Old Mar 22, 2011, 09:17 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Mike: No need for any sorry. If you were having fun, testing out something new, testing out the camera, trying to carrier land, whatever, it was great that you shared the video.
One of our MARS Micro Modelers pilots got so good so fast at carrier landings with his Vapor that he switched to doing the landings across the table instead of along the length!
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Aug 28, 2011, 02:38 PM
Mike-A is offline
Find More Posts by Mike-A
Mike-A's Avatar
Sweden
Joined Oct 2002
WOW just found this post
Originally Posted by lovespicyfood View Post
Is there anything that comes close to the slowness of this plane that is rtf or even kit? Man, that thing is NICE!
Pete
Wow just found this Post! The guy who is flying that plane is Alexi Lantsov a master builder. He has a friend who actualy makes the carbon fiber in any form he needs and another friend... Serge, who builds his electronics. I use to fly with these guys when I lived in St. petersburg. I miss those days... Everything was scratch built from the materials to the motor systems and radios... Today everything is ARF...
These guys are an inspiration. They would always come up with new ideas that pushed the envelope on what was possible. And they did it with style... AND looks like they still do! I'm gonna track him down and see if he could "fix me up" with one of his creations like the old days! lol!! And Ill see if I can get my hands on some of that carbon fiber again. NOTHING available comes close to the wieght / strength ratio that he makes!
Mike-A is offline Find More Posts by Mike-A
Old Aug 28, 2011, 06:27 PM
poulsbobill is offline
Find More Posts by poulsbobill
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
Originally Posted by Gordon Johnson View Post
Jim,
If you want to hover be sure and use the Cub 6mm motor, which requires lengthening the wires. As I'm sure you know, it puts out substantially more thrust, about 22g at 3.5V. But, amp draw is also higher so you'd want to use the 110mAh or 130mAh PZ cell instead of the 70mAh that comes with a Vapor.
I've never gotten around to putting the Cub motor in my son's Aileron Vapor. It's on my to do list.
Gordon
This http://www.horizonhobby.com/Products...ProdID=PKZ3916 motor gordon?
Bill
poulsbobill is offline Find More Posts by poulsbobill
Last edited by poulsbobill; Aug 28, 2011 at 07:13 PM. Reason: IS it the motor or the combo of gearing and prop too?
Old Aug 28, 2011, 06:45 PM
Tony Twoskids is offline
Find More Posts by Tony Twoskids
USA, GA, Kennesaw
Joined Dec 2003
Pete
That is gorgeous. I'd buy one in a heartbeat. Beautiful flight.
Tony Twoskids is offline Find More Posts by Tony Twoskids
Old Aug 28, 2011, 07:31 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Originally Posted by poulsbobill View Post
Yes, that's the motor. Since I posted that I have put a Cub motor in the Aileron Vapor, and in a regular Vapor. My boys really like the additional thrust.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Aug 28, 2011, 08:05 PM
Poulsbo, Wa
Joined Sep 2004
Gordon
Did you use the Cub gear box and prop or the vapor's? And if the vapor's did the pinion on the cub motor work on the vapor gear box?
Bill
Old Aug 28, 2011, 08:26 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
The pinion on all the 6mm motors are the same, if I am not mistaken.
Jay
Faethor is offline Find More Posts by Faethor
Old Aug 28, 2011, 10:39 PM
Boston, Mass
Joined May 2001
Bill
Vapor GB, otherwise you would need the cub prop and would get less thrust.
Old Aug 28, 2011, 11:26 PM
Joined Oct 2005
This is the first I've heard of anyone who makes their own carbon fibre. Not that I necessarily want to do that, but I'd sure like a source of curved carbon fibre. Any leads or suggestions?
Jim
Old Aug 29, 2011, 07:18 AM
Boston, Mass
Joined May 2001
Jim,
I think you would need to get Carbon Fiber Tow, and then make your own from that. There have been a few people who have posted in this forum about making their own pieces from Tow. You might be able to find those posts with the help of the search engine. The key to getting light CF constructions is to use the minimal amount of epoxy. Extra epoxy makes composite pieces substantially heavier. So, it's not enough to form ones own CF pieces, they also need to be light.
Gordon
Old Aug 29, 2011, 03:50 PM
Poulsbo, Wa
Joined Sep 2004
Thank you...appreciate it.
Bill
Old Aug 29, 2011, 04:03 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Jim how small a radius you trying to get? When you heat CF it will bend and hold the bend. I've only done 90* bends but I'm sure a radius could be done also. I'm assuming your talking about .5mm rods for the outside structure of an airplane?
TODD
I R Irv is offline Find More Posts by I R Irv
Old Aug 29, 2011, 04:19 PM
Joined Oct 2005
Exactly, Todd.
Jim
Old Aug 29, 2011, 04:40 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
Jim CF has a tendency to bend in a small focused area when heated,( not a radius) but if it was me I would bend a strip of metal to the radius I wanted and tie the CF rod to it. I mean totally wrap the CF rod with heavy thread or string keeping the gaps between the wraps at 1/8'' or less and then heat it well with a hot air gun. Now if this produces a nice radius or a bunch of little bends I really don't know but it might be worth trying.
TODD
Old Aug 29, 2011, 04:53 PM
Joined Oct 2005
Thanks, Todd, for that suggestion. What I've been aware of is that sometimes carbon rods bent and glued into an airframe later break when they get hot if you leave the plane in a car in the sun. That breaking, and the continuous tension required to keep them bent is what I'd like to reduce or eliminate.
I've looked at several manufacturers and dealers in carbon rods. Either they don't mention it at all, or some of them say they don't offer any curved carbon rods. That suggests that someone does offer such, but I don't know who.
Jim
Sold AR6400 with aileron servo Stall'n_N_Haulin Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Feb 26, 2010 10:22 AM
Discussion 2 servos for aileron Plane Hazza Radios 4 Feb 26, 2010 04:45 AM
Question how to swap rudder and aileron on vapor brick? indoor_fr Scratchbuilt Indoor and Micro Models 3 Oct 28, 2009 05:49 PM
Discussion Vapor 5th channel on vapor tx? LexusIS300 Scratchbuilt Indoor and Micro Models 1 Oct 14, 2009 02:26 AM
Sold 2x Vapor DSM2 transmitters, 1x Vapor LiPo charger philski Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Jul 30, 2009 05:50 AM
