Old Apr 02, 2010, 01:46 AM
TexasThermalKing is offline
Find More Posts by TexasThermalKing
TexasThermalKing's Avatar
Angleton, Texas
Joined Mar 2007
Airtronics RF radio module question on pins.
Does anyone have the schematic of what each pin, located on the 72 mhz Airtronics plugin modules is linked to? I have a Vision 8SP radio I was looking to convert to 2.4 ghz. It uses the TX RF Module #93782.
If you have suggestions on a good way to convert it, please let me know.
If you are using a particular 2.4 system...let me know what you like about it.
Thanks !
TexasThermalKing is offline Find More Posts by TexasThermalKing
Old Apr 02, 2010, 09:22 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
I've only done some limited research, but the generic 2.4 modules that I've found connect to the trainer port. If the Vision has one, it should be fairly easy to determine the pinout.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Apr 02, 2010, 10:30 PM
Angleton, Texas
Joined Mar 2007
No tranier port on the Vision 8SP.
Tim, Thanks for your response...but the Vision 8SP has no trainer port. I'm
I'm trying to figure out the pins functions...so I can use a 2.4 ghz board, or hack module to see if I can get up on 2.4ghz.
Anyone that has information on the Airtronics 72mhz plug in modules, would be appreciated.
Old Apr 30, 2010, 04:27 PM
Angleton, Texas
Joined Mar 2007
Update...found pin locations for Vision 8SP radio.
Working with the FrSKY 2.4 hack module, that I used to convert my Airtronics Vision 8SP radio....I found the positive, negitive, and PPM pin locations I needed on the XPS website. Thanks XPS, I appreciate your detailed help!
Wanted Futaba 9c rf synthesized rf module jazzmanb Aircraft - General - Radio Equipment (FS/W) 1 Mar 11, 2010 12:10 AM
For Sale AIRTRONICS Stylus RF Module >>SPECTRA Synthesized W/Stylus Adapter<< old_dude Aircraft - General - Radio Equipment (FS/W) 5 Dec 18, 2009 12:58 PM
Sold JR DM9 Spektrum Module, JR RF Module, Old JR Radio davidg51537 Aircraft - General - Radio Equipment (FS/W) 0 Jul 03, 2009 07:40 AM
FS: Airtronics Stylus RF Module - HAM BAND glide Aircraft - General - Radio Equipment (FS/W) 0 Feb 01, 2005 06:46 PM
