| Thread Tools |
| This thread is privately moderated by Asher Carmichael, who may elect to delete unwanted replies. |
Clip screws
Hi Asher!
I see you struggle with attaching cowls and access doors Prime me with your mailing address again and I will get you worry free clips They will be just perfect for a size of your tug Did I say WORRY FREE! ZM Check Accessory page for more pictures http://mysite.verizon.net/vze2qbfc/id19.html |
Guntersville, AL
Joined Jun 2004
Ganging Ailerons
This is probably the last post for the Decathlon until I get an engine. I have thoroughly enjoyed this assembly and the fit and finish of this plane are top notch.
I've never ganged multiple servos before so I asked a few questions on Flying Giants and got some good advice regarding some videos by Down on the Deck. You can go to the link here and follow the thread to the the videos for more specific info. Ganging servos is important on these big models, not so much for the additional torque but to help avoid flutter. I'm told a single point connect is more subject to problems than is a ganged setup. http://www.flyinggiants.com/forums/s...ad.php?t=51950 The idea is to get the geometry right from the start. Equidistant linkages are a must. Leave one aileron linkage loose and measure the throw, up and down, and adjust the travel limits in the TX until equal. Undo that linkage, hook up the other and repeat the process until you have equal throws. Then, hook both up and measure amperage draw. Also, listening to the servos is a big part of eliminating binding. You should be able to get the servos to be quiet after full deflection. Notice the wings are vertical in this setup. Gravity is your enemy in ganging servos. The weight of the surface on the servo will make it sing all day. Putting the wing in a vertical position will eliminate that. I use a Hanger9 in-line amp/volt meter for measuring the amperage. It will jump around a bit when moving the surface but look for the nuetral and several points to full deflection and a reading that is .00 - .05 in the range.
Joined Apr 2006
Whoa! Can't imagine the SD with a 150 in the nose! Reports from those flying them with 100cc say they do a fantastic job. Thanks for the link. Asher, Can't wait to read your report. I finally took the 'bait' and Bill H. crossed my eyes when he set the hook! ![]() I'm on the list for the next container so I'll be referenceing your thread here. Let us know how the SD performs. |
| Thread Tools | |
| Discussion Bill Hempel 100cc Yak-55m | grimgrinnin | Giant Scale Airplanes | 2 | Jun 16, 2010 03:37 PM |
| New Product 50% KA-6 from Bill Hempel | authomassen | Scale Sailplanes | 15 | Feb 24, 2010 05:24 AM |
| Bill Hempel & The Aviator | asmokindeal | Electric Plane Talk | 2 | Feb 17, 2005 02:46 PM |
