Tailboom http://www.bladehelis.com/Products/D...rodID=EFLH2428 Aluminum "performance kit" and different colored canopies and boom tails: http://www.cuskerrc.com/apps/webstor.../535080?page=1 Custom plastic canopies and decorations: http://www.micro-flight.com/BLADE-MCX.htm Here's a place to get the metal frames for the mcx2 as well as a ton of other aluminum parts, canopies, and such: http://www.boomtownhobbies.com/category_s/111.htm Does this cover most of it? I'm not sure if I'm missing anything else. |
Latest blog entry: Fitting a Bravo SX fuselage to a GW 9958...
http://www.microheli.com/store/index.php/cPath/3_31 Thanks, Mickmeister. Looks like they're currently sold out of the aluminum mainframe right now. |
TP103CQ-ACDC charger & CF Tail Boom with LEDS's
So I went and picked up the Thunder Power charger today... running it right now off one of my 12VDC AGM sealed lead acid batteries... nice!
Also did a a quick and dirty proof of concept tonight, putting a spare mCX2 LED light harness onto the CF Tail Boom. Now that I know it works I'll actually make tiny holes for the canopy LED's, use O-rings or small pieces of heat shrink for securing the wires to the boom (maybe even cover the boom/wires instead with something tubular, small and light weight like a tiny straw or something)... and probably figure out a cool quick connect system, I have a bunch of micro Deans plugs I use on the pickups of my guitars but I want something even more light weight like some kind of skinny male/female pins without a housing. Lost maybe 10 seconds of flight time to the added weight and power to run the LED's. (EDIT more like up to a half minute, depending on which battery I use... since I was already getting 7.5 to 8.5 mins that's still not too bad. I see you guys are discussing the aluminum Microheli parts... the main frame is the only one I'm interested in due to it's heat sink action on the motors which I don't find is an issue on my bird, but it can't hurt. . |
mCX2 CF Tail Boom with lights
Here's a video showing my LED mod. As always, watch it directly on Youtube to lose the crippled frame-rate you get here in the embedded player... and choose HD
I know there is the MIA scale fuselage. Has anybody thought or fitted a Nine Eagles
bravo fuselage to the MCX2? It looks like it should fit.. http://www.helipal.com/nine-eagles-b...z-edition.html |
It's on the boom right now and I would have had the mod completed and had a nice video uploaded by now but I had a catastrophic failure of one of mt LED's. Didn't realize until I was almost done the mod that E-flite messed up the extra LED harness I bought and put the green nav light on the left and the red on the right. You can't just flip the harness over either because the main plug then won't reach the 5-in-1 (4-in-1?) without having to mod it. So I though I'd put my soldering skills to the test and swap the boards around... was 90% successful but then the heat dislodged one of the very small surface mount LED's from the board and is gone. I went to my local electronics supply shop and against their advice I bought a pack of 5 high efficiency red surface mount LED's and tried my best to place it onto the board and almost succeeded (after first losing all but the last one!) but in the end I failed. Oh well, I don't have the $900 machine to properly set them and it was worth the 2 bucks I paid to find out if it could be done manually. I'm leaving right now to go buy a new $6 harness ![]() ... look here for a video hopefully soon... I need to get some sleep at some point today though ![]() Quote:
![]() ... but thanks for your input! Was also toying with the thought of other aftermarket LED's as well... was curious what the result would be of putting a self blinking LED in the tail which is of course triggered by the helis mainboard which already puts out a strobed voltage. Oh yeah, and I'm replacing the the rudder LED with a clear one... red is not right for that position! |
I'm using TinyBrites on mine. The stock lights weren't an option because I prefer the CF tailboom to the plastic rear section, and I don't want strobing nav's. It was a bitch to install - it involved custom-building a few pieces from bent paper clips and attaching them to the mainframe. Came out pretty good, though.
| Thread Tools | |
| Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter | soaringcam | Aircraft - Electric - Helis (FS/W) | 4 | Apr 07, 2010 10:27 AM |
| Sold EFLITE BLADE MSR+BLADE 400+DX6i | dhmojo | Aircraft - Electric - Helis (FS/W) | 7 | Mar 29, 2010 10:38 PM |
| Sold Blade MCX2 LNIB | mgroves | Aircraft - Electric - Helis (FS/W) | 1 | Mar 23, 2010 11:17 AM |
| For Sale Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. | kdill2160 | Aircraft - Electric - Helis (FS/W) | 1 | Sep 02, 2006 09:28 AM |
| Alert Eflite Blade CX - 2nd Eflite heli | jschenck | Coaxial Helicopters | 26 | Oct 24, 2005 01:48 AM |
