Old Jan 31, 2013, 01:03 AM
lasakro is online now
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Hi guys. It's my first time here on this thread and sorry for interrupting. I need some serious Coax help. I've got this CX2 and it's kicking my asX big time.
It wants to toilet bowl on take off (see video). Both shafts completely straight by sight and there are no vibrations. New swash and plastic lower head. Both upper and lower blades balance check good. Flybar not bent and also has good balance. Upper blades track good. No bearing slop. Shaft collar is snug to there is no axial shaft movement. I'm at a loss.
Ignore the reference to toilet bowl on the video.
Blade CX2 Toilet Bowl Lift Off (0 min 26 sec)
lasakro is online now Find More Posts by lasakro
Old Jan 31, 2013, 01:17 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Did you check for a cracked shaft. Not familiar with the cx2 but I'm guessing it's constructed the same as the mcx2 only bigger?
By the way, that's not toilet bowl... that's... well... I don't know what to call that
pretty crazy, man.
North_of_49 is offline Find More Posts by North_of_49
Old Jan 31, 2013, 02:58 AM
Seeking Control
lasakro's Avatar
Joined Dec 2012
Crap. I missed the little m in front of the CX2 for the name of the thread. I'll keep looking.
Old Jan 31, 2013, 03:05 AM
Joined Dec 2011
Old Jan 31, 2013, 07:36 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
http://www.youtube.com/watch?v=40NNf...ature=youtu.be
I dont know (from the vid) but is it really toilet bowl you are experiencing? (looks more to me like it is spinning - with toilet bowl the nose points ALWAYS in the same direction while doing the circle)
And if that is the case, it could be you just plugged the motors in the wrong place. did you already try to swap the plugs (top one down and bottom one up)?
Old Jan 31, 2013, 07:50 AM
Seeking Control
lasakro's Avatar
Joined Dec 2012
I guess it not a toilet bowl it's just that as soon as it starts to achieve lift the entire top starts to do circles before falling over. The motors are plugged correctly otherwise the blades would be spinning in the wrong direction.
Old Jan 31, 2013, 07:59 AM
erdnuckel2's Avatar
Joined Mar 2009
Nope, this is NOT what I mean - as long as you do NOT change the polarity, the motors will spin in the same direction, no matter if you plug it in top or bottom.
HOWEVER, top or bottom DOES matter a LOT in terms of which motor is driven from which plug (and this is a rule of thumb that NEVER failed me):
You HAVE to plug the motor that drives the TOP rotor into the TOP plug in the 4in1 and the motor that drives the BOTTOM rotor into the BOTTOM plug in the 4in1!
The other way round will cause the heli to spin!
Old Jan 31, 2013, 08:02 AM
valiantGLX is online now
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Looks like the flybar is too tight, loosen it right off and try again.
Mechanical and digital trim it.
Just because the shafts look to be straight there's a good chance that they're bent if you have crashed it before.
Helis are always less stable in ground effect, after doing the above try a hand take off from 3ft (1m) or more. Put some blankets and cushions around incase things go horribly wrong though
valiantGLX is online now Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Jan 31, 2013, 08:21 AM
Seeking Control
lasakro's Avatar
Joined Dec 2012
I swapped plugs knowing that I never did that before. The Stb. wires were very short to fit the bottom plug but I got them to reach. Maintaining the same polarity both motors changed direction. I plugged them back to the way they were.
The link is closed right up but as soon as I start to loosen it the blade tracking goes out. But that is how it's acting. Nothing binding though.
Swash is level
When spinning they are true
I can take CP and hover nicely in ground effect. As soon as it starts to get lift the entire top wants to wildly spin. Something wacky mechanically.
Old Jan 31, 2013, 09:44 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
lasa, your top rotor is spinning in the wrong direction. Flip the polarity on the plug. Red always faces up on the top and on the bottom faces down. I had the exact same thing happen to me with my V4.
V4 spin.AVI (0 min 20 sec)
Chap1012 is online now Find More Posts by Chap1012
Old Jan 31, 2013, 09:46 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Here's our "official" CX2 thread..
http://www.rcgroups.com/forums/showt...07057&page=524
Old Jan 31, 2013, 10:30 AM
Seeking Control
lasakro's Avatar
Joined Dec 2012
http://www.youtube.com/watch?v=feHBWEYnfOU
Nice try but they are plugged correctly. The bottom spins CW and the top CCW looking from the top. I also never messed with the motors or the plugs until today.
Great! I'll see what ideas they have. If not it's a trip over to the LHS tomorrow to see their tech. Then ship this thing on ebay. This is the first and last coax I'll own.
That least you guys had someone to laugh at for a while. See ya around....and around....oh and around.
Old Jan 31, 2013, 10:36 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
My blades were turning in the correct direction too...
The CX2 is a fine heli. Don't give up
Old Jan 31, 2013, 10:55 AM
Seeking Control
lasakro's Avatar
Joined Dec 2012
My top plug has red on top and my bottom plug has red on the bottom. I'm confused. You first tell me you blades were turning wrong then you wrote they were correct but still had spin.
Old Jan 31, 2013, 11:39 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
"B" motor (lower rotor) is plugged into the bottom and "A" motor (top rotor) is plugged into the top..
I have the EFLH1024 RX in my V4. Same as the CX2 right?
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 10:27 AM
Sold EFLITE BLADE MSR+BLADE 400+DX6i dhmojo Aircraft - Electric - Helis (FS/W) 7 Mar 29, 2010 10:38 PM
Sold Blade MCX2 LNIB mgroves Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2010 11:17 AM
For Sale Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. kdill2160 Aircraft - Electric - Helis (FS/W) 1 Sep 02, 2006 09:28 AM
Alert Eflite Blade CX - 2nd Eflite heli jschenck Coaxial Helicopters 26 Oct 24, 2005 01:48 AM
