Apr 19, 2010, 01:06 AM
tehachapi, CA
Joined Jan 2006
not really.....the larger inlet only means more drag. sure, it helps on takeoff....after it gets up to speed....it turns into more drag. yeah, the alfa mig is faster than the alfa sabre....why? because the inlet on the alfa sabre is rediculus. airframe wise, the sabre has more sweep angle, and rudder is far thinner and smaller, the fuse is more sleek, not being as "fat" as the mig. theres a reason the rael sabre was faster than the mig at high alt. its a much larger jet in full size than the mig as well. the small inlet is doing it only good in this case...a new way of thinking, and it works. case in point, jhh cougar...150mph with 120% FSA. jhh F-86, 160+ with 75% FSA. same exact power plant. now i know you cant compare them 100% because its not the same airframe, but weve seen this time and time again with the higher power setups. now...if your talking differance at say, 500W....yeah, more might be better...thats because the model cant reach the speed required to help overcome the small inlet.
Originally Posted by flamehead
Well. the real MIG had a bigger inlet than the Sabre of course, which means it works even better as a model without cheater holes. If E-Flite made a MIG with the same powertrain as the Sabre it would probably have a 10mph speed advantage. You're right, I hope they make one!
