Old Mar 28, 2010, 10:03 PM
up2late is offline
Find More Posts by up2late
Joined Dec 2009
Question
900 mhz patch antenna help
Does anyone have the dimensions for a regular 900mhz patch antenna.I found a website that had pictures of a patch antenna for 1.2ghz that someone had opened and had taken measurements,but I need one for 900mhz.If anyone has any pictures of a 900mhz patch antenna internals with measurements like the example below please post them.
up2late is offline Find More Posts by up2late
Old Mar 29, 2010, 03:16 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Here ya go...
http://www.rc-cam.com/gp_patch.htm
The_Mongrel is offline Find More Posts by The_Mongrel
Old Mar 29, 2010, 07:25 AM
ess is offline
ess
Find More Posts by ess
ess
ess's Avatar
Türkiye, Istanbul
Joined Mar 2010
is this 910mhz patch antenna suitable for 1040mhz? or 1010mhz?
ess is offline Find More Posts by ess
Old Mar 29, 2010, 08:02 AM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
I just had a 900 and 1200 patch apart a few days ago, and made note of the measurements. The two patches I have (from L-Com) are identical, with the exception of the size of the upper element, and the cable.
As shown in your picture, the right side of the upper element,and the cable attachment are in the same location. For the 900 MHz unit, the left to right measurement is 146mm, and the top to bottom is 161mm.
The cables are much different in length, and could even be different types, though that's unlikely. They do seem to be using the cables to match the overall impedance. My limited understanding is that the impedance match would be more of a problem if it were used as a transmit antenna. As you can see in the RC-CAM link, he got rid of the cable completely.
Cheers,
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Mar 29, 2010, 03:41 PM
up2late is offline
Joined Dec 2009
Thank you,Rusty that is what I am looking for.If you have time could you find the measurement for the air gap that is between the bottom plate and the top,mabe provide a diagram with your measurements of the 900mhz antenna.
Old Mar 29, 2010, 04:10 PM
up2late is offline
Joined Dec 2009
To answer ess's question,the antenna in the above example is for 1.2ghz and the specs say it covers 1080-1200mhz.The specs for L-com's 900mhz antenna are from 902-928mhz,so I don't know how effective they would be at receiving 1040mhz or 1010mhz.Sorry mongrel,I am only interested in the demensions of a regular 900mhz patch,not rc-cam's gp patch.
Old Mar 29, 2010, 05:29 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
The plastic housing, and ground plane are exactly the same between the two units, so the air gap is the same as well. I think I called it 14mm, but there's nothing to hold the plates perfectly flat, so it kinda depends on where you measure it.
BTW, Mike (OMM) recently found this link for calculating patch antenna dimensions. Dielectric constant for air is 1. It's VERY impressive,and spot on
http://snipurl.com/v5g7h
Cheers,
Rusty
Site Sponsor
Old Mar 29, 2010, 11:15 PM
up2late is offline
Joined Dec 2009
Thank's rusty,you have been incredibly helpfull.If you have time maybe you could post some pictures with measurement's of the 900mhz patch.
Discussion FS: 900-1200mhz Digital RX and Patch antenna charlienofun FPV Talk 2 Mar 14, 2010 11:03 PM
Discussion 900 Mhz patch antenna moti FPV Talk 3 Dec 07, 2009 05:55 PM
Discussion anyone know where to get a mini patch antenna 900 mhz? djdaveq FPV Talk 12 Oct 20, 2009 07:32 AM
Discussion 900 mhz rx patch antenna help me please.. bozo bozok FPV Talk 8 Sep 24, 2009 03:16 PM
Sold 900 Mhz hyper link 8dBi Patch receiver antenna $60 rajesh5024 Aircraft - General - Miscellaneous (FS/W) 2 Mar 11, 2009 05:28 PM
