Old Feb 26, 2011, 09:27 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
OK, I should have been clearer.
The risk is if you connect the positive WITHOUT a negative connection that is complete. This would happen if (for example) you use the supplied banana leads, plug the positive in before the negative AND the USB circuit to the PC is in place. The diagram in the Help section of the software explains.
With Deans or similar, the same thing can happen if you connect a live PS to a charger AND the positive pin connects before the negative one when you push them together. Again only if you have a complete USB connection as well.
Bottom line - connect the Deans THEN power up.Both the negative and positive parts of the circuit are complete before you apply the juice and there is no issue.
As an alternative, just for convenience I added a 40A automobile accessory switch in the positive line to the charger. It's handy to be able to turn it on and off without switching off the Power supply. The negative circuit is never disconnected.
John
Originally Posted by baratta930 View Post
What do you suggest if I plan to connect to a PC? Switch to bullets on my supply?
If I connect the charger to the power supply and then connect the USB cable to the computer and then turn on the power supply will that be ok?
thanks,
Berardino
jj604 is online now Find More Posts by jj604
Old Feb 26, 2011, 09:50 PM
baratta930 is offline
Find More Posts by baratta930
United States, IL, Carbondale
Joined Jun 2005
John
Ok, so I think I'm fine then but let me say it out loud (ok written down) just so you guys can confirm this is ok.
The following assumed Deans connectors. Also I'm using a PC.
1) Connect my power supply and charger together (both +ve and -ve connect at once). (I leave it always connected so this is a given).
2) Power on my charger (i.e. turn on the power supply)
3) Plug in the USB cable into the charger and PC
4) Launch the control software on the PC and enjoy
Is this ok? Would hate to fry this charger the first day I get it
Berardino
baratta930 is offline Find More Posts by baratta930
Old Feb 27, 2011, 05:23 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Berardino, that will work just fine. I had sometimes to power off the PS and power it up again (that is restart the Charger) to get the software to recognize the USB port in early days but I have a feeling Mr Mel fixed that particular behavior.
By the way - it isn't the Charger you will fry in any case. It would be the USB circuitry in your PC.
John
Berardino
Old Feb 27, 2011, 10:29 AM
JohnWilliamson is offline
Find More Posts by JohnWilliamson
Joined May 2010
Screenshot... http://www.wheelchairdriver.com/desk.jpg Excuse the size I got another new monitor! Scroll!
Every time I charge this 13 cell pack here http://www.wheelchairdriver.com/BM-M...powerchair.htm
Scroll again, to see the size of the thing!
I get output voltage 0.000v on the software. And a strangely HUGE M/Ohm figure like 53247... The charger itself reads correctly. Both voltage and 12 M/Ohm or whatever.
JohnWilliamson is offline Find More Posts by JohnWilliamson
Old Feb 27, 2011, 10:37 AM
MrMel is offline
Find More Posts by MrMel
Electric Helis is my game
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
I'm out travelling, but I seriously doubt it's the chargers itself, you have driver problem as you posted before.
Same thing corrupts the data is my guess (and crashing/BDOD you computer)
USB communication in those chargers are not very complex, when you connect a new charger = windows re-loads stuff, so changes are THAT's whats fixing it rather than the new charger itself.
Test first powering the charger by one of your 12v batteries.
To know exactly what happens I need to get debug info, but I'm away for 2 weeks now.
MrMel is offline Find More Posts by MrMel
Old Feb 27, 2011, 01:57 PM
Joined May 2010
repeat
Old Feb 27, 2011, 02:00 PM
Joined May 2010
BUGs??
Old Feb 27, 2011, 08:47 PM
Joined Jun 2005
John
Frying my PC would suck even more
Thanks, my charger should be here tomorrow or Tuesday. Can't wait to play with it
Berardino
Old Feb 28, 2011, 03:44 PM
Joined May 2010
When charging, discharging or balancing a 13 cell pack there is no "output voltage" it just reads zero.
And likewise m/Ohms is either a very big number or 1.
Every time.
The graph displays pack voltage correctly with or without balancer. The charger displays volt correctly too. Its just in the Suite.
Screenshot if needed.
Last edited by JohnWilliamson; Feb 28, 2011 at 03:45 PM. Reason: Added I forgot I already posted this!
Old Mar 01, 2011, 05:54 AM
Fastredrover is offline
Find More Posts by Fastredrover
Fastredrover
Fastredrover's Avatar
Australia, NSW, Coffs Harbour
Joined Jun 2010
Burnt USB
Hi there.
I have managed to burn out the USB on my
new EOS0615i charger and notebook which was powered from house supply.Both charger leads were connected to the power supply at the time as per Hyperion's instructions.I was very aware of what I had to do.
The power supply is Maxamps's 24V.
http://www.maxamps.com/Power-Supply-24V.htm
I assume it is the same as this,
http://sites.google.com/site/tjinguy...ts/diy-24v-47a
or this
http://www.rcgroups.com/forums/showthread.php?t=1164359
I am yet to check but I don't think they insulate
the outer case of one supply like feathermerchant dose
When I check for a voltage from either + or - on the DC power supplies leads to house ground I get 12V, just polarity swaps.
Do you think this has caused the back flow through the USB's?
Maybe I need to insulate the outer case of a supply or float the DC-.
Thanks in advance.
John
Fastredrover is offline Find More Posts by Fastredrover
Old Mar 01, 2011, 07:55 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Ontario, Canada
Joined Apr 2010
Originally Posted by Fastredrover View Post
I am yet to check but I don't think they insulate the outer case of one supply like feathermerchant does. When I check for a voltage from either + or - on the DC power supplies leads to house ground I get 12V, just polarity swaps.
I think that's exactly what happened. The charged tried to ground itself through the USB port.
I have to check, but IIRC my 24VDC 350W Meanwell PS has the -V attached to chassis ground... which is connected to the center prong on the 120VAC plug.
philipa_240sx is offline Find More Posts by philipa_240sx
Old Mar 02, 2011, 04:35 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
This looks like a fairly dodgy implementation of the two-in-series supply solution to me. They fact they say it doesn't matter which power cord goes to which supply is a bit of a worry.
These MUST be insulated or they wouldn't work but what the resultant effect on a USB connected circuit is could be anything depending which way the power cords are plugged in. You might want to read the thread on connecting two in series if you want to understand some of the possible issues. Certainly my advice is that the grounded power PS must be the one that outputs the 0V side of the DC out.
http://www.rcgroups.com/forums/showt...170241&page=29
and particularly Post# 183 of the thread.
John
Hi there.
or this
Thanks in advance.
John
Old Mar 06, 2011, 06:44 AM
Joined May 2010
My benchtop power supply has 3 out terminals. NEG (Black) Earth (green) RED (pos)
Its 24v and 40 amp output. Adjustable.
So presumably the output is floating. And the EARTH is tied to mains earth.
Is it better to link the earth and the neg? Or just use it as I am doing now? (floating) Which is safer?
I would have thought that floating was safer. Not so sure now! I am already having USB problems although no blown ones due to this issue (yet)...
Old Mar 06, 2011, 08:23 AM
Joined May 2010
OK Heres what me and my old sillyscope found.
When charging from a battery (24v in this case) or a quality 40 amp 30v FLOATING power supply, I was getting connectivity, and noise problems (resulting in lost USB connectivity) regularly. And sometimes not found problems. Difference between the floating neg voltage and the wall Earth (pc) on the power supply was regularly 2 noisy volts...
Earthing the Power supply negative, ~(and doing the same from a battery power supply) cured the problem totally on two chargers. They behaved worse when charging 13 or 14 cells at fulll 550 watts. The noise seemed to be the charger itself. Very short power leads helped. Long extended oned made it worse as mine were. Earthing the negative cures it. But leaves you open to possible earth loop issues so back to being careful again!
Old Mar 08, 2011, 02:46 PM
mlprater is offline
Find More Posts by mlprater
Joined Mar 2011
+1 on the series power supply problem. 720 SDUO / SiLabs 6.1.
HP DPS-600PB supplies. Hooked in series, with the case/ground floating on the first supply in the series. That's it - I've yet to fit it with capacitors or diodes. Still kind of researching the best way to do that.
Dell Latitude D600 notebook. Detects charger when AC on the notebook is unplugged, can't detect it when it is plugged in. Ferrite core on the USB didn't work.
Great thread! I eagerly anticipate a resolution. Until then, I guess I'll be buying a new notebook battery.
mlprater is offline Find More Posts by mlprater
Discussion Availability of Hyperion EOS 0720i NET3 ? Pull-Up Batteries and Chargers 23 Mar 29, 2010 02:16 PM
For Sale Hyperion EOS 7I Charger Robert Burson Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 20, 2010 03:17 PM
Discussion Hyperion EOS 0606i bighead93 Batteries and Chargers 3 Mar 01, 2010 07:26 PM
Discussion Data logging dont work on firware 3.00 beta alah Castle Creations 4 Nov 15, 2009 11:30 AM
Discussion Hyperion EOS DUO-NET Beta logging Software NipponDave Batteries and Chargers 83 Dec 01, 2008 12:07 AM
