Old Jul 13, 2013, 02:07 PM
Martijn666 is offline
Find More Posts by Martijn666
resU deretsigeR
Martijn666's Avatar
Harderwijk, The Netherlands
Joined Aug 2008
Hey guys, I just wanted to mention I passed the test for my FIA license with my E-Typhoon! Was a super easy climb with the Kira 450-26 and a 16x10 Cam carb prop...
Martijn666 is offline Find More Posts by Martijn666
Old Jul 13, 2013, 02:20 PM
martinh is offline
Find More Posts by martinh
martinh's Avatar
United Kingdom, England, Fleet
Joined Aug 2002
Congratulations! What do you have to do to pass the test?
Martin
martinh is offline Find More Posts by martinh
Old Jul 13, 2013, 06:19 PM
resU deretsigeR
Martijn666's Avatar
Joined Aug 2008
It was easier than my powered flight license, the one I passed recently only applies to gliders.
Phase 1: Launch and climb in a straight line without diverting
Phase 2: Power off and stay aloft for a minimum of 3 minutes
Phase 3: Above the runway, at the start, begin with flying a circuit. The last 90 deg turn needs to align the glider with the exact middle of the runway (all without power). Land within 30 meters of the pilot.
As you can see, no biggie. But flying the Phoon made things a lot easier
Old Aug 03, 2013, 03:08 PM
turnale is offline
Find More Posts by turnale
turnale's Avatar
United States, TX, Houston
Joined May 2006
All,
I have a question concerning the throws for the ailerons and flaps: when the manual says "All measured from the outboard trailing edges" - it means towards the wing tip or towards the root?
Am I suppose to measure the throw where the aileron is at its widest (next to the flap) or where it is the narrowest (at the wing tip)?
Side question - are the manual recommendation a good start for the throws? Any dual rate recommendation?
the "manual" I am referring to: http://www.rcrcm.com/pdf/Typhoon-instruction-Manual.pdf
RCRCM recommendation:
GENERAL:
Ailerons = + 7 mm, -5 mm
Flaperon = +/- 8 mm
Rudder = As much as possible
Elevator = +/- 10 mm
CROW
Crow- Flap = As much as you can get.
Crow-Aileron = +7 mm
Crow-Elevator compensation = -4 mm
THERMAL (WHAT?) OR PUSSYCAT
Thermal or Cruise flap = -2 mm
Thermal or Cruise Aileron = -1mm
PACEMAKER SWITCHED ON?
Ailerons/flaps reflex up = 1-1.5mm
turnale is offline Find More Posts by turnale
Old Aug 03, 2013, 04:24 PM
Soaring Junkie is online now
Find More Posts by Soaring Junkie
Addicted to carbon and speed
Soaring Junkie's Avatar
Australia, QLD, Tingalpa
Joined Jul 2013
Hi turnale,
The recommended throws are measured from the tips for ailerons, root for flaps.
I have used the recommended throws as a starting point have worked well. I have added snap flaps, and the 'phoon really pulls hard and fast through turns/loops, much better than without. I have snap flaps active in all flight modes/conditions. Check out Slope Racer for their recommended setup.
You may need to open up the hinges to get full throws in ailerons, by carefully sanding/dremel the inside of the live hinge. My roll rate was a bit slow until I did this, and made sure I got at least the recommended travel.
Video from last weekend, slope soaring, fixed view so best in full screen:
E Typhoon at Beechmont (2 min 35 sec)
Cheers,
Brent
Soaring Junkie is online now Find More Posts by Soaring Junkie
Old Aug 04, 2013, 01:10 PM
turnale is offline
turnale's Avatar
Joined May 2006
Found my answer on Tony's website sloperacer.co.uk
http://www.sloperacer.co.uk/_content/typhoon.asp
It is very clear:
Aileron (measured at tip)
Up 7mm
Down 5.5mm
Aileron (Camber) - Down 1.5mm
Aileron (CROW) Up 5mm
Aileron (Snap Flap mix) Up/Down 1.5mm
Aileron (Reflex) Up 1mm
Flap (Measured at root)
Flap / Aileron mix Up 8mm, Down 5mm
Flap (Camber) Down 3mm
Flap (CROW) Down 58mm
Flap (Snap Flap mix) Up/Down 3.5mm
Flap (Reflex) Up 1mm
Rudder (measured at base)
Left / Right 17mm
Elevator (Measured at widest point near root)
Up / Down 11mm
Elevator (CROW) down 9mm
Let's see if I will be able to get that .5mm precision
Old Aug 04, 2013, 01:24 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Be more interesting if you noticed the difference between 3mm and 3.5mm
feefo is offline Find More Posts by feefo
Old Aug 04, 2013, 02:09 PM
martinh is offline
martinh's Avatar
Joined Aug 2002
I'm using Tony's setup and it works nicely.
The only issue is that with the ~9mm ish down compensation required for crow braking, there's not enough extra down travel on the elevator if you're set at the stated 11mm max travel. I've set my down elevator to something around 15mm to allow for this.
Hope this makes sense.
Martin
Old Aug 04, 2013, 10:29 PM
RanGee75 is offline
Find More Posts by RanGee75
RanGee75's Avatar
Joined Sep 2012
Recommend propulsion configuration
Hello All,
Can anyone suggest a recommend propulsion configuration for the E-Phoon?
I am looking for excellent climb rate for an economy budget
Thanks!
RanGee75 is offline Find More Posts by RanGee75
Old Aug 05, 2013, 01:13 AM
martinh is offline
martinh's Avatar
Joined Aug 2002
Martin
Put another way, Tony's elevator setting will almost inevitably cause a crash at some point.
You need to increase the elevator setting to give more down elevator movement when crow braking is activated.
Martin
Old Aug 05, 2013, 01:23 AM
martinh is offline
martinh's Avatar
Joined Aug 2002
Originally Posted by RanGee75 View Post
Hello All,
Thanks!
You could try one of the Turnigy GliderDrive motors from hobbyking http://www.hobbyking.com/hobbyking/s...4_6_840kv.html
The 4.6 840 kv one looks good on 4S. I have one to try and the quality looks ok. Not sure about the best prop though 14x9 looks interesting.
Martin
Old Aug 05, 2013, 04:41 AM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
MVVS motor could be another choice, more expensive but better quality than the Turnigy and cheaper than a geared drive http://www.espritmodel.com/mvvs-sail...ss-motors.aspx
Old Aug 05, 2013, 05:56 AM
gouch is offline
Find More Posts by gouch
de-registered abuser
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
Martin
can you jam a 38mm motor in the nose?
gouch is offline Find More Posts by gouch
Old Aug 05, 2013, 10:18 AM
turnale is offline
turnale's Avatar
Joined May 2006
Martin
Thanks! I will maiden the typhoon tonight and will increase the throw beforehand.
This plane's weight is way above spec - 1950g against 1450g... should I be concerned?
This is the full carbon version, with Tony's recommended setup for power, run on a 1800mAh 70C 4s battery. I might have been able to save a few grams here and there by being more cautious with the glue usage, but certainly not 500g! The plane didn't even need lead for balancing.
Old Aug 05, 2013, 10:21 AM
turnale is offline
turnale's Avatar
Joined May 2006
It might (haven't checked, I will tonight). You will have to cut the nose a great deal. If you want to make your life much easier, and have not problem at all finding a cheap and yet powerful power setup, get the RCRCM Hornet. Basically the same plane, but with a wider fuselage.
Discussion RCRCM Typhoon 2m - First detail pics slopetrashuk Slope 2590 May 27, 2016 11:05 AM
Build Log Typhoon electric build log and presentation Ghost_ Electric Sailplanes 0 Mar 29, 2010 12:47 PM
Build Log Stinger 45 Build Log by sekollera EscoFlier Slope 129 Jan 08, 2009 10:06 PM
Build Log Blu-Baby Build Log - by Phil PhillipE Aerial Photography 6 May 23, 2008 09:20 PM
Discussion RCSP Blackwing build log (by an amateur) bennymack Foamies (Kits) 5 Oct 02, 2007 08:30 PM
