Hope you don't have the AR6250..they were recalled by Spektrum over a year ago.. I returned all my AR6250 receivers to Horizon.
from Spektrum web site. Quote:
Guess I'll jump in here as I just ordered a carbon E Typhoon and Neu 1110/1/6.7 (hope I got that right) prop and spinner from Soaring USA. Sounds like a fantastic all around glider. I want to slope it and fly it at the power field as well, everyone at my field is fascinated by my Blizzard, wait until they get a load of this! The design ticked all the boxes. Four servo wing for big air and tight landing areas, not too big or too small, two piece wing, acrobatic but can get some time in thermals, descent power but not really a "hot" setup, having both fuses should make even dead days at the slope big fun. Plus I have a box full of good 3 and 4s 2200 mAh Lipos. I wish someone here had flown the Neu motor on 4s. Has anyone? Too bad about the QQ issues, I'll definitely know where to look but the one guys experience is a real buzz kill! Anyway, I'll let you know how it looks when I get it in a couple days but for the most part I am psyched
I am running it on 3S 2200, 4S 2200 will not fit I have a contronic motor and gearbox and running the prop on full beans makes the most awesome sound, it comes in at 750 watts and its going to be very fast... I have a slope fuz as well and am also yet to maiden that one I guess I am just a bit nervous as this is my first moulded 6ch plane, I can fly small hotliners so am hoping this will be a breeze its just this is the most expensive project (s) so far so any mistakes will be very costly! Its coming soon though, will keep you posted!
Husafreak wrote
http://www.rcgroups.com/forums/showp...9&postcount=34 video link here http://www.youtube.com/user/SoaringUSA?feature=mhum |
Hmmm, Bob at SUSA definitely said I could use 3 OR 4s so I will have to see for myself. I spoke to Gary (?) yesterday and he recommended I reinforce the nose ahead of the wing so I'll lay some CF or FG in there. I wonder if Epoxy will be OK (cure) there or if a glass resin would be better? I am also on the fence about servos, I would love to use Hitec 125's and the supplied mounts but really want to just glue in the Hyperion wing servo's, they look great and probably center better. Then again a trip to my garage/hobby warehouse did just turn up 4 Airtronics 94761 digtals taken out of a 500 class heli I recently sold (12mm wide) and 4 NOS JRDS368 servos that were not used yet but earmarked for a Mirag slope ship I never assembled... Those are kinda big 12.5mm. Hitec HS65MG servos seem small for this ship though, so much power and weight...
2S2P 2200 would work, 2x2S packs end on end. I got 6S 1900 in mine, tight though.
Dunno what your planning for an ESC, but a phoenix 125 would be a bit bulky and a waste of it. A castle ice lite would easily keep up. You need to reinforce the nose around the canopy cutout, carbon preferably. The hyperion wing servos, or the SJ propo that are the same without the hyperion sticker are great servos. HS65's would be OK for the tail feathers, I wouldnt use MG's though, too easy to get slop in the flying stab. |
Just spent some time on SUSA website. I must have been doing pretty well financially back when I bought these servos! I'm going to put the JR's in the two fuses (I got a slope and E version) and the 4 Airtronics in the wings. They should fit at 10mm wide and SUSA advertises them as thin wing servos so... As for recievers I haven't been sloping or gliding on 2.4 yet but I will be now (JR11X). It looks like the Spectrum Carbon ready reciever is a short range type without satellites. And only 6 ch. So for full range in the E Typhoon I can use the 7ch Rx with a satellite all inside the nose area ahead of the CF. For the slope version what is preferred, 6 ch with sat in the nose or the 6ch CF Rx with external antenna? I'll try that question over at the slope thread too. Thanks
Hi Jacko, thanks for all your input earlier in the thread. 2S2P 2200, great. I'll get one and set up the fuse to accommodate 3s1P or 2S2P interchangeably. I have a CC Phoenix 80 so I intend to use that with some kind of external Rx battery, SUSA recommends the Eneloops but 4AA cells would be big, I also have small Lipo packs in various sizes I could use with a small Medusa voltage regulator, Or go straight 2s Hyperion Life and hope the servos take it (6.6v). I can wait to see just how small this fuse is
I have CF weave for the reinforcement but what glue/resin should I use and are we talking just around the fuse ahead of the wing or all the way around the canopy cutout?
E Typhoon is finally on the bench, I promised myself I'd finish my other projects first, so finally got to look at everything together.
First, everything fits! I can get a Neu motor/6.7 gearbox combo, 2 2s 2250 65C TP packs, CC Phoenix 80, Spectrum AR7600, Satellite, and SUSA Eneloop 4 cell 2000 mAh in there no problem. The fuselage has little room at the servo bay, looked like Hitec HS 65 were a little too tall so for the same money as 5065's I got Futaba S3156 Digital, MG, BB servos drop right in. At 27.8 oz-in/2.0 kg-cm and 0.13 sec they are nice servos and no slop just not very beefy. For the wings I will use my Airtronics 94761 wing servo's for the flaps and I got Hyperion DS095-FMD for the ailerons. One cool thing is the aft 4s pack can be set up so that the cg would not change going from 3s to 4s packs. Although with the new 65C packs I will probably just quick charge them at the field between flights and leave them in the glider (hope it never burns!). |
| Thread Tools | |
| Discussion RCRCM Typhoon 2m - First detail pics | slopetrashuk | Slope | 2408 | Apr 01, 2013 05:04 PM |
| Build Log Typhoon electric build log and presentation | Ghost_ | Electric Sailplanes | 0 | Mar 29, 2010 12:47 PM |
| Build Log Stinger 45 Build Log by sekollera | EscoFlier | Slope | 129 | Jan 08, 2009 10:06 PM |
| Build Log Blu-Baby Build Log - by Phil | PhillipE | Aerial Photography | 6 | May 23, 2008 09:20 PM |
| Discussion RCSP Blackwing build log (by an amateur) | bennymack | Foamies (Kits) | 5 | Oct 02, 2007 08:30 PM |
