Old Apr 01, 2010, 03:14 PM
garyinpa is offline
Find More Posts by garyinpa
Philadelphia, PA
Joined Apr 2005
Question
How do I set-up differential on a Pete n Poke?
I just bought a completed Pete 'n Poke. It has a Y-harness in the wing for the ailerons. How would I set up differential without each servo being plugged into the receiver? Thanks!
garyinpa is offline Find More Posts by garyinpa
Old Apr 01, 2010, 04:40 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
If your asking how you get the servos to move in oppsite directions you just plug them into the Y harness and the single end goes into the receiver. The electronics do the rest. If your asking about aileron differential..... making each aileron move different amounts of up and down to combat yawing, etc. you can accomplish that through the radio if that feature is available or phsycally through the placement of the servo arm on the output shaft.
Via the arm placement on the servo, if your using a single servo in the center of the wing it would depend on if the plane is high wing.. (servo on bottom of wing) or low wing (servo on top of wing). WI know your using two servos so eithe way they should be on the bottom of the wing most likely. Which Pete N Poke do you have.. one is a parasol and the others are low wing. Here is a pic of the general idea. You can keep the horn vertical and make the adjustment at the servo. The amount of "off center" of the arm and horn will control the differential.
There are tests you can do during flight to determine if you have if setup right and the link is here where I got this other info... I wanted to give credit where credit is due...
http://www.modelaircraft.org/mag/ftg...1/31main4.html
Thermalin is offline Find More Posts by Thermalin
Old Apr 09, 2010, 01:07 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
i'd like to see finished pics of your P n Poke. how was the die cutting on your kit? did 90% of the pieces fall out of the sheets?
was the wing attachment easy to do and robust?
TexasClouds is offline Find More Posts by TexasClouds
Discussion How do I work out how many Watts I'll get from my set-up... Stuart Warne Power Systems 3 Mar 15, 2010 05:16 AM
Help! Has anyone built and flown a GP Pete 'n Poke? 4075aaron Fuel Plane Talk 5 Feb 12, 2010 04:32 PM
Found Pete n Poke Kit JRAllen Aircraft - Fuel - Airplanes (FS/W) 6 Jan 09, 2010 09:45 AM
Great Plane Pete N Poke 100% Famed UP DPage Aircraft - Fuel - Airplanes (FS/W) 1 Mar 06, 2005 07:18 PM
