Old Sep 25, 2001, 08:34 PM
bztguy is offline
Find More Posts by bztguy
Leaf River IL.
Joined Sep 2001
Dual conv. TX's with single conv. RX's
Can single conversion receivers be used with dual conversion transmitters as long as the freqs are the same?
bztguy is offline Find More Posts by bztguy
Old Sep 25, 2001, 09:06 PM
me11owman is offline
Find More Posts by me11owman
Tucson, AZ, USA
Joined Sep 2000
It always works for me ...although I can't explain the technical why-fors it does work ...
Jim
me11owman is offline Find More Posts by me11owman
Old Sep 25, 2001, 09:14 PM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
I've never heard of any conversion transmitters,zero,single,dual or what ever!!!! just keep matched up on the usual factors such as frequency , AM , FM , PM, and Positive or Negative shift,,,once a receiver syncs up on its matching type signal , it does not care how it received it as the xmtr is putting out a clean signal only on that one frequency. Receivers are a different deal , with Dual Conversion types rejecting and ignoring all Other frequencys and not showing interference effects as much as Single conversion receivers types.
KillerWatt is offline Find More Posts by KillerWatt
Old Sep 25, 2001, 09:32 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Dual conversion sort of means like two tuners in a row - one to filter out the signal, the other to make it sharper.. sort of.. still the same signal type being tuned in..
..a
Old Sep 25, 2001, 09:41 PM
Fred Marks is offline
Find More Posts by Fred Marks
Ijamsville, MD, U.S.A.
Joined Mar 2001
Gentlemen; Dual and single conversion apply only to receivers. There is no such thing as a dual conversion transmitter. Please read the FAQ section of the fmadirect web site regarding receivers to see what single and dual conversion receivers are about. Briefly, dual conversion receivers have two mixers and two Intermediate frequency sections while single conversion receivers have only a single IF at 455 KHz removed from the transmit freq. Dual conversion is used to avoid potential problems with signals at the image frequency. In the case of single conversion, the image frequency is just 900 KHz away from the transmit frequency and very difficult to filter in the front end, The image frequency in a receiver with a first IF 10.7 MHz from transmit frequency is heavily filtered and seldom ever a problem.
Fred Marks is offline Find More Posts by Fred Marks
Old Sep 25, 2001, 09:50 PM
breadboy is offline
Find More Posts by breadboy
multiple celled organism
breadboy's Avatar
San Diego,CA,USA
Joined Sep 2001
cool!that means you can buy FM recievers for $20 and they will work with a flash 4 etc.!(like cirrus mrx-4,GWS 4p)
(these dont include crystals)
breadboy
breadboy is offline Find More Posts by breadboy
Old Sep 25, 2001, 10:37 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Fred, of course, as the designer of many fine products, is correct.
For the less technically inclined, read his note again, and remember that you must pick a reciever that will work with your transmitter.
Futaba and Hitec require one type of reciever, JR and Airtronics another. All after market sources offer models to suit. You must specify which type of tranmitter you are using when ordering.
Also, crystals from one mfg may or may not work with another product. Stick with the mfg products for guaranteed success. They know!!
FYI, Dave
DaveW is offline Find More Posts by DaveW
Old Sep 26, 2001, 06:54 AM
Joined Mar 2001
Dave is correct. For those who don't know or don't want to worry, we make the Magnum receiver that automatically detects the shift and works with either frequency shift.
Sold BlueBird Micro single conversion Rx's for Futaba Dell C. Aircraft - General - Radio Equipment (FS/W) 6 Sep 09, 2006 05:35 PM
HELP! 6 Foot Range with 2 of my RX's! Phiber Optik Radios 7 Oct 05, 2005 08:42 AM
Found Looking for two N shift single conversion RX's, like new or new. himeros Aircraft - General - Radio Equipment (FS/W) 2 Aug 18, 2005 10:28 AM
