Old Mar 29, 2010, 07:31 PM
wolfsong is offline
Find More Posts by wolfsong
i think i need a bigger boat
its cold up here
Joined Jan 2005
marblehead hull
Hi Guys,
i have an old marblehead boat, which was made original out of abs plastic.
unfortunately after about 20 years, the boat is getting fragile. and to top it off, it fell of the stand yesterday and cracked the upper hull on one side.. .
so far it is fixable, but it does not look good.
question for you : should i try to attempt of restoring the hull ? ie, cutting it along the boot stripe in 2 halves, laminate the inside , put it back together and re-finnish the outside?
or find a new hull and move all part over to the new hull ?
personally i like the boat and would hate to have to junk the hull...
ohh.. i do not do any competition sailing.. just for fun
wolfsong is offline Find More Posts by wolfsong
Old Mar 29, 2010, 07:34 PM
bboarder711 is offline
Find More Posts by bboarder711
bboarder711's Avatar
State College, Valley Forge PA, LBI NJ
Joined Jun 2008
what about making a plug out of it and building a completely new boat?
bboarder711 is offline Find More Posts by bboarder711
Old Mar 29, 2010, 07:42 PM
wolfsong is offline
its cold up here
Joined Jan 2005
making a plug is a little more, than i would want to do at this time.. it would require a multiple part plug, due to the cockpit area
Old Mar 29, 2010, 08:34 PM
wolfsong is offline
its cold up here
Joined Jan 2005
did some search on this side and the hull i got, is actually an old robbe pirol..
she sails nice though
Old Mar 30, 2010, 11:15 PM
Oian is offline
Find More Posts by Oian
USA, CA, Selma
Joined Sep 2004
I too have a Robbe Pirol. The hull material (Called Plura by Robbe) has also gotten a little brittle. I discovered this when I picked up the boat by holding the hatch opening and cracked (in several places) the side of the hull. I re-positioned the cracked areas with tape and epoxied a few layers of glass cloth across the cracks. It worked very well and the hull is as stiff as new. I'm just more careful as to how I carry it. If the outside of the hull is rough when you get finished you can just fill/sand and repaint the area.
John
Oian is offline Find More Posts by Oian
Old Mar 30, 2010, 11:40 PM
Oian is offline
USA, CA, Selma
Joined Sep 2004
This is the repaired hull, fortunately I was able to reposition the several cracks well enough with tape that they really don't show that much (they were on this side). The color in the pictures is a little odd, the boat is yellow and the people are not black and white! The boat actually sails very nicely for its age but the single panel stock sails leave a lot to be desired.
John
Discussion Marblehead Thread !! 1967250s Sailboats 21 Nov 01, 2010 02:37 PM
Gallery Marblehead from scratch...Ideas and comments onlinegamesnz Sailboats 13 Mar 30, 2010 04:16 AM
Build Log Delta Class Marblehead Build 1967250s Sailboats 39 Feb 10, 2010 01:48 PM
Discussion Ebay- Marblehead Mould breakwater Sailboats 0 Jan 22, 2010 11:38 AM
