Old Apr 03, 2010, 05:17 PM
Extremeflyer is offline
Find More Posts by Extremeflyer
Extremeflyer's Avatar
United States, CA, Rancho Cucamonga
Joined Feb 2009
Question
Fiberglass Or Liquid Sheeting Over EPS Foam?
Okay, I have posted a similar thread like this in painting and finishing tips and thought I'd try my luck here in foamy EDFs as well. I've just recently purchased the 90mm Fly Fly F-86 Sabre kit, and out of the box it looks pretty good. However, I am concidering on going the extra mile here and try improve the looks by trying fiberglass/epoxy resin or a product by Wowplanes called Liquid Sheeting. I have no experience with fiberglass or the product Liquid Sheeting. One thing that I do not wish to remove are the original panel lines that are on this model. Any helpful advice would be greatly appreciated
Extremeflyer is offline Find More Posts by Extremeflyer
Old Apr 03, 2010, 05:23 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Have you seen this thread?:
http://www.rcgroups.com/forums/showthread.php?t=779470
I saw this one at a club meeting - it looked great:
http://www.rccanada.ca/rccforum/showthread.php?t=98895
He did the glass / wbpu method.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Apr 03, 2010, 06:15 PM
Joined Feb 2009
Yes pmackenzie I have in fact read the Fly Fly F-86 build thread. And some of the builds have turned out awesome! I'm still wondering if I should just leave mine alone and apply the decals, or try and fiberglass it.
Old Apr 04, 2010, 12:20 AM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
I never glassed a model until I tried it on a FlyFly Mirage. I first filled in the deep panel lines with light weight spackle. Then I sanded all the parts. I have small cups that I mix 1 part resin. 1 part hardener and 1 part rubbing alcohol to thin. I used .56oz Sig fiberglass cloth and Zpozy finishing resin. I cut the cloth to shape then used a brush to dapple on the resin in the corners of the cloth to get it to stay in position. Then lightly brush on the resin starting in the middle and working out toward the edges. I have some Glad plastic containers that are filled with rubbing alcohol. I use one to wash my fingers if I get any resin on them and the other to clean the brush. Once the panel is covered I then scrap off the excess resin with a credit card. Then I roll toilet paper on the panel to absorb more resin. I let it set overnight. Then I sand the edges and lightly sand the panel. I apply WBPU on the panel next and let it set overnight. Once the whole model is completed then spray with automotive primer (Rustoleum). Then sand with 320 and 400 grit sandpaper. Any thin spots just fill in with light weight spackle. Then paint. It's no worse than applying iron on covering.
Kelvin
kelvin is offline Find More Posts by kelvin
Old Apr 04, 2010, 06:11 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Instead of scraping with the credit card and then using toilet paper, I just warm the resin with a heat gun, once it is spread out on the glass cloth, then use heavy duty paper towels to soak up the excess resin.
Pinecone is offline Find More Posts by Pinecone
Old Apr 04, 2010, 11:42 AM
Joined Feb 2009
Kelvin
Hey Kelvin, first let me start by saying that Mirage looks great! And it was your first glassing and foamie good job. One of the things that I wanted to try and keep on this model is the panel lines if possible. And it looks like when you glass, you lose them. How about the weight gain after glassing? Did you notice a big difference in weight gain? Also is it difficult to cover the fuselage and areas that are not flat?
Old Apr 04, 2010, 08:16 PM
kelvin is offline
Joined Jan 2002
I was going to draw on panel lines. The panel lines in these foam models are to wide and deep. It would be hard to get the glass into the lines. The extra weight wasn't too much, less than 4 oz for this size model for glass, resin, primer and paint. It sure made the model very resistant to hangar rash. Every time I pick up a foam model I leave finger nail dents. My FlyFly Mirage Fuselage and wing when glassed weighed 2lbs. This included balsa ducting, battery tray, nose gear and main gear retract mounting blocks in the fuselage.
Covering curves is harder. I used several pieces for some curves like the nose. Then you sand lightly to blend them in. I'm no where near being an expert at this. If you can cover a model with plastic iron on covering and come out with a respectable finish then you can glass. The Zpoxy is about $14 - $20 depending where you buy it and fiberglass cloth can be up to $20 for a 6 foot length so it can get expensive to cover one of these large jets.
Kelvin
Old Apr 04, 2010, 10:29 PM
Joined Feb 2009
Yeah Kelvin, the total process to fiberglass a model does seem like a little bit of work. However the finished product does look good. One of the main things that I do not like about the styrofoam EDF jets is the fact that the surface is pretty delicate. On the flip side, they are easy to repair in the event of a crash. Oops, did I just say the C word I guess that you can't have the best of both worlds with a foamy.
Question Liquid Sheeting On Styrofoam Extremeflyer Painting and Finishing Tips 22 Mar 29, 2015 12:22 AM
Discussion Styro Spray, Liquid Sheeting philba The Builders Workshop 1 Dec 16, 2009 12:56 PM
Help! EPS core, fiberglass, sheeting ajroahkni Slope 3 Aug 11, 2006 03:06 AM
fiberglass covering over balsa or foam jsomers1234 The Builders Workshop 1 Nov 14, 2002 01:34 PM
composite hollow fiberglass wing vs. fiberglass over foam wing? ChrisFeole Power Systems 7 May 21, 2001 02:33 AM
