Old Apr 02, 2010, 06:20 AM
MrMel is offline
Find More Posts by MrMel
Electric Helis is my game
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Hyperion EOS Control & Data Suite - Public Release.
Hyperion Control & Data suite program for the EOS line of chargers.
First of all, the manual can be found here;
http://media.hyperion.hk/dn/pc/ecds-man
It's recommended that you read the "Before you start part";
http://media.hyperion.hk/dn/pc/ecds-...reyoustart.htm
This program require Firmware version 5.0 (or later)
Visit the EOS CHARGER Firmware Update site for the newest version:
http://media.hyperion.hk/dn/pc/eosfw.htm
Finally, the Control & Data Suite program can be found here;
http://media.hyperion.hk/dn/pc/ecds-man/Installer.zip
Current version is: 2011-05-25
This program has a requirement of .NET Framework 3.5
If your computer is not updated this component need to be updated from Microsoft.
http://www.microsoft.com/downloads/d...displaylang=en
For any of you running more then one charger connected to the same computer, READ THIS BEFORE YOU START!
http://media.hyperion.hk/dn/pc/ecds-...rechargers.htm
Note: If you have trouble with SiLabs driver for the chargers, the latest version can be found here;
http://www.silabs.com/products/mcu/p...cpdrivers.aspx
The program will automatically check both Firmware and Software version at startup, if there is a new version you are prompted to do a re-install/update.
/Fredrik
** Known issues
MrMel is offline Find More Posts by MrMel
Last edited by MrMel; May 25, 2011 at 03:31 AM. Reason: Change of version number & update of links.
Old Apr 02, 2010, 06:28 AM
Tyro is offline
Find More Posts by Tyro
Tyro's Avatar
Adelaide , South Australia
Joined May 2005
Thank you VERY much , i've been waiting for this. Happy Easter to all at Hyperion!
Tyro is offline Find More Posts by Tyro
Old Apr 02, 2010, 10:56 AM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
Great news. I have a question about the new software, do we still need to install a USB driver?
3Dmuse is offline Find More Posts by 3Dmuse
Old Apr 02, 2010, 10:58 AM
proublot is offline
Find More Posts by proublot
French
Joined Apr 2004
It's good for me,
my Hyperion 720iNET and Hyperion Duo 610i II passed in firmware v4.1.
Good job to Hyperion,
Pascal.
proublot is offline Find More Posts by proublot
Old Apr 02, 2010, 10:59 AM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Yes, you need to have SiLabs USB driver installed for it to be able to communicate with the charger, the latest version can be found here;
Old Apr 02, 2010, 11:08 AM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
I have added a "known issue" list to the first post, so you don't have to report any of those issues there.
Old Apr 02, 2010, 02:24 PM
prozac is offline
Find More Posts by prozac
prozac's Avatar
USA, TX, Grapevine
Joined Sep 2008
So far so good. Hooked up my brand new DuoIII and watching a 4s 4000 pack do a storage charge now. No problems on my end. I like that you can label each battery memory spot and set the parameters.
prozac is offline Find More Posts by prozac
Old Apr 02, 2010, 02:25 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
a tip is to name your packs in the beginning, and stick to that naming, that way you can get a full history for just that pack after the season or whenever you want.
Old Apr 02, 2010, 02:53 PM
prozac is offline
prozac's Avatar
USA, TX, Grapevine
Joined Sep 2008
Now I'm pissed. Second pack ever to be run through this charger and the charger starts blowing smoke out of the back of the unit. It is a damn good thing I was sitting here watching it. W T F !!!!!!!
Old Apr 02, 2010, 02:55 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Ugha, sorry to hear that must have been something faulty in that unit, post over in the EOS thread and Dave will take care of you ASAP.
Old Apr 02, 2010, 05:16 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Very cool, the memory editor seems to have a few a bugs though, it would not update the charger to a 2S Life pack in position 2, no matter how many times I tried, it stuck at Life 13.2V 2300. Ende up doing it manually in the charger and it seems to have stuck.
Somehow I also managed to get the first 12 batteries names to be randomly attached to all the memory postions, but the battery data remaind the same, So I had Nimh packs being called lipos. Kinda dangerous
jackosmeister is online now Find More Posts by jackosmeister
Old Apr 02, 2010, 05:58 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
anyone running this software with the original DUO
gww528 is offline Find More Posts by gww528
Old Apr 02, 2010, 06:19 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Anything similar for the 0610iNet chargers?
Duster_360 is offline Find More Posts by Duster_360
Old Apr 02, 2010, 09:22 PM
MrMel is offline
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Any chance that you have set the charger to temperature F?
Memory name is not stored per memory number but by a Key of Type, cells, size, chargerate together, I suspect in your tries to get the 2s to stick, that got updated.
If you did not run Fahrenheit, please PM me with more details.
I have a original Duo which I have tested it with, you get Logging part (not bi-directional functions) only, but logging with tagging and alarms.
Old Apr 02, 2010, 09:39 PM
Auckland NZ
Joined Aug 2007
Mr. Mel , nope didnt change it from celsius, It didnt seem to screw up the memory data until I went to the control function section. But #2 slot position wouldnt save to the charger from the first time I started the program, and the memory editor was the first thing I did with the program.
Is there anyway of simplifying the alarms? Ie instead of reading the whole "COM5/Hyperion 610i DUO2 on channel 0" Which turns into a garbled mess in text to speech, where as something like "Duo 2 channel 0" would be much simpler.
Some good qoutes to replace the warnings, My Duo2 is now a HAL9000
"I am putting myself to the fullest possible use, which is all I think that any conscious entity can ever hope to do. "
"Dave, this conversation can serve no purpose anymore. Goodbye. "
"I know that you and Frank were planning to disconnect me, and I'm afraid that's something I cannot allow to happen. "
"I know I've made some very poor decisions recently, but I can give you my complete assurance that my work will be back to normal. I've still got the greatest enthusiasm and confidence in the mission. And I want to help you."
Im a geek!
Discussion Availability of Hyperion EOS 0720i NET3 ? Pull-Up Batteries and Chargers 23 Mar 29, 2010 01:16 PM
For Sale Hyperion EOS 7I Charger Robert Burson Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 20, 2010 02:17 PM
Discussion Hyperion EOS 0606i bighead93 Batteries and Chargers 3 Mar 01, 2010 06:26 PM
Discussion Data logging dont work on firware 3.00 beta alah Castle Creations 4 Nov 15, 2009 10:30 AM
Discussion Hyperion EOS DUO-NET Beta logging Software NipponDave Batteries and Chargers 83 Nov 30, 2008 11:07 PM
