:42 AM
kadil is offline
Find More Posts by kadil
unconventional :-)
kadil's Avatar
Brisbane north, Australia
Joined Feb 2009
Looks great, I have a scratch polaris, this also looks very interesting!!
It looks like no camber in the wing, can I ask why? Would you think an airofoil whin would be beneficial?
Regards,
Kim
kadil is offline Find More Posts by kadil
Old Apr 06, 2010, 07:26 AM
kylevn is offline
Joined Dec 2007
@Kim:
My first Seawind is a wing with airfoil and hieral, but I can't feel the different between them ???
Maybe some mistake from me! I'll try to correct and test again!
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
Discussion Free Plan - 1930's Burd Models "Sky Burd" rubber model planeman Free Flight 7 Nov 17, 2009 07:30 PM
Discussion How to derive a model plan from Metasequoia 3D model? Bugger Simulators 3 Mar 21, 2006 03:33 AM
FS - Plan and Templates PinkStar: SturdyBoard Pattern ParkFlyer MartinChou Aircraft - Electric - Airplanes (FS/W) 37 May 28, 2005 11:35 PM
Cool SturdyBoard Pattern ParkFlyer - Great flying (Free plan!) MartinChou Foamies (Kits) 21 Feb 29, 2004 11:36 AM
