Old May 19, 2010, 11:20 AM
MooSey-UK is offline
Find More Posts by MooSey-UK
Born Again Idiot
MooSey-UK's Avatar
United Kingdom, Wiltshire
Joined Jul 2007
Great set of illustrative photos there mark. Very informative.
MooSey-UK is offline Find More Posts by MooSey-UK
Old May 19, 2010, 10:26 PM
millikenrob is offline
Find More Posts by millikenrob
millikenrob's Avatar
Joined Jun 2008
I'll look forward to the build Mark.
Rob.
millikenrob is offline Find More Posts by millikenrob
Old May 20, 2010, 08:10 AM
mstone is offline
Find More Posts by mstone
Which way is it going now
mstone's Avatar
Australia, SA, Golden Grove
Joined Mar 2003
Servos first
Well I didn't get the servos in tonight :-(
The JR DS368 servo, I think the HS85 will be in the same boat, will go in but it stands so high the you can't get a decent servo arm on it.
With more measuring you really need a servo with less than 19mm below the mounting lugs and as importantly less than 15mm from the button of the mounting lug to the topside of the servo arm.
So I'll try a JR NES-381 (321 ? in other parts of the world) on the weekend.
Other than that I think the following will fit: Hyperion 11 Series, GWS Naro plus BB and Hitec HS-65.
Mark
mstone is offline Find More Posts by mstone
Old May 20, 2010, 08:24 AM
pilotrcuk is offline
Find More Posts by pilotrcuk
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
What depth is available in the wing for wing servos Mark?
pilotrcuk is offline Find More Posts by pilotrcuk
Old May 20, 2010, 06:29 PM
mstone is offline
mstone's Avatar
Joined Mar 2003
Wing servos
The flaps a reasonably deep I put HS85s in and they fit with nothing to spare.
The ailerons don't have a huge space. I used JR DS171, which are 11mm thick and there wasn't alot of spare space. The aileron and flap clovers do have a small bulge molded into them. So you have to make sure you line the servo up with the bulge, in the example of the HS85 for flaps, or they don't fit.
There is lots more info on the wings over in the slope forum.
You will need about a 35mm spinner and there is about 300mm to the leading edge from the back of the spinner.
Mark
Old May 20, 2010, 07:11 PM
Joined Jun 2008
The hyperion DS-95's work perfectly for the ailerons with no bulge. They are 9.5mm.
Old May 20, 2010, 07:32 PM
Dangerous James is offline
Find More Posts by Dangerous James
Pompano Hills Flyers
Dangerous James's Avatar
Miami
Joined Aug 2004
Originally Posted by laanguy View Post
Ghost,
I have a few electric fuses on the way to go with slope typhoons over here. A friend is considering what set up to use but put a few questions to RCRCM and this is what details I now have from their test model.
- The motor: diameter 28mm, KV880.
- The prop we used for test is 12*8".
- Controller: Futaba
- Battery: Lipo battery 15C 2200mA 3S
- Spinner: the diameter 35mm, L=34mm,
- The diameter of nose cone: 35mm.
- The nose width: 44mm.
- The nose length: 300mm.
I was sent a few early pics of the test fuse.
Andrew
Are those HS-55 servos that you're using?
DJ
Dangerous James is offline Find More Posts by Dangerous James
Old May 20, 2010, 08:54 PM
mstone is offline
mstone's Avatar
Joined Mar 2003
DJ
Look more like HXT900 to me.
Old May 21, 2010, 12:25 AM
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
Cool, I have a set of those for my Graphite that doesn't really need them (way more space than 9.5mm available in that) so I might go with these. I had hoped to go with cheaper servos but since they're on the shelf... Thanks.
Old May 21, 2010, 02:35 AM
Joined Jun 2008
I know James uses those vg8's from hobbycity. http://www.hobbycity.com/hobbycity/s...idProduct=7026
Old May 21, 2010, 03:05 AM
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
I had a set of these to use in a HET Sniper EDF model - I sold them on though having read some bad reports re developing slop really quickly. Nice and thin at 8mm though!!
Old May 22, 2010, 09:35 AM
mstone is offline
mstone's Avatar
Joined Mar 2003
Servos are in
Well I have installed the servos.
Ended up with JR E381 for the elevator and HS 65 for the rudder. The elevator servo is probably overkill but it fits and they are reasonably priced.
Used the pushrod ends and MP-Jet clevis's that Andrew from Falcon Gliders provided with the fuselage.
I hope to get the firewall glued tomorrow.
Mark
Old May 22, 2010, 11:55 PM
mstone is offline
mstone's Avatar
Joined Mar 2003
Firewall is done
The firewall in now in.
The front of the fuse had about 2 degrees of up and 1 degree of left. So I sanded it to have about 1 of down and no left or right. I'll mix the rest out with the radio if required.
How just wait 24 hours for the epoxy to set properly.
Mark
Old May 23, 2010, 02:31 AM
Soggy Scotland
pilotrcuk's Avatar
Central Scotland
Joined Jun 2004
Bit of a pain that the nose isn't prepared as well as it should be... Nice work with your install.
Old May 24, 2010, 10:03 PM
Joined Jun 2008
Hey Mark,
How do you tell the angle of the nose? Do you just lay it flat on the table and have a guess?
Discussion RCRCM Typhoon 2m - First detail pics slopetrashuk Slope 2590 May 27, 2016 11:05 AM
Build Log Typhoon electric build log and presentation Ghost_ Electric Sailplanes 0 Mar 29, 2010 12:47 PM
Build Log Stinger 45 Build Log by sekollera EscoFlier Slope 129 Jan 08, 2009 10:06 PM
Build Log Blu-Baby Build Log - by Phil PhillipE Aerial Photography 6 May 23, 2008 09:20 PM
Discussion RCSP Blackwing build log (by an amateur) bennymack Foamies (Kits) 5 Oct 02, 2007 08:30 PM
