Old Mar 07, 2011, 09:45 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Thanks, Tim, for sharing info and photos on yours! It looks great, and sounds like it flys great if lt flys slower than the NVs.
You are soooooooo clever about the around the world semantics! You really got me on that one.
I like your Orange color. I assume that's paint. Spray paint and I are not good friends. I use Sharpies whenever I can. I wonder what an orange highlighter would do on foam like that. Guess I could try a scrap and see how it turns out.
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Mar 07, 2011, 10:03 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Jim
The orange is cheap acrylic craft paint. Thinned with Windex and sprayed with an airbrush.
Gordon was kind enough to cut the parts for me and I assembled it the week of the KEIF meet in Williamsport PA and flew it for the first time there.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 07, 2011, 12:50 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Jim,
Spray painting is pretty easy. Besides, going the Sharpie route isn't going to work as well on the inside and outside edges of the cutouts. With spray paint all those edges will be the same color too. And, you can paint the ribs etc the same color. Try it on some scraps. The key is to dust it on, wait about a minute, and then dust some more on.
I doubt the highlighter will work very well. There's a reason people use Sharpies.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 07, 2011, 04:27 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
You thin acrylic with Windex? That's a new one on me! Any unusual effects?
Jay
Faethor is offline Find More Posts by Faethor
Old Mar 07, 2011, 06:47 PM
Tim Wolff's Avatar
Joined Sep 2002
Jay
Flows better and dries faster than using water.
Old Mar 07, 2011, 07:32 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
I've had some water based acrylics bead up on styrene foam before. Does the Windex solve that issue?
Petefoss is offline Find More Posts by Petefoss
Old Mar 07, 2011, 08:24 PM
Tim Wolff's Avatar
Joined Sep 2002
It helps "wet out" (flow) on the foam better than water. First few coats are VERY light and give the finish coats something to grab. If it is beading, you are applying too heavy a coat.
Old Mar 08, 2011, 02:02 PM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
I was usually brushing so it's hard to go light. I'll try some of the same paint with Windex.
Pete
Old Mar 08, 2011, 02:10 PM
Tim Wolff's Avatar
Joined Sep 2002
Pete
Windex won't make a difference if you are brushing.
Old Mar 08, 2011, 02:22 PM
Joined Oct 2005
Tim and Gordon and anyone else with Aileron Vapors: What sort of manuevers do you do in what sort of indoor facility?
I've flown original Vapors and now the Night Vapor. Indoors in a full-court gym I tend to fly mostly in two dimensions, i.e. around in circles, figure-8s, etc., either flying on the wing or harriering. Inside loops can be done, but I do them rarely. Outside loops are really iffy. And flying inverted is amost impossible for me. I can often hover or very nearly hover with the battery allowed to hang down and swing backwards at high alpha. That's with the A/C shut off, of course!
Jim
Old Mar 08, 2011, 03:33 PM
Boston, Mass
Joined May 2001
I just fly around, use the ailerons to do banked turns, and the occasional loop. I've rolled it some, but don't do it all the time. My son flys it more than I do, and he does all of the above and occasionally flies inverted. Mostly it's for the fun of flying something like a Vapor, but that is controlled differently because of the ailerons. For example, you can do nice flat turns with it.
Gordon
Old Mar 10, 2011, 11:03 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Pardon my iggerence but what's windex ?
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Mar 10, 2011, 11:12 AM
Boston, Mass
Joined May 2001
Terry
http://en.wikipedia.org/wiki/Windex
There you go.
Old Mar 10, 2011, 11:31 AM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Wow, just stumbled on this thread. What a great looking plane!
lovespicyfood is offline Find More Posts by lovespicyfood
Old Mar 10, 2011, 12:12 PM
Tim Wolff's Avatar
Joined Sep 2002
Originally Posted by Gordon Johnson View Post
Given the recent changes to the formula cited in the Wiki you linked, I'll probably be switching to windshield washer fluid. It is probably more consistent and I'm told works just as well.
Sold AR6400 with aileron servo Stall'n_N_Haulin Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Feb 26, 2010 10:22 AM
Discussion 2 servos for aileron Plane Hazza Radios 4 Feb 26, 2010 04:45 AM
Question how to swap rudder and aileron on vapor brick? indoor_fr Scratchbuilt Indoor and Micro Models 3 Oct 28, 2009 05:49 PM
Discussion Vapor 5th channel on vapor tx? LexusIS300 Scratchbuilt Indoor and Micro Models 1 Oct 14, 2009 02:26 AM
Sold 2x Vapor DSM2 transmitters, 1x Vapor LiPo charger philski Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Jul 30, 2009 05:50 AM
