Rich, tow hook position and cat launch position is very different. A tow position allows level pull, no climb. What imodel says is correct place to start. Hanging the jet with the nose up, the jet should have approx 15deg pos away from the zip line. Just about all of my jets are approx 50-60% back from the nose to the CG.
Tape a hook in the approx position and hang as discribed. Adjust to suit. Mount perm. If you have a backing of 1/4" ply, inside the fuse, a 3/16" carbon dowel works great, epoxied in. A small tab of plastic or thin ply at the base of the hook allow protection from the pull ring. Fuzz |
Yep, Fuzz got it right. You need to position the hook so that the inertia of the model makes it rotate to the correct angle of attack when the bungee is accelerating it. This will depend on the 3D position of the CG, not just the longitudinal position of it, as a high CG will tend to rotate the model more than a low CG. If the hook is too far back the model will tend to rotate to too high an angle of attack, causing the wing to be stalled no matter how fast the launch is (remember, wings stall at a given angle of attack, not airspeed), with the result the model does the dreaded bungee death roll.
Stu. |
Fuzz, I totally agree with you. what I disagree with is the fact that that is where I used to put the hook for bungee launching a glider. if you are using up to 60% on your plane, is that not close to 2/3?
if you look at Nick's Turbinator that is designed for bungee launch, he puts the hook at 2/3 between nose and CG. I'm not saying you are wrong at all, but the man is a God in the RC world and I think I'm more inclined to go with him here. for a more technical reason, we can go further............since we are talking about moments of inertia, too far forward and it's gonna give you a nose down attitude on launch. too far back and you get too nose high. either of those and you are facing a crash with every launch. 60-63% (2/3) gives the best happy medium................in other words, it's gonna give you a bit of nose high at launch, without getting too high in A0A. there's obviously a reason why Nick chose that hook position with his Turbinator, right? and the reason is, is because it's the most aerodynamically sound position to place it. Rich |
G'day Steve!
Rich, the reason I don't like the "2/3 from the nose" or similar method is that it depends on the length of the nose. What if it's an F5 or F104? Glider launching is a totally different ball game. It happens much slower and you're on the line for a lot longer. A glider launch is designed to get height, whereas a jet launch is designed to get speed. Stu. |
| Thread Tools | |
| For Sale PRo Bungee Launch System | Artsloper | Aircraft - Electric - Jets (FS/W) | 2 | Jun 26, 2010 12:40 PM |
| Discussion Bungee launch height. | mikey100 | Australia | 2 | Nov 16, 2009 04:17 AM |
| For Sale Bungee launch | dbcaster | Aircraft - Electric - Jets (FS/W) | 4 | Oct 30, 2009 12:31 PM |
| Discussion Bungee Launch Hooks | Leadfoot | Pusher Prop Jet Models | 0 | Oct 23, 2009 11:29 AM |
