Old Mar 10, 2011, 07:53 PM
poulsbobill is offline
Find More Posts by poulsbobill
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
I like it too!!
Bill
poulsbobill is offline Find More Posts by poulsbobill
Old Mar 13, 2011, 01:30 AM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Originally Posted by Jim_Marconnet View Post
Gordon: I just saw a video of a composite plane the flys like I'd like a Vapor to fly with ailerons: http://vimeo.com/16590312
Unfortunately the guy is in St Petersburg, Russia.
Jim
Is there anything that comes close to the slowness of this plane that is rtf or even kit? Man, that thing is NICE!
Pete
lovespicyfood is offline Find More Posts by lovespicyfood
Old Mar 13, 2011, 08:17 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
One of our local guys (George Maiorana) has built one at the opposite end of the spectrum from RTF. He made his own carbon fiber rod from tow and epoxy! I believe it's based on the Osirus.
Petefoss is offline Find More Posts by Petefoss
Old Mar 13, 2011, 07:40 PM
brandonb5269 is offline
Find More Posts by brandonb5269
brandonb5269's Avatar
United States, MI, Macomb
Joined Jan 2009
does any one know where i can buy the connections used to hold the landing gear and parts on? like push in style connecters for carbon rod? i would love to have a go at making my own micro, and have tried before, but just gluing the carbon together is rather hard for me. thanks for any help you might be able to give
brandonb5269 is offline Find More Posts by brandonb5269
Old Mar 13, 2011, 09:28 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
I searched my A$$ off looking for these. The only site I found had already went out of business. If you so happen to find some please post a link.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Mar 20, 2011, 12:09 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
20110319 171353 (2 min 45 sec)
Removed the dihedral and put in a Cub motor.
Aileron Vapor (2 min 31 sec)
mcross is offline Find More Posts by mcross
Old Mar 20, 2011, 02:05 PM
G rees is offline
Find More Posts by G rees
Joined Dec 2010
someone in Keystone Rc Club has one I saw
G rees is offline Find More Posts by G rees
Old Mar 20, 2011, 02:11 PM
G rees is offline
Joined Dec 2010
Hey was this yesterday at the KRC funfly
Old Mar 20, 2011, 03:14 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Yes it was
Old Mar 21, 2011, 07:20 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Mike,
Looks good in the air. Nice job.
I notice in the video that you built yours with dihedral. I couldn't see that it had dihedral in the previous picture you posted, although I could see the joint where the two halves were glued together. That looks like it makes it more stable, but that also explains one reason yours won't roll as well as ours does (not that ours rolls that great, but it will do it).
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 21, 2011, 09:53 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
I appreciated seeing this latest video and also reading about the dihedral. In the video I did not quite "get" the aileron vapor in that I did not see particularly slow flight, nor high-alpha flight, nor rolls. But it could have just been that the pilot was having fun flying, not necessarily showing off the aileron vapor special attributes!
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Mar 21, 2011, 11:50 AM
Boston, Mass
Joined May 2001
Jim,
In terms of speed there are a few parts in the video where you can see Mike's plane and a regular Vapor both flying at the same time. To my eye it looks like his Aileron Vapor is flying about the same speed as those regular Vapors. Remember, it's not slower than a regular Vapor. But, it does have ailerons.
Gordon
Old Mar 21, 2011, 01:07 PM
Joined Oct 2005
Thanks, Gordon, for pointing that out.
I can usually come very close to hovering (or flying very high alpha at almost zero ground speed) my Vapors, especially when I let the battery hang on the wire instead of having it mounted to the fuselage. But what I'm really looking forward to someday is being able to actually hover one with ailerons controlling the wing rock.
Hope springs eternal!
Jim
Old Mar 21, 2011, 01:44 PM
Boston, Mass
Joined May 2001
Jim,
If you want to hover be sure and use the Cub 6mm motor, which requires lengthening the wires. As I'm sure you know, it puts out substantially more thrust, about 22g at 3.5V. But, amp draw is also higher so you'd want to use the 110mAh or 130mAh PZ cell instead of the 70mAh that comes with a Vapor.
I've never gotten around to putting the Cub motor in my son's Aileron Vapor. It's on my to do list.
Gordon
Old Mar 22, 2011, 08:52 AM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Gordon,
Thanks for the tip on the dihedral, I should have known better. Eventually I'll build a new wing.
Jim,
Sorry, that flight was not intended to show it's capabilities. It was just a friend flying so I could gain some experience with my new cam. He was trying to land on the table the whole flight. I did later land and takeoff from the table. I've never flown a stock Vapor so I can't really tell you how different it is. It does fly at about the same speed when not in high alpha but can't slow down as much as the stock Vapors. It is heavier, but I don't know the exact weight. It has more ply, thread and CA than Gordon's and Tim's. It was flying with a 130 mAh cell and also has a homemade version of Gordon's kid proof gear.
Sold AR6400 with aileron servo Stall'n_N_Haulin Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Feb 26, 2010 10:22 AM
Discussion 2 servos for aileron Plane Hazza Radios 4 Feb 26, 2010 04:45 AM
Question how to swap rudder and aileron on vapor brick? indoor_fr Scratchbuilt Indoor and Micro Models 3 Oct 28, 2009 05:49 PM
Discussion Vapor 5th channel on vapor tx? LexusIS300 Scratchbuilt Indoor and Micro Models 1 Oct 14, 2009 02:26 AM
Sold 2x Vapor DSM2 transmitters, 1x Vapor LiPo charger philski Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Jul 30, 2009 05:50 AM
