Old Jan 12, 2011, 05:22 PM
kaamacat is offline
Find More Posts by kaamacat
Cumming, GA
Joined Jan 2011
Originally Posted by jeffpack1957 View Post
I did figure out how to mount them, but they are poorly designed and built.
I flew once with them, and then discarded. For a first time flyer, I'm now flying all about the big room, landing, taking off, etc. I just get abit lost sometimes if the bird gets away from me, and its nose toward me.
Just switched to my DX7, and got it trimmed up and flying this morning. Took the rubber grommets from the training gear, and used them to space down the landing gear, so the battery brace doesnt touch the main shaft.
This little bird is a hoot to fly.
One thing I did notice if anyone has any thoughts, is the swash plate servo arms seem to lightly graze the canopy body opening. Doesnt seem to have any impact, but I cant believe its helping anything either.
Maybe tonight I'll switch to the CF tail boom.
I had that on mine, ever so slightly on the right side. (And I could see it binding. Did not take but a slight touch to make it happen). What I ended up doing was just to trim about 1/8" off the total top and its perfect now.
kaamacat is offline Find More Posts by kaamacat
Old Jan 12, 2011, 06:24 PM
jeffpack1957 is offline
Find More Posts by jeffpack1957
Puyallup, wa.
Joined Dec 2010
hmm
Ok, I'll try that. thx.
jeffpack1957 is offline Find More Posts by jeffpack1957
Old Jan 12, 2011, 07:04 PM
padge993 is offline
Find More Posts by padge993
Joined Nov 2010
Originally Posted by padge993 View Post
I have replaced the front left servo bracket on my bird. Now when i throttle up it spins counter clock wise cant gain altitude. Any ideas why this could be happening?
Also the main motor plugs that plug into the 5in1 board is it the black and white wire plug it to the left socket and red and blue into the right socket?
This is a video of what's happening when i go full throttle the top motor cuts in and out. So when its assembled and on the ground i cant hit full throttle just a little throttle and it spins clock wise.
http://www.youtube.com/watch?v=oqYFF7bOvKs
padge993 is offline Find More Posts by padge993
Old Jan 12, 2011, 07:27 PM
sv1000s is offline
Find More Posts by sv1000s
Throttle-Hold Expert
sv1000s's Avatar
Spokane
Joined Jan 2009
Originally Posted by tracknoob View Post
Exactly.
Lipo fires are no fun, even for a battery as small as the mCX's.
As well-engineered, but minimal as this heli already is, I would not be for chopping out ANY bracing or support on it, anywhere. On the huge metal helis, sure they do have extra junk, and might be hugely overbuilt, but this thing is already so 'optimized' and light, that I would not want to remove any part that might be needed to contribute to structural integrity.
Again the grommet-on-the-pin fix seems to me to be a pretty darn good fix, and with minimal downside - the slight possibility of losing your skids, only if they are too loose and you also fail to put some adhesive on them.
The battery holder and skids offer NO structural integrity to this heli.
Besides.......when you crash you are only crashing 1 ounce of weight. Removing a peice of plastic that is so small that you need tweezers to pick it up afterwards will in no way negatively effect the heli.
And were not even talking about cutting completely through the center brace. Just a little nick out of it.
sv1000s is offline Find More Posts by sv1000s
Old Jan 12, 2011, 10:12 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
It looks like your bottom collar bushing is loose. Check the screw.
Chap1012 is offline Find More Posts by Chap1012
Old Jan 12, 2011, 10:42 PM
padge993 is offline
Joined Nov 2010
Is it this i can see it after watching and watching. http://images.trademe.co.nz/photoser...45968_full.jpg
Old Jan 12, 2011, 11:18 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Funny that they wasted the material putting that bar in there....
tracknoob is offline Find More Posts by tracknoob
Old Jan 13, 2011, 12:49 AM
sv1000s is offline
sv1000s's Avatar
Spokane
Joined Jan 2009
THAT material I removed weighs like 1/100th of a gram...and the bar is still there doing what it's supposed to do (reinforce the battery holder).
ARE YOU SERIOUS MAN?!
Cheese.....
Old Jan 13, 2011, 05:15 AM
jtravel is offline
Find More Posts by jtravel
Rather Be flying or Tinkering
jtravel's Avatar
Arizona
Joined Aug 2010
Motor cutting out could be a bad connection,bad motor or Bad ECS.
Check the motor wires and make sure they are not pinched or damaged and that the connector is completely connected to the ECS.
I worked on a MCX2 that came from the factory with the motor wire pinched between the motor and mainframe.
If you don't see anything obvious swap the two motor connectors at the ECS board. If the problem follows the motor you have a bad motor.
If the motor that was previously working fine now cuts out you have a bad ECS.
jtravel is offline Find More Posts by jtravel
Old Jan 13, 2011, 09:34 AM
loudbikes is offline
Find More Posts by loudbikes
loudbikes's Avatar
USA, WA, Yakima
Joined Jan 2005
ECS?? Do you mean ESC (electronic speed control)? - Tim :-)
loudbikes is offline Find More Posts by loudbikes
Old Jan 13, 2011, 09:47 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
(posts consolidated and snipped for clarity)
Cheese.....
When offered two options - hack away at what is already a minimalist chassis structure, versus providing a simple spacer to prevent possible interference; to most people, the preferred (and tested!) solution is obvious.
Link to original vid describing problem and fix:
http://www.youtube.com/user/thestar22#p/u
Two stills from vid, and two from my own heli:
Old Jan 13, 2011, 10:12 AM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
The ECS (Electronic Control System) does more than just control motor speed.
It includes control electronics for Gyro,mixer,servos,receiver & motor speed.
Blade Calls it the 5 in 1 board.
Old Jan 13, 2011, 10:25 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Sorry, I meant the outer shaft retaining collar. Page 29 in the manual, part # 020. It looked like it was slipping but, the vid could have been playing tricks with these old eyes
Mike.
Old Jan 13, 2011, 10:49 AM
sv1000s is offline
sv1000s's Avatar
Spokane
Joined Jan 2009
Ahem:
1) I thought your profile said you are a college student, not an aeronautical or materials engineer.
2) When offered two options - hack away at what is already a minimalist chassis structure, versus providing a simple spacer to prevent possible interference; to most people, the preferred (and tested!) solution is obvious. Apparently not so for you. So be it.
3)I'd suggest you stay in school.
I'd suggest you not insult my intelligence.
And I'd suggest you learn some manners and read the site rules.
Old Jan 13, 2011, 10:55 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
You live under a bridge don't you?
I have read the site rules.
I find your reply offensive.
If you care to discuss further, please take this to PM.
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 10:27 AM
Sold EFLITE BLADE MSR+BLADE 400+DX6i dhmojo Aircraft - Electric - Helis (FS/W) 7 Mar 29, 2010 10:38 PM
Sold Blade MCX2 LNIB mgroves Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2010 11:17 AM
For Sale Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. kdill2160 Aircraft - Electric - Helis (FS/W) 1 Sep 02, 2006 09:28 AM
Alert Eflite Blade CX - 2nd Eflite heli jschenck Coaxial Helicopters 26 Oct 24, 2005 01:48 AM
