Old Nov 14, 2010, 08:11 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
There's some video of the first time I flew it in this post in my Air Bender thread.
http://www.rcgroups.com/forums/showp...4&postcount=66
No video since then as I've gotten better flying it. And, no video of it when I was flying it quite a bit at KIEF. Sorry there's no more recent video.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Nov 15, 2010, 03:16 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
That looks awesome
Nice job
Do you mount the motor with ply? How did you secure to foam?
Gordon
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 15, 2010, 08:16 PM
Boston, Mass
Joined May 2001
The motor mount is just two pieces of 1/64th ply (in retrospect should have been 1/32) which have holes that the motor bearing tube is pressed into. Those light ply pieces then slide into slots cut in the foam fuselage and the motor is pushed through them and a hole in the foam I bored with a hand reamer. With only about 24g of thrust it doesn't have to be super robust. There's a close up pic of it in the second post in that thread.
Gordon
Old Nov 15, 2010, 08:39 PM
sajeev is offline
Find More Posts by sajeev
United States, VA, Fairfax
Joined Feb 2004
now that adds an awesome touch to the boring vapor . makes me wanna get a vapor again.
sajeev is offline Find More Posts by sajeev
Old Nov 15, 2010, 10:29 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
thanks for info
if you dont mind I'll re-direct questions to your thread on this subject
Gordon
Old Nov 20, 2010, 10:29 PM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Boring? BORING?!?! It's just calm....
PiperCub49 is offline Find More Posts by PiperCub49
Old Feb 05, 2011, 07:44 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Thanks for the plan Gordon. I made mine from a green dot fuse with electronics so I didn't have all the fittings. Thread, CA, and ply worked in place of fittings. Built from 3mm depron and 1/4 mil mylar. I still need to add a rudder servo but it flew fine without it. Flies very nice and relaxing.
mcross is offline Find More Posts by mcross
Old Feb 05, 2011, 08:00 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
I've been meaning to try one of those myself.. Sure looks sleek! Makes me wonder how a Night Vapor would look, all lit up!
Jay
Faethor is offline Find More Posts by Faethor
Old Feb 07, 2011, 07:56 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Hi Mike,
How does it roll? Can you do a decent roll or does the undercamber make it difficult? I'm thinking about building one for my wife an an aerobatics trainer since things happen slowly.
Pete
Petefoss is offline Find More Posts by Petefoss
Old Feb 07, 2011, 08:32 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Hi Pete,
It doesn't do rolls. It's a nice aileron trainer but it's not an aerobat. Perhaps with a flat wing and bigger ailerons it might roll. I added the rudder servo but I don't think that's gonna help rolls.
It's a really easy and quick build, I might try a new wing at some point.
Old Feb 07, 2011, 09:16 PM
Boston, Mass
Joined May 2001
Mike,
Nice to see you built one and like it.
Pete,
it can do rolls, but they aren't pretty. The wing is up on a pylon, and then there is the under camber. And, when we fly ours we can see the tail twist out of alignment with the wing because the CF fuselage is not that rigid. Still, it flies nice and slow, and differently than a standard Vapor.
Ours has a big rip in one wing from a mishap a couple of months ago with another plane's prop. It's taped up and flies fine. But, doesn't look so great. I'll probably need to make another wing at some point after this indoor season is over.
Gordon
Old Mar 06, 2011, 08:10 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Just curious how many of these have been built and flown around the world.
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Mar 06, 2011, 07:56 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Jim
Gordon's, Mike's, and mine makes 3 built that we know of. None of them have flown around world AFAIK.
Mine is covered with Saran Wrap and uses an Ember II fuse, so it is a tad heavier than Gordon's. The wing can be moved forward and aft as can the battery tray. It can be trimmed to fly slower then the Night Vapors at our local site.
I "forced" my son to fly it at our last session. The Vapor he usually flies was being re-covered and I suggested he give it a try. He just sat there with the plane in front of him, too "chicken" to take off. I distracted him and threw the throttle to about half-way. Off it went leaving him no choice but to fly it .
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 06, 2011, 08:28 PM
RCBilly is offline
Find More Posts by RCBilly
MAD MEN QCRC
RCBilly's Avatar
Joined Jun 2006
Looks good Tim! Maybe we'll see it fly at Toledo Bill
RCBilly is offline Find More Posts by RCBilly
Old Mar 06, 2011, 10:00 PM
Tim Wolff's Avatar
Joined Sep 2002
Probably.
Sold AR6400 with aileron servo Stall'n_N_Haulin Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Feb 26, 2010 10:22 AM
Discussion 2 servos for aileron Plane Hazza Radios 4 Feb 26, 2010 04:45 AM
Question how to swap rudder and aileron on vapor brick? indoor_fr Scratchbuilt Indoor and Micro Models 3 Oct 28, 2009 05:49 PM
Discussion Vapor 5th channel on vapor tx? LexusIS300 Scratchbuilt Indoor and Micro Models 1 Oct 14, 2009 02:26 AM
Sold 2x Vapor DSM2 transmitters, 1x Vapor LiPo charger philski Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Jul 30, 2009 05:50 AM
