Old Mar 30, 2010, 02:26 AM
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
A Simple Quad
I'm planning to build a simple Quadrocopter based on 4/3 of Signguy's tricopter (and possibly other similar designs I have not referred to and so cannot acknowledge here).
I will use the H-4 or H4X swash mixing available in my (new) Futaba 10C - see picture below (from the Futaba manual).
Edit (October 2010): I now know that the Futaba 9CHP also provides 4-way 90 CCPM swash mixing. So you can build and operate a Simple Quad if you have a 9C, or another TX that offers this mixing. Furthermore, Vic20owner has shown (here) that you can also use 3-way 90 mixing (as on a Spektrum DX7 for example) plus one additional mix, to operate a Simple Quad.
H-4 mixing will give a " + " orientation and H4X will give me an " x " shape.
The + Quad would have a single tail rotor that is tilted for yaw and managed by a gyro. Aileron control would speed up and slow down just two motors -- left and right respectively, each managed by a gyro. Elevator control would speed up and slow down the single front and rear motors respectively, again each managed by a gyro.
The x Quad would have two (2) tail rotors, both tilting for yaw and managed by a single gyro. Aileron control would speed up and slow down all four motors, two on the left and two on the right respectively, all managed by a gyro. Elevator control would speed up and slow down the two front and two rear motors respectively, again all managed by a gyro.
I was originally planning to control yaw by speeding/slowing permanently tilted sets of rotors. Manual control of yaw would work with this method but I could not see how to enable one gyro to stabilize the yaw control with this set up. I could see a way using another four independent gyros but was not prepared to go so far. So I have chosen to use one (for +), or two (for x) tilting motors for manual and gyro control yaw.
I am waiting on my motor orders, having ordered some of the motors recommended. I already have the HK401B gyros and ESCs.
But before I go too far down this road, are the any comment or observations?
Has this been done heaps of times before? Am I on a loser? Any threads for me to read through on this?
And ... which of + or x configurations might be better? I must say that I prefer the x configuration because it will enable a better view between the front arms for camera work.
thanks,
Simon
SSM is offline Find More Posts by SSM
Old Mar 30, 2010, 07:49 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
This should become a very Interesting thread. I also want to build a cheap quad using my favorite building material.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 30, 2010, 08:37 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Simon,
Go for it! New builds always spur creativity There have been others in the past who have done gyro only quads and quads using servos for tilt on all arms, See the Lemiwinks and Joeling builds referenced in my Quadrocopter and Tricopter Mega Link Index
The tricopter gents have found that 4 gyros give the best response with one for yaw control. You will likely need 5 gyros for your build. Not many other Tx's have the Futaba 10C's mixing capability for a quad setup. Others have successfully used ClarkSt's Mini-mixer for this: http://www.rcgroups.com/forums/showthread.php?t=949507 and http://www.mini-mix.blogspot.com/
Cheers,
Jim
thanks,
Simon
jesolins is offline Find More Posts by jesolins
Old Mar 30, 2010, 08:39 AM
Joined Aug 2009
Originally Posted by jesolins View Post
Simon,
Go for it! New builds always spur creativity There have been other that have done gyro only quads and quads using servos for tilt on all arms, See the Lemiwinks and Joeling builds referenced in my Quadrocopter and Tricopter Mega Link Index
Cheers,
Jim
In my opinion, he can do it with Three Gyros using a high precision V-tail mixer but again, it would be simpler using five.
Old Mar 30, 2010, 08:51 AM
Joined Aug 2009
Oh, forgot to mention, because the 401Bs are so cheap, it is cheaper to use them verse using the expensive V-tail mixers.
Old Mar 30, 2010, 05:43 PM
SSM is offline
SSM
SSM
SSM's Avatar
Joined Nov 2003
Demonstration of Futaba 10C swash mixing for Quads
Thanks for your replies guys, and support.
I thought I'd do a couple of demonstration videos of the two swash mixes on my Futaba 10C that I could use for a Quad.
The first is the H4X swash mix, suitable for a " x " set up - with two front motors and two back motors.
Warning: I am on Mode 1
H4X Quad Mix.MOV (1 min 27 sec)
The second is the H-4 swash mix. This is suitable for a " + " configuration of motors - one motor front and back and one on each side.
H-4 Quad Mix.MOV (1 min 4 sec)
First up (when my motors arrive .. ..) I think that I'll build and try the " x " Quad.
Simon
Old Mar 30, 2010, 05:53 PM
Joined Aug 2009
Simon
I also like the X format because it offers the best camera view.
Old Apr 12, 2010, 03:38 AM
SSM is offline
SSM
SSM
SSM's Avatar
Joined Nov 2003
It may just work!
OK, I got my 4 motors and completed my build - presently in the X configuration (although it's only a couple of buttons on the Futaba 10C to change to +).
Here's a video of the tethered maiden test flight. At this stage, I am willing to hope that it seems to respond to controls as one would anticipate.
Simon
Quadcopter Maiden Test.MOV (1 min 16 sec)
Old Apr 12, 2010, 03:52 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
OK, I got my 4 motors and completed my build...
Mode one. Hardcore.
Looking good. Set it free
RCvertt is offline Find More Posts by RCvertt
Old Apr 12, 2010, 07:44 AM
Joined Aug 2009
Simon
I say, NOT TO BAD, it is actually Fantastic Awesome!!!
Congratulation!!!
Old Apr 12, 2010, 08:09 AM
Joined Aug 2009
I have not done this myself, but looking at the Flymentor setting, you should be able to use it for the X - Configuration.
Old Apr 12, 2010, 11:52 AM
jesolins is offline
Joined Feb 2007
Nice preflight testing That looks like a very flyable setup to me. Great work. Get some air time now!
Cheers,
Jim
Old Apr 12, 2010, 11:55 AM
jesolins is offline
Joined Feb 2007
RR,
I did not know the FM had a 90 degree swash setup. With that setting it certainly would work to self level a quad configuation. Looks like we'll be getting you into quads sooner that I thought
Cheers,
Jim
Old Apr 12, 2010, 12:05 PM
Joined Aug 2009
RR,
Cheers,
Jim
Seriously, I want to build one ASAP, just need the funding, that is all. I have the time.
Old Apr 12, 2010, 01:37 PM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Simon
Exellent!!!
Let it out!
SebastianJ is offline Find More Posts by SebastianJ
Discussion Quad brushless motors and quad ESC wiring whatala Power Systems 11 Dec 28, 2015 03:51 PM
Sold 2 ESC's cheap! - 18A Thunder Bird, 35-40A Super Simple Garret H Aircraft - Electric - Power Systems (FS/W) 5 Mar 05, 2010 02:28 PM
Discussion Simple Foamy for IPS? a67ems Foamies (Scratchbuilt) 3 Mar 03, 2010 01:36 PM
Question A simple powered design for 5 rookies to learn to fly. cyclops2 Electric Sailplanes 1 Feb 27, 2010 04:49 AM
quad cdr quad esc how many poly cells? captinnitro Power Systems 2 Apr 04, 2005 08:37 PM
