Old Mar 28, 2010, 10:29 AM
bosco49 is offline
Find More Posts by bosco49
bosco49's Avatar
USA, CA, Shasta Lake
Joined Mar 2005
Tail heavy High Aspect-ES 3.1M electro
Just finish up building this AH High Aspect-ES 3.1M electro....But its tail heavy ....Has anyone that has ever build one came across this?
bosco49 is offline Find More Posts by bosco49
Old Mar 28, 2010, 01:04 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What motor and battery are you using?
..a
Old Mar 28, 2010, 03:17 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
Andy its a PJS 2500,And the pack is a Rhino 2250mAh 3S1P 30C Lipoly Pack...Weight : 199g.I might go with a heaver motor Mega ACn 22/30/3 and a bigger pack??
Old Mar 28, 2010, 04:24 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Well, first, how much weight do you have to add up front to balance it? If it's just a couple of oz, then the heavier pack or motor might be the answer.
Where are your servos mounted? Do you have a receiver pack?
..a
Old Mar 28, 2010, 07:42 PM
sruelle is online now
Find More Posts by sruelle
Team Horizon
sruelle's Avatar
United States, MI, Ann Arbor
Joined Feb 2005
I have the glider version tranformed in a e-glider. As nose is longer banlancing is just right for me with my BL480 6G 4.4/1
so if you have a light motor, it doesn't surprise me that you have some issues balancing it.
I use a 4AA reciever pack, close to CG and the lipo pack in the front
servos and reciever under the wings
I will never flew again without a reciever pack! Newton has won on me with a glider equiped with a BEC!
Just like this glider, probably one of my favorite TD plane
sruelle is online now Find More Posts by sruelle
Old Mar 28, 2010, 08:17 PM
Forest Flyer is offline
Find More Posts by Forest Flyer
Terre Haute, Indiana, USA
Joined Aug 2004
My High Aspect balances well with an AXI 2820/10 motor and a Hyperion 3S 2600 pack about 8 mm back from the motor. I use a CC Ph 80 ESC (more than enough for that motor!), which is positioned on the lipo pack. No extra weight needed beyond those components. The tail servos are under the wing, with the receiver just in front of the servos. AUW about 56 oz.
Forest Flyer is offline Find More Posts by Forest Flyer
Old Mar 28, 2010, 09:55 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
Thanks for the input guys....my servos are mounted at the CG point and I dont use a receiver pack,The receiver is about 20MM behind the CG...you can look at the pics in my blog.I think the heavier motor might be the answer....the Mega ACn 22/30/3 is 220g,I will be pulling out the PJS its 162g...58g to play with.I also have a Multiplex BL-480/4G but its only 117g.
Old Mar 29, 2010, 07:53 PM
Team Horizon
sruelle's Avatar
Joined Feb 2005
Forest, I just have the same AUW than you
Bosco have fun with it; mine is in the back of the car allready for tomorrow!
Look like a good day is coming in Michigan!
Old Mar 29, 2010, 11:14 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
sruelle...........''Tomorrow''......That a work day...........you cant going flying on a work day......well have fun for me too.
Old Mar 30, 2010, 08:35 PM
Team Horizon
sruelle's Avatar
Joined Feb 2005
I take what I call an extended lunch break!
that will be too bad to let all these thermals going away without a glider in it!
Today was great!
The HA was the right sailplane, arround noon, as lift was just trying to establish. this glider is circling so well!
Old Mar 30, 2010, 10:45 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
I went the Mega ACn 22/30/3 and the receiver pack is in the front of the CG...everthing is in the front,A Turnigy 2650mAh 3S 30C Lipo Pack.The Pack Weight is 247g....with all that done I can get a balance at 5mm behind the CG......What do you guys think?
I can put big holes in the Horizontal stab.......
Old Mar 31, 2010, 07:39 AM
abla57 is offline
Find More Posts by abla57
tame gliding frog
abla57's Avatar
France, PACA, Carpentras
Joined Dec 2006
from common experience on a French forum, the CG indicated on different versions of AH instructions varies from 77 to 100 mm !!!
The high aspect flies very well with CG between 81-86 mm from LE (Mine is 84mm ).
What measured CG are you ?
abla57 is offline Find More Posts by abla57
Old Mar 31, 2010, 08:03 AM
Joined Aug 2004
Good point. I fly mine at about 84 - 85 mm back from the LE.
Old Mar 31, 2010, 08:21 AM
Joined Aug 2004
Well, that much weight, put as far up front as possible, would definitely make my HA nose heavy.
I looked at your blog photos, and nothing looks unusual or obviously heavy to the rear of the CG. How did you secure the control rods in the tail boom?
FF
Old Mar 31, 2010, 09:01 AM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
The control rods in the tail boom are in the Sullivan Semiflex Gold-N-Rod....BUT I Just the used the Blue sheath part to run the two small stock push rods in.I cut a 20'' of the Blue sheath part and glued with thick CA.I did this also with my AH Serenity-EV 2.5M electro-glider and really no change with the CG on that plane.........I went with the stock 82 CG.....Sooooo a CG around 87 would work?.
Discussion Art Hobby High Aspect-E 3.1M electro-glider bosco49 Electric Sailplanes 3 May 16, 2006 05:34 AM
Discussion ArtHobby High Aspect RES-3.1m csocso Thermal 2 Jan 25, 2006 01:04 PM
