Old Apr 10, 2010, 05:39 AM
MrMel is offline
Find More Posts by MrMel
Electric Helis is my game
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Which charger do you have?
Have you limited the correct input voltage/amp in the UserSetup? It might have cleared when you updated the firmware and the low voltage trips the error.
MrMel is offline Find More Posts by MrMel
Old Apr 11, 2010, 03:12 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
I've uploaded version 2010-04-11 RCG-BETA with the following changes;
-- 2010-04-11 RCG-BETA
* Added check on Control Charger function that only 20 memories will be loaded, and in sequence.
* Added Amps vs Time in the Statistics window.
* Added Amps vs Capacity (mAh) in the Statistics window.
* Changed Safety timer under Memory setup to Zero actually becomes OFF
* Channel number should now be correctly named in the Alarms (was +1)
/Fredrik
Old Apr 12, 2010, 10:10 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Thanks Fredrik, I will install the latest update this evening.
Ohmic is offline Find More Posts by Ohmic
Old Apr 12, 2010, 11:41 AM
Doffen24 is offline
Find More Posts by Doffen24
Doffen24's Avatar
Norway
Joined Sep 2008
/Fredrik
Great.
Startet testing today. Many errors gone.
is there any posibilities to show these Amps graph In real time.
Even better in the same graph as cell voltage vs time.
Best regards
JE
Doffen24 is offline Find More Posts by Doffen24
Old Apr 12, 2010, 03:51 PM
Ohmic is offline
USA
Joined Jan 2002
I just installed the latest version.
The online help issue I had encountered is now working. Previously clicking on Online help was causing an error message in the browser and not taking you to the on-line help. That issues is now resolved.
Old Apr 12, 2010, 04:00 PM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
What is new in the 4.1 firmware? I'd like to know this before giving it a try.
3Dmuse is offline Find More Posts by 3Dmuse
Old Apr 12, 2010, 04:09 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Sorry, I do not have a complete list as I has only written the Control & Data suite, Dave has to answer that one.
what I do know of is lots of changes regards to PB charging and changes to sound/melody.
Old Apr 12, 2010, 04:12 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
I've looked into it but it's tricky, the Graph in the logviewer is dynamic since you have different chargers with different cell count, It's possible but might require quite a lot of changes, will see if I can find an easy way to do it without disturbing the rest of the dynamic stuff, else I have to say no for now.
Old Apr 13, 2010, 05:09 AM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
First, 4.1 or higher is required in order to use the PC Control & Data Suite
Beyond that, these are the main changes:
* PB adds Terminal Voltage Control, to allow tuning for various PB battery types (wet vs gel vs agm, etc).
* PB adds FLOAT VOLTAGE setting which allows the charger to be continuously attached to PB while maintaining the FLOAT VOLTAGE setting (when/if battery voltage falls a predetermined point below FLOAT, after charge completion). SAFETY Timer must be set OFF to allow this.
* Some LCD screens have been changed to make them more consistant and easily understood
NipponDave is offline Find More Posts by NipponDave
Old Apr 13, 2010, 07:26 AM
3Dmuse is offline
Ontario, Canada
Joined Sep 2009
Dave & Frederik, many thanks for your answers.
Old Apr 13, 2010, 08:00 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Cheers MrMel, looks like you were on the money with the power supply max current user Setup
jackosmeister is online now Find More Posts by jackosmeister
Old Apr 13, 2010, 09:30 AM
Ohmic is offline
USA
Joined Jan 2002
Dave, I see it has the float voltage now and was wondering if this means it's now a complete three stage Pb charger with bulk, absorption, and float modes?
Old Apr 13, 2010, 01:31 PM
Hans Meij is offline
Find More Posts by Hans Meij
Joined Feb 2005
Hyperion team, thanks, the update worked, the control suite works fine.
Hans Meij is offline Find More Posts by Hans Meij
Old Apr 14, 2010, 03:39 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
I've sent up a new version.
-- 2010-04-14 RCG-BETA
* Fixed a bug in the graph (logviewer) for 7-14 cells
* Fixed a bug in the memory editor when using more then 6s NiMh packs.
Old Apr 14, 2010, 03:51 PM
Doffen24 is offline
Doffen24's Avatar
Norway
Joined Sep 2008
I was a little late on testing on the previous version 2010-04-11. Maybe these errors still appear, they were not mentioned here.
Best regards
JE
Discussion Availability of Hyperion EOS 0720i NET3 ? Pull-Up Batteries and Chargers 23 Mar 29, 2010 01:16 PM
For Sale Hyperion EOS 7I Charger Robert Burson Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 20, 2010 02:17 PM
Discussion Hyperion EOS 0606i bighead93 Batteries and Chargers 3 Mar 01, 2010 06:26 PM
Discussion Data logging dont work on firware 3.00 beta alah Castle Creations 4 Nov 15, 2009 10:30 AM
Discussion Hyperion EOS DUO-NET Beta logging Software NipponDave Batteries and Chargers 83 Nov 30, 2008 11:07 PM
