Old Apr 01, 2010, 03:02 PM
I'm FAMOUS
Joined Mar 2010
SYMA S107 Total Tear-Down Photographed
http://www.youtube.com/watch?v=j80NVZAu1dM
This is a simple copter, and its design is based on a lot of similar machines. Even if you own some other copter, you will still find this enlightening.
killbucket is offline Find More Posts by killbucket
Last edited by killbucket; Aug 04, 2011 at 01:25 PM. Reason: all photos by killbucket, all hosted at the air-sharp site.
Old Apr 02, 2010, 07:48 AM
I'm FAMOUS
Joined Mar 2010
May as well continue this with how to re-finish the parts, because that's what I'm planning today!
We'll need Windex, adhesion promoter spray (used for pre-coating vehicle bumpers with), masking tape, copper wire, wood skewers, paint.
Pics coming in a bit...
Old Apr 02, 2010, 08:26 AM
North East England
Joined Feb 2004
Nice autopsy and pics. It's a pity some of the shops and websites describe this as a 'toy' helicopter, when it's so obviously a well-engineered miniature flying machine.
If you haven't already got a paint scheme in mind, a 'tiger stripe' scheme would look good, I recall seeing a full-size US F-16 done like this and it looked great.
Steve
Redbaron25 is offline Find More Posts by Redbaron25
Old Apr 02, 2010, 08:30 AM
Inacio 23's Avatar
Joined Apr 2010
Hi Killbucket, I'm from Brazil, and bought my S107 2 weeks ago, It is cool. But, I want upgrade it. I think in put the mobile battery, put in below, for don't disestablish. My question is: the battery have 1200 mAh, this will burn the board?
Thksss
Inacio 23 is offline Find More Posts by Inacio 23
Old Apr 02, 2010, 08:41 AM
I'm FAMOUS
Joined Mar 2010
wergnwetbnethnyn
Old Apr 02, 2010, 08:59 AM
Inacio 23's Avatar
Joined Apr 2010
Hummm... Ok, I will make tests and post here.
Do You have idea for How upgrade battery?
Thks
PS: sorry for cross-post.
Old Apr 02, 2010, 09:33 AM
Inacio 23's Avatar
Joined Apr 2010
Yess, I want see How!!!
Old Apr 02, 2010, 09:34 AM
I'm FAMOUS
Joined Mar 2010
wrbthn3ethne4th4n4y
Old Apr 02, 2010, 09:40 AM
Inacio 23's Avatar
Joined Apr 2010
Humm.. I Dont understand. =(
Old Apr 02, 2010, 09:43 AM
Joined Aug 2006
I figured you bought a few more. That is the easiest way increase the flying time!
Can you read any of the markings on the parts on the pcb?
derelicte is offline Find More Posts by derelicte
Old Apr 02, 2010, 09:59 AM
I'm FAMOUS
Joined Mar 2010
Only the few seen in the pics.
More flying time wanted, get more copters.
Much easier than playing engineer, and DEFINITELY spending more looking for the 'right combo' (it won't be the first or third try that works, trust me)..
Old Apr 10, 2010, 01:25 PM
I'm FAMOUS
Joined Mar 2010
Put it back together now.
wrbgetw4
Last edited by killbucket; Dec 24, 2010 at 07:03 PM. Reason: pics by killbucket, hosted at air-sharp.
Old Apr 14, 2010, 09:36 PM
Raleigh, NC
Joined Apr 2007
kb, referencing photo #6 in post #1 where you say "Pull the lower blade set and head off; it's a press-fit.", just how hard did you have to pull on the lower blade set to get it off?
I pulled as hard as I dared but couldn't get mine off. Does the shaft go through the drive gear?
Bill
Sir Raleigh is offline Find More Posts by Sir Raleigh
Old Apr 14, 2010, 09:53 PM
I'm FAMOUS
Joined Mar 2010
Yes, it presses onto the
wrhgbetne4t
Old Apr 14, 2010, 10:44 PM
Raleigh, NC
Joined Apr 2007
Okay.
The problem was that the rotor head was loose on the shaft so I couldn't use that to twist with (that was the part I had to fix).
Do you think the lower rotor head is glued to the shaft during initial assembly?
Bill
Discussion Syma s107 Helicopter jlcamp7 Coaxial Helicopters 13032 May 18, 2013 12:41 PM
Discussion V-max .vs. Falcon-X .vs. Syma 3 S107? 7immy Mini Helis 12 Apr 07, 2011 04:11 PM
Discussion Syma S107 Redbaron25 Micro Helis 8 Apr 02, 2010 01:54 PM
Discussion SanHuan 6023 or Syma S107 ? Tuc Coaxial Helicopters 20 Mar 21, 2010 09:15 AM
