Old Apr 01, 2010, 08:08 PM
wtl0715 is offline
Find More Posts by wtl0715
United States, CA, Marin County
Joined Apr 2009
FatShark goggles question...
I apologize in advance for inundating the board with questions. I'm trying to get my setup ready for in the morning and everything seems to be out of place.
I cannot find the charger for my FatShark RCV goggles. The battery is 2s appx. 800mah. Does anyone forsee a problem with me soldering the FatShark pin connector onto another 7.4v 800mah battery for which I have a charger?
-TL
wtl0715 is offline Find More Posts by wtl0715
Old Apr 01, 2010, 08:13 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Just get the polarity right.
I think it would work though- don't see why not.
Kmart is offline Find More Posts by Kmart
Old Apr 01, 2010, 08:14 PM
wtl0715 is offline
Joined Apr 2009
You make a good point...how do I check the polarity? Both wires are black.
Old Apr 01, 2010, 09:14 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Pretty sure it's center pin positive.
And yes you can use any 2S lipo. I've got three 1000mAh 2S lipos that I use
to power my FS goggles. They're bigger than stock battery but will
still fit in the headband. They last much longer.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 01, 2010, 09:21 PM
gt35r is offline
Find More Posts by gt35r
Perth, Western Australia
Joined Mar 2006
Assuming you have a multimeter just check for continuity between the centre pin and one of the wires to find the positive.
I only get about 600mah out of the FS batt so using a bigger one is a good idea anyway.
If you have some clips for your charger output you can also charge the stock batt with those
and a pin for the hole ( I use a prop finger balancer because mine came with US charger)
gt35r is offline Find More Posts by gt35r
Old Apr 01, 2010, 09:40 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
Its center pen positive on mine. You don't need to cut the old connector off if you don't want to, its a standard connector sold in every hobby shop (2.1mm DC plug, maybe called a "TX connector"). Can use any 2S battery you want. Finally, you don't need to throw the fatshark battery away either, charge it using any unbalanced charger; the Cellpro Multi4 even has an adapter that will allow you to charge it without making a special plug.
http://www.fmadirect.com/Detail.htm?...319&section=45
(The 2.5mm and 2.1mm plugs are on either side, you can see the labels in the picture)
Acorns is offline Find More Posts by Acorns
Old Apr 01, 2010, 10:22 PM
wtl0715 is offline
Joined Apr 2009
Unfortunately, I don't live anywhere near a hobby shop and I'd like to fly tomorrow as it may be my last chance for a few days. Upon taking a closer look at the FS battery, the cord has a black wire with white stripes on it and a black wire with only a small bit of writing on it. Would it be safe to assume that the one with white stripes on it is positive?
-TL
Old Apr 01, 2010, 11:58 PM
Acorns is offline
Joined Oct 2008
No, would not be safe. Use a multimeter to see which is which.
Old Apr 02, 2010, 12:23 AM
wtl0715 is offline
Joined Apr 2009
Didn't have a multimeter, but I liked the circuit idea, so I did a redneck version of that. It worked. Thanks for the advice.
-TL
Old Apr 02, 2010, 02:45 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
If you're going to do FPV for more than one flight, you need to buy a multimeter.
It will save you hundreds of hours of frustration and potentially thousands of
dollars worth of gear.
ian
Discussion Broke Headplay goggles, should I try Fatshark? wilsonj FPV Talk 3 Mar 28, 2010 12:05 AM
Sold Sold: FatShark video goggles and TrackR1 HeadTracker Pepelatz Aircraft - General - Miscellaneous (FS/W) 3 Nov 23, 2009 01:00 PM
Discussion FS: Fatshark Goggles and TrackR1 Headtracker Pepelatz UAV - Unmanned Aerial Vehicles 1 Nov 22, 2009 09:56 PM
Discussion FS: Fatshark Goggles and TrackR1 Headtracker Pepelatz FPV Talk 0 Nov 21, 2009 09:19 PM
Discussion FS: Fatshark Goggles and TrackR1 Headtracker Pepelatz Aerial Photography 0 Nov 21, 2009 09:17 PM
