Old Jul 23, 2010, 11:41 AM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
drjim,
One setup question, do you mix aileron to rudder, with your Typhoon? or have rudder mix on a switch?
My only hotliners, for now, have no rudder, so this has never been an issue before. My floaty electric sailplanes, and Ultra Stick have aileron mixed to rudder.
thanks
320pilot is offline Find More Posts by 320pilot
Old Jul 25, 2010, 07:09 AM
mstone is offline
Find More Posts by mstone
Which way is it going now
mstone's Avatar
Australia, SA, Golden Grove
Joined Mar 2003
I feel the need for speed
Had a great time out with the E-Typoon today.
With the bigger motor now fitted with a 13 X 7 the E-Typoon goes like a skun cat. The Turnigy 1800mAh 3S 40C battery came out cooler than the motor.
Attached is the log file from the ESC.
The E-Typhoon flies well in this warm line roll, the energy retention is good with hugh loops and bunts after diving. Didn't try looking for thermals. I will need to look at some cooling for the ESC when summer comes around.
Mark
mstone is offline Find More Posts by mstone
Old Jul 27, 2010, 07:38 PM
acurusaragon is offline
Find More Posts by acurusaragon
Malaysia
Joined Jul 2008
Originally Posted by millikenrob View Post
Alright, so heres the deal (i need some help analysing this - i think it may be over propped).
Motor: gs2218-10
Battery: 3s 1800mah flightmax 40c
Esc: Phoenix 80amp with switching bec
Prop: aeronaut 14x8
I did three motor runs, each about 7 seconds. The motor is VERY hot - too hot to touch? I dont fly electrics, i dont know what this means, but im pretty sure its not right.
According to the wattmeter it's pulling 761watts, and 72.66amps.
The battery dropped to 10.23volts (can someone tell me if this is too low?) should i be worried about a brown out with the ar7000 receiver?
The other two readings i got were .249Ah and 2.5Wh. The first one i'm guesssing is 250mahs, i dont know what the watt hours represents.
So guys - what you reckon, should i go down a prop size - there is a strange smell coming from the motor compartment.
Rob
Rob,
Hows that gs2218-10 holding? recommended for this setup?
Im looking at getting the same.
DEcent power or not?
-sam
acurusaragon is offline Find More Posts by acurusaragon
Old Jul 28, 2010, 10:56 PM
millikenrob is offline
Find More Posts by millikenrob
millikenrob's Avatar
Joined Jun 2008
Oh - i thought i had posted the details.
I ended up with about 45amps on a 12x6.5 - The climb is good - but far from spectacular. Probably 10-15 seconds to get to a thermalling height.
I'm going to bump it up to 13x6 -
12x6.5inch is getting 45 amps, 14x8inch is getting 70amps splitting the diff should get me close to the 55amps max rating.
It does sound fantatic though but im still getting used to the landings. im used to a much slower (groundspeed) landing so a couple of times i have nearly stalled it on landing. It doesnt help that im landing in a pretty tight area.
Last week i damaged my blades trying to power up before landing in either a) a puddle/lake b) a gravel walking path. I hit the gravel walking path, ruined my blades, then slid into a very wet patch of grass.
Does the plane deserve a bigger power setup? If you have the money for a neu/hacker setup then i go for it - otherwise the hyperion is a nice option
rob
millikenrob is offline Find More Posts by millikenrob
Old Jul 29, 2010, 12:37 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Hi Guys!
Just jumping in to soon join the Typhoon party/club/or brotherhood of storm chasers here. I should be going over to pick-up my new Ty' from SoaringUSA Friday.
The set-up I am going to try will/may be....
Aveox 1015/2Y 4.4-1 with 3,4,5, or 6S (prop size to be determained after testing)
CC 80A esc with DE Sport bec (more than I need,but will be there if I need it)
Servos to be decided when I get to SUSA.
I'm trying for a warm/hotliner set-up. I already have a very fast F5D. I will try and keep my findings/experience posted here. It likely won't happen very fast because my free time is so limited....see...gotta rush to work now.
Peace-out, Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jul 31, 2010, 12:28 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I guess I won't be getting the Typhoon right now like I thought. After Bob showed me the Typhoon, I decided it wouldn't accept the larger power set-up (for sick power). I decided not to use the Aveox, and went with a Neu. A Typhoon will be in my future though. It's a very sweet ship...looks even better in person too.
Right now, I opted for the 2M electric Weasel. I wanted a bit more room in the fuse, a one peice wing, and didn't really need the rudder for what I want to do. It was still a hard decision to make.
Bill
Old Aug 01, 2010, 08:29 PM
drjim is offline
Find More Posts by drjim
Joined Apr 2010
320pilot, yes I use aileron/rudder mix. Just added until truns were coordinated better.
Mike Richards, yes it slows down nicely. No apparent tendancy to tip stall. Stalls are
straight forward with my setup. If you let it fly (stay off the elevator and
don't mush around) it will thermal nicely and rather tightly. It is not a
Gentle Lady. If you look at the wing loadings you will see that it will fly
faster than the typical TD type ship. Good luck with your ship.
Jim
drjim is offline Find More Posts by drjim
Old Aug 04, 2010, 09:12 AM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
Thanks, Jim. I was just worried that rolls, (with rudder mixed to ailerons) would go screwy.
ray
Old Aug 12, 2010, 11:49 AM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
this will probably be the motor/ESC for my Typhoon. Just arrived today from Esprit.
Neu 1110/1Y/6.7 on 3S Phx ICE LITE 100 ESC
should I grind a flat spot on the G/B shaft?
Old Aug 12, 2010, 07:13 PM
mstone is offline
mstone's Avatar
Joined Mar 2003
Well that depands on the spinner you use. If you use one of the grub screw types, yuk, and it is not super tight on the shaft and you don't put 609 on it then yes.
If you use a compression type then no.
Either way that should be fun.
Mark
Old Aug 15, 2010, 04:32 PM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
One more question (for now) . I am thinking of a RFM 12.75X 13 prop, for the Neu motor 1110/1Y/6.7 ; PHX ICE 100 combo above. On 3S LiPo
Would that be a suitable prop? I could put throttle on a switch, might try it on the left stick, too.
Old Aug 17, 2010, 11:21 AM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
pictures of my Typhoon, just unpacked from SUSA.
I plan to use some 3.2mm carbon fibre rod for linkage from elevator and rudder servos to tail. (see last two pictures)
Things I like about the kit;
good hardware set, clevis, threaded rod, etc. all metric though.
all servo covers, bellcrank cover are beautifully fitted
stabilator bellcrank (with clevis) already installed in tail
rudder control horn (with clevis) already installed.
all control horns are epoxied into ailerons and flaps.
wing is opened up for linkage from servo boxes to top driven aileron/flap control horns.
canopy already has a wire clip epoxied inside to hold canopy on.
something I would like too;
A factory epoxied motor mount, or at least a built -up lip, to hold a motor mount in place. Fuselage is just cut off at front.
Old Aug 19, 2010, 11:00 PM
mstone is offline
mstone's Avatar
Joined Mar 2003
320pilot,
I'm guessing the 12.75 X 13 prop will work fine. I personally prefer not to use over square props and would go with a 14 X 9.5 for about the same power level. It will not be as fast but should be easier to launch and and climb better.
That setup will take alot more prop 16 X 10 or 16 X 13 if your game. I personally have my throttle on an interlocked switch with a slow startup ramp.
I prefer metric hardware.
I'm guessing the reason they don't put the firewall in is that no two motors have the same mounting holes or need to be positioned the same distance from the the nose.
Good Luck
Mark
Old Aug 21, 2010, 01:07 PM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
thanks, Mark
should be starting with the build soon.
are you worried it will cavitate too much on the launch?
Overall I am very pleased with the kit, and careful packing by SUSA. I was just mentioning some of the highlights of the kit. Many steps in the build have already been done.
I have a 13X9 RFM prop on a BulleT warmliner. It launches beautifully, right out of my hand. Just at little hard to see up high, with only a 58.5 inch wingspan, versus 78.5 inches for the Typhoon, so I bought the larger Typhoon. (Bullet has a Neu 1105/2.5Y/4.4 motor with a Ice Lite 50.)
ps, I do have a spare 13X9 RFM prop, too. I could get a 14.5X10 RFM slim, for later. Thanks for the ideas, now I just have to get this Typhoon flying
Old Aug 21, 2010, 06:55 PM
mstone is offline
mstone's Avatar
Joined Mar 2003
Not so much cavitating but it will not pull out of your hand quite as well. So when you launch you would have to give it a good heave.
Mark
Discussion RCRCM Typhoon 2m - First detail pics slopetrashuk Slope 2586 Mar 03, 2016 11:43 AM
Build Log Typhoon electric build log and presentation Ghost_ Electric Sailplanes 0 Mar 29, 2010 12:47 PM
Build Log Stinger 45 Build Log by sekollera EscoFlier Slope 129 Jan 08, 2009 10:06 PM
Build Log Blu-Baby Build Log - by Phil PhillipE Aerial Photography 6 May 23, 2008 09:20 PM
Discussion RCSP Blackwing build log (by an amateur) bennymack Foamies (Kits) 5 Oct 02, 2007 08:30 PM
