Old Jan 13, 2011, 12:01 PM
sv1000s is offline
Find More Posts by sv1000s
Throttle-Hold Expert
sv1000s's Avatar
Spokane
Joined Jan 2009
Originally Posted by tracknoob View Post
Ahem:
1) I thought your profile said you are a college student, not an aeronautical or materials engineer.
2) When offered two options - hack away at what is already a minimalist chassis structure, versus providing a simple spacer to prevent possible interference; to most people, the preferred (and tested!) solution is obvious. Apparently not so for you. So be it.
3)I'd suggest you stay in school.
How can you say that little piece removed is "Hacking Away"?
How can you think the skids offer any structural integrity?
Are you an Engineer?
I am going to keep this public so other people can see how you are.
sv1000s is offline Find More Posts by sv1000s
Old Jan 13, 2011, 12:09 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
(emphasis added)
Okay partner, I'll be your your huckleberry.
1. *I* never said the skids provided structural integrity. Not a point of contention.
2. Instead, it was YOU who said that the skids and the bar across the battery tray (which was the object of discussion) did NOT provide any structural integrity. Please review the thread if you disagree with either #1 or #2, so far.
3. My recommendations and endorsements of OP's pragmatic and now at least twice-proven method (grommets versus hacksaw) are consistent with modeling best practices, and with the concepts of mod-reversibility, of first doing no harm, and of taking a least-invasive approach that directly addresses the issue at hand without potentially introducing new or different issues. The one minor downside it could potentially introduce -- the skids eventually slipping off, was addressed by the OP in his recommendations to use adhesive, and check for fit.
4. Yes, I am an engineer, not that it matters for the purposes of this dialog.
5. I implore you to now stand down, or to take this to PM, as previously requested. I meant no harm, no disrespect, and no affront, and still don't, but frankly, you are out of your league, son. However, if you insist that you want to keep squawking, then of course, I'll keep listening and replying.
Cheers!
tracknoob is offline Find More Posts by tracknoob
Old Jan 13, 2011, 12:18 PM
sv1000s is offline
sv1000s's Avatar
Spokane
Joined Jan 2009
(emphasis added)
okay partner, i'll be your your huckleberry.
1. *i* never said the skids provided structural integrity. Not a point of contention.
2. Instead, it was you who said that the skids and the bar across the battery tray (which was the object of discussion) did not provide any structural integrity. Please review the thread if you disagree with either #1 or #2, so far.
3. My recommendations and endorsements of op's pragmatic and now at least twice-proven method (grommets versus hacksaw) are consistent with modeling best practices, and with the concepts of mod-reversibility, of first doing no harm, and of taking a least-invasive approach that directly addresses the issue at hand without potentially introducing new or different issues. The one minor downside it could potentially introduce -- the skids eventually slipping off, was addressed by the op in his recommendations to use adhesive, and check for fit.
4. Yes, i am an engineer, not that it matters for the purposes of this dialog.
5. I implore you to now stand down, or to take this to pm, as previously requested. I meant no harm, no disrespect, and no affront, and still don't, but frankly, you are out of your league, son. However, if you insist that you want to keep squawking, then of course, i'll keep listening and replying.
Cheers!
lol
Oh yes you did!
that I would not want to remove any part that might be needed to contribute to structural integrity
http://www.rcgroups.com/forums/showp...&postcount=805
Old Jan 13, 2011, 01:48 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
My posts are all correct -- I said exactly what I said, meant what I said, and feel no need to retract, correct or clarify anything.
I did not say what you claimed I said, and your link illustrates exactly that.
Keep workin' on it, I think eventually you'll get there, sport!
HINT: You have actually seen P/N EFLH2222 and it's descriptor, correct?
Still not wanting to go to PM, eh, mate?
Old Jan 13, 2011, 03:32 PM
DoomsDay is offline
Find More Posts by DoomsDay
DoomsDay's Avatar
Charlotte Douglas, NC
Joined Sep 2003
(emphasis added)
Cheers!
I believe I was the one who suggested slicing off a small amount so that it no longer touches. That is NOT doing any harm. It is still there and still works for its intended purpose of protecting the battery.
extending the landing gear is the worse option if you think about it. You are changing the actual design of the helicopter by making the landing gear be farther away than it was made. Now, will it really hurt it? I doubt it. But it would be considered as changing the design of the helicopter itself.
Which is actually worse? Your adding more weight by adding the grommets, your extending the landing gear further down, You may have to use some type of glue to keep the landing gear in place which then if you crash and break the landing gear, may now have a much harder time in removing. All of that versus taking a sliver of plastic off the top edge to keep the shaft from touching.
Both systems work, but for some ungodly reason your acting like taking a sliver of plastic off is going to make the helicopter explode into a billion pieces and then the rest of the world is going to go into complete anarchy.
I say they are both alternatives that have been proven they work.
DoomsDay is offline Find More Posts by DoomsDay
Old Jan 13, 2011, 05:03 PM
padge993 is offline
Find More Posts by padge993
Joined Nov 2010
Originally Posted by jtravel View Post
Motor cutting out could be a bad connection,bad motor or Bad ECS.
Check the motor wires and make sure they are not pinched or damaged and that the connector is completely connected to the ECS.
I worked on a MCX2 that came from the factory with the motor wire pinched between the motor and mainframe.
If you don't see anything obvious swap the two motor connectors at the ECS board. If the problem follows the motor you have a bad motor.
If the motor that was previously working fine now cuts out you have a bad ECS.
Looks like a bad ECS swapped plugs round and the the motor that was cutting out works fine. Both motors work fine on 2nd plug. Am i covered by a warranty?
padge993 is offline Find More Posts by padge993
Old Jan 13, 2011, 05:08 PM
sv1000s is offline
sv1000s's Avatar
Spokane
Joined Jan 2009
AGREED 100%!
I don't know what Tracknoob's problem is...
I'm done wasting my time with that guy...
Old Jan 14, 2011, 06:03 PM
TheOldFart is offline
Find More Posts by TheOldFart
Crash expert
Joined Nov 2010
AGREED 100%!
In my opinion, he doesn't have a problem. You do. Why is that the 2 engineers here are the ones who think that a simple reversible mod is better than hacking away at something? Perhaps it is because we long ago learned that a simple mod that doesn't have a chance of error or damage is better than one that can result in damage if done incorrectly or something slips. Why is it that complex gear systems are adjusted with shims and not by grinding away at the components?
TheOldFart is offline Find More Posts by TheOldFart
Old Jan 14, 2011, 06:40 PM
sv1000s is offline
sv1000s's Avatar
Spokane
Joined Jan 2009
I won't waste my time with you either....you two just don't get it.
Old Jan 14, 2011, 06:42 PM
jeffpack1957 is offline
Find More Posts by jeffpack1957
Puyallup, wa.
Joined Dec 2010
mods..
I cant see how a grommet, that measures less than 1/32in, even when factored to scale, makes any appreciable change. In fact, that grommet adds some shock isolation to the frame on a hard landing.
I would do that before grinding the battery support. Removing material rarely is ever considered to not affect structural integrity.
jeffpack1957 is offline Find More Posts by jeffpack1957
Old Jan 14, 2011, 07:36 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Thanks jeffpack1957 and Oldfart for letting me know I am not totally out to lunch.
However, I now realize that as a noob here, I should have taken a more friendly tone, even as I argued my position, so I hereby apologize openly and publicly to sv1000s and DoomSay or anyone else who might feel I was less than polite. Being new to the forum, it takes some figurin' to understand the culture, and I guess things here are a mite more teechy than I am used to.
I had hoped that a single photo from my own heli, now included in the prior post since a moderator told me I needed to edit it based on a complaint, would have sufficed to illustrate my point.
If not, I guess I am just plain out of bullets, and ready to move on to more fruitful pursuits!
Old Jan 14, 2011, 08:09 PM
Puyallup, wa.
Joined Dec 2010
While there's no real right or wrong answer yet, common sense dictates that in lieu of absolute facts, a temporary and reversible fix would be better than a permanent and untested one.
Old Jan 14, 2011, 08:27 PM
jmoore is offline
Find More Posts by jmoore
Jim
jmoore's Avatar
Winchendon,MA
Joined Aug 2007
I have to join in with the engineers. Actually, my fix was even less invasive. Once I saw that the shaft was indeed touching the battery brace, I simply pulled the front peg of the ldg gear out slightly and I now have plenty of clearance. I'm keeping an eye on it, but so far even after a few hard landings, the clearance is still there.
jmoore is offline Find More Posts by jmoore
Old Jan 14, 2011, 11:59 PM
sviking is offline
Find More Posts by sviking
Prescott, AZ
Joined Jan 2011
Originally Posted by Bowerz View Post
Ok, DO NOT INSTALL ANY ALUMINIUM PARTS WHERE THERE SHOULD BE PLASTIC!!!!!!
I agree...except for the swashplate. I've flown R/C helos from an mSR to a CX2/3 to large glow helos like X-Cell and TSK Mystar .60s. A CNC metal swashplate is a VERY worthy upgrade. It's a fairly high stress/high RPM component that is the heart and soul of the flight control system that connects the non-rotating control input from servos to the rotor blades.
sviking is offline Find More Posts by sviking
Old Jan 15, 2011, 10:02 AM
kaamacat is offline
Find More Posts by kaamacat
Cumming, GA
Joined Jan 2011
Was checking mine last night...... The shaft has plenty of room between the battery holder (so I'm fortunate). But, did notice that there was room to trim the shaft end if needed, should I have been in the stuation where it did in-fact hit the carrier.
Just mention that as another option as it all depends on how high up your lower gear is in relation to the motor pinion gear, which is wider. (And sure you'd then lack some wiggle room). Just mentioning.
kaamacat is offline Find More Posts by kaamacat
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 11:27 AM
Sold EFLITE BLADE MSR+BLADE 400+DX6i dhmojo Aircraft - Electric - Helis (FS/W) 7 Mar 29, 2010 11:38 PM
Sold Blade MCX2 LNIB mgroves Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2010 12:17 PM
For Sale Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. kdill2160 Aircraft - Electric - Helis (FS/W) 1 Sep 02, 2006 10:28 AM
Alert Eflite Blade CX - 2nd Eflite heli jschenck Coaxial Helicopters 26 Oct 24, 2005 02:48 AM
