Old Feb 06, 2012, 06:12 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Have you flown the e-typhoon yet Husafreak? Would like to see a photo of your fuselage install.
I just got my typhoon back in the air. Flap fixed with a silicon hinge.
Stunt Double is offline Find More Posts by Stunt Double
Old Feb 10, 2012, 11:00 AM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Quick question, do I glue both stab halves to the carbon rod, so it is attached permanently? Also, what holds the wing on, do I just tape the joints?
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Feb 11, 2012, 02:24 AM
Joined Oct 2007
No, dont glue the carbon rod. If you break it the bits will be stuck and you might have to replace the stabs. Just build up the thickness of the rod with thin CA until its a tight fit and sand it back if you put too much on (let the CA set before you insert the rod!!).
On another forum the designer of the typhoon mentioned the wings were designed to be taped in place. I find it a bit annoying to tape the entire join so I use one small piece of fibre strapping tape on the top. My wings hold very tight anyway as I used the CA trick to build up the thickness of the carbon joiner and could actually fly it without any tape at all.
Old Feb 11, 2012, 05:16 PM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
Stunt Double,
Here are some pictures of my Typhoon, showing the motor/ESC layout in the fuse. Futaba receiver is behind the wing joiner.
320pilot is offline Find More Posts by 320pilot
Old Feb 11, 2012, 08:03 PM
badbill is offline
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
That worked great. I had already called SUSA and they had told me the same. I was surprised just how little CA it took. Thanks!
Bill Davenport
AMA 28141
Old Feb 11, 2012, 10:44 PM
nph is offline
nph
Find More Posts by nph
nph
United States, TX, Plano
Joined Oct 2010
Sorry, I am building my Typhoon right now but am a little lost as to what carbon rod you are referring to that would require replacing the stab?
Are you referring to the bit that joins the two wing parts? If so I don't quite get the connection to the stab.
Not being a native English I am actually not quite sure what the stab is either, some of the RC terms are new to me.
Stab, being one of them
nph is offline Find More Posts by nph
Old Feb 11, 2012, 11:38 PM
Joined Oct 2007
Was referring to the carbon rod used to join the horizontal stabilizers (stab or tailplane, that flat bit at the back of the plane!!!).
Old Feb 12, 2012, 06:24 PM
Joined Oct 2007
Ive had the typhoon for a while now but never really explored its thermal-ing potential, mostly because its not really my flying style but also I was a bit limited by the DX6i's mixing abilities. Now ive got a 2.4 module for a 9 channel radio which has sailplane mixes so I can try a few new things. When chasing thermals what have you found to be the ideal flap/aileron settings?
Old Feb 13, 2012, 12:09 AM
nph is offline
nph
nph
Joined Oct 2010
I am really interested in tihis answer as well since I am building light in order to catch a thermal or two.
Old Feb 14, 2012, 04:36 PM
Joined Oct 2007
The crow function works nicely with the Typhoon. Couldnt do it properly before with the DX6i. It really slows it down in a hurry and makes for precise landings. Loving the new radio.
Old Mar 16, 2012, 10:35 AM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
I should be able to maiden my Typhoon this weekend weather permitting. One thing is with the Stab LE at 63mm it just looked (like it was trimmed) nose down to me so I checked it with an incidence meter and got over 1 degree negative flying incidence on the stab (the wing 1 degree negative reference the stab) , kinda scary, so I used the incidence meter to set the stab zero reference the wing and a few clicks up trim, maybe it is 61-62mm now, should be good to go. Mine is a bit of a lead sled at 4 lbs 3 oz with a 4cell AA Eneloop for Rx power, a 4s 2250 TP 65C power pack, and the big Neu motor gearbox 15x13 prop. Plus I laid in some weight reinforcing the fuselage for about 8" around the wing LE. I need 1/2 to 1 oz tail weight to get the CG back with this setup so I plan to put a AAA Eneloop in the nose for power and ditch the tail weight. Anyway wish me luck, this thing pulls like a freight train so at least I know it is going up! Also I sat for hours and still need help with the sailplane programming in my 11X. I have all 5 flight modes and crow and a camber and a reflex setting on switches with preset deflections but for the life of me I cannot get the flaps and ailerons to work together for roll or elevator and flaps+ailerons to operate together for pitch.
Husafreak is offline Find More Posts by Husafreak
Old Mar 27, 2012, 11:05 AM
lukeydukey10 is offline
Find More Posts by lukeydukey10
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
i maidened my etyphoon today, am using tp2200 3s battery, kontronic motor, gearbox and phat folding prop
am using dx8 with throttle on switch off / full - was a bit worried about this but it works really well and is very fast and unlimited vertical.. was on the slope with it and its a great all rounder!! very happy with the phoon!
lukeydukey10 is offline Find More Posts by lukeydukey10
Old Apr 05, 2012, 07:25 AM
voodoo magic maaan
Joined Jan 2011
here is my ephoon with custom go pro mount flying in S England today
great plane, very stable.. could feel the camera was on there but it still flew well
here is the vid http://youtu.be/ArfvyPKzBLM
too cold on the slope for maximum enjoyment
Old Apr 15, 2012, 03:05 AM
rumbey is offline
Find More Posts by rumbey
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
Looking for around 750-800W. What non gearbox setup would I need. I presume 3s 2250 sized lipos?
rumbey is offline Find More Posts by rumbey
Old Apr 15, 2012, 10:38 AM
Jebera is offline
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
Maybe a AXI 2826/10 wil do, but what's the nose inside diameter?
André
Jebera is offline Find More Posts by Jebera
Discussion RCRCM Typhoon 2m - First detail pics slopetrashuk Slope 2590 May 27, 2016 11:05 AM
Build Log Typhoon electric build log and presentation Ghost_ Electric Sailplanes 0 Mar 29, 2010 12:47 PM
Build Log Stinger 45 Build Log by sekollera EscoFlier Slope 129 Jan 08, 2009 10:06 PM
Build Log Blu-Baby Build Log - by Phil PhillipE Aerial Photography 6 May 23, 2008 09:20 PM
Discussion RCSP Blackwing build log (by an amateur) bennymack Foamies (Kits) 5 Oct 02, 2007 08:30 PM
