Old Apr 04, 2010, 07:23 AM
greentigermoth is offline
Find More Posts by greentigermoth
Joined Jan 2009
Problem with lost phase on brushless motor
Can anyone help me please?
I recently had ongoing problems with continually losing one phase on my brushless motor, I took it apart, resoldered on the lead and it worked, however midflight the problem reocurred. I took it apart several times repairing it, and the leads have falled apart, now after two leads came adrift, and I cannot find where to resolder the leads, I am have soldered on new leads, but the motor tries to go forward and backwards and will not start, when it did start once, it squealed then some smoke appeared. How do I determine where to solder the leads back on, do I do some unwinding and locate the winding twist and solder onto these, the motor does not have a brand on it, it has 12 posts of winds. Could part of the problem be that I made the new leads much longer?
Please help, Mark!
greentigermoth is offline Find More Posts by greentigermoth
Old Apr 04, 2010, 07:31 AM
imyohero is offline
Find More Posts by imyohero
F-OFF
imyohero's Avatar
Joined Mar 2007
Sounds like a burnt phase, probably time to rewind or replace.
Since you had smoke we know the windings over heated and burnt off the coating on the wire.
Shane.
imyohero is offline Find More Posts by imyohero
Old Apr 04, 2010, 08:12 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
If you keep running the motor with a bad phase you risk burning out your speed control.
As above: Rewind or replace.
Any time you let out some magic smoke its done.
going4speed is offline Find More Posts by going4speed
Help! Problem with EMAX HL2215 450 Brushless motor coeprobotics Electric Motor Design and Construction 5 Apr 03, 2010 11:26 PM
Discussion Problem with EMAX HL2215 450 Brushless motor coeprobotics Large Electric Helis 2 Apr 03, 2010 01:41 AM
Help! Problem with EMAX HL2215 450 Brushless motor coeprobotics Electric Heli Talk 1 Apr 03, 2010 12:30 AM
Help! Problem with EMAX HL2215 450 Brushless motor coeprobotics Multirotor Talk 0 Apr 02, 2010 04:02 AM
Help! Problem with EMAX HL2215 450 Brushless motor coeprobotics Beginner Training Area (Heli-Electric) 0 Apr 02, 2010 02:36 AM
