Old Mar 27, 2010, 07:32 AM
Timewerx is offline
Find More Posts by Timewerx
Timewerx's Avatar
Joined Mar 2010
Collection of my 4G6 DIY mods (Crash proofing, canopy, peformance boosts, etc)
Hi all!
First of all, I'm new to this forums! However, I'm already 3 months into this hobby and exclusively flown only Walkera helicopters, far mostly with the 4G6..
I maybe a newb, but as an aviation enthusiast, I'm not, and designed, built and flown my first powered, free-flight plank at the age of nine, built out of recycled materials. I earned a degree in Manufacturing Engineering and worked as IT specialist. My hobbies has been mostly in the field of aeronautics and aerospace propulsion. I'm also an amateur science researcher and inventor - only as a hobby, I don't get paid for it!
Anyway, here's the collection of the mods I designed myself, it was never a piece of cake as the 4G6 is proving to be quit a challenge to improve upon using off-the-shelf items from the house:
High performance crash proof blade redesign
http://www.helifreak.com/showpost.ph...5&postcount=32
Anti-tail gear stripping mod
http://www.helifreak.com/showpost.ph...1&postcount=26
High Performance Evaporative Active cooling solution for the stock motor
http://www.helifreak.com/showpost.ph...0&postcount=33
High Performance Canopy design
http://helifreak.com/showthread.php?t=196542
Modding 4#3b/CB100 servo to work as tail servo(higher performance than stock tail servo!)
http://www.helifreak.com/showpost.ph...5&postcount=29
More to come! Thanks!
Timewerx is offline Find More Posts by Timewerx
Old Mar 27, 2010, 08:54 AM
dreadhero is offline
Find More Posts by dreadhero
dreadhero's Avatar
Joined Jan 2010
very cool stuff, Thanks for posting. I'm thinking about getting a 4g6 so these mods will save me a lot of money
dreadhero is offline Find More Posts by dreadhero
Old Mar 27, 2010, 11:11 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
No problem!
The first link especially will give your 4G6 longer flight times, higher performance and an especially crash-resilient blade that will probably take several crashes before you need to R&R only the tip(not the whole blade! ) which virtually costs nothing btw and easy enough to R&R.
But all in all, turns your 4G6 into a crash and pick up CCPM heli!
Old Mar 30, 2010, 11:27 AM
BrownOut is offline
Find More Posts by BrownOut
Chasing dreams not d competion
uk
Joined Feb 2009
Hey, could you post your mods on this forum in one thread? i clicked your links but found a load more to click, click those and you have even more to click, you must have loads of threads open on helifreak but much better to have it all in one place here.
BrownOut is offline Find More Posts by BrownOut
Old Mar 30, 2010, 11:46 AM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Sorry about that, try this one
http://www.rcgroups.com/forums/showp...postcount=3797
That is actually posted in the 254th page of 'Walkera 4G6 - Mods, Repairs, Setups ' thread.
Old Mar 30, 2010, 11:52 AM
BrownOut is offline
uk
Joined Feb 2009
That link still takes me to another thread that i need to keep clicking links onto another site in order to see all the mods
Old Mar 30, 2010, 12:04 PM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
Try looking at post #1 now
You still need to click links with the canopy link though because if I gave you direct link, you won't see the other canopy liveries, cheers!
Old Mar 30, 2010, 12:38 PM
BrownOut is offline
uk
Joined Feb 2009
You are missing the problem but dont worry.
It would be ideal if the articles you link to (5 of them) were posted here as one.
If they were posted here it would be ideal if they were all in one thread.
The objectivve being that myself and others can read through a thread which had all the details and pictures and guides etc in it instead of chasing them around the net.
Old Mar 30, 2010, 12:42 PM
Maksym is offline
Find More Posts by Maksym
Maksym's Avatar
Baie-Comeau, Québec, Canada
Joined Mar 2010
Thanks a lot for posting all your experiments Timewerx, I for one appreciate them. Particularly the blade-related ones.
My 4G3 is out of commission at the moment, so I'm toying a around a bit with what I can do to make it fly better. I've got a few cheap wooden blade off of Ebay for like 2$ a pair. I've already removed the lead off of a pair and replaced it with hot glue and it removed a bit of weight. Soon I'll try to find some vinyl tape somewhere to crash 'proof' their tips but I can't say I've seen that stuff anywhere before. Would that be the stuff they strip cars with?
Maksym is offline Find More Posts by Maksym
Old Mar 30, 2010, 01:02 PM
Timewerx is offline
Timewerx's Avatar
Joined Mar 2010
I get what you mean now, I'll see what I can do tomorrow.
Sounds like it, but it's not. Vinyl tape is often times used for cable/electrical chord repair/joining. This is the tape you wrap around the point where you joined/solder two chord/cables together to insulate it.
You may be able to find them from hardware stores like Ace or electronic components/hobby store. But you may not have to bother with them. This another one of my blade repair/crash proofing kit is better and don't require vinyl!
http://www.helifreak.com/showpost.ph...1&postcount=27
Old Mar 30, 2010, 01:12 PM
Maksym is offline
Maksym's Avatar
Joined Mar 2010
Ok, we call it electrical tape here, hence the confusion. I've got plenty of that stuff (being an 'handy' man :P).
Your new blade design wouldn't work for wooden blades, would it? They don't have the carbon rod so I'm not sure if it'd be strong enough. I could retro fit some carbon rods into the ends of them, but drilling straight into the blade and making the rod stick out straight would be quite the challenge.
Edit: Oh I see you've linked to a different post of yours, I assumed it was the radical mod. I'll check it out, thanks.
Build Log AWESOME! Walkera 4#3s, CB100, 4G6, 5#6, 52, Novus, EP, MCX, 120 UPGRADES-MODS-HOW TO MarioIArguello Micro Helis 2437 Feb 05, 2011 08:52 PM
Discussion Is this a good motor for 4g3, 4g6, ..etc? mayday1 Micro Helis 1 Mar 07, 2010 04:21 PM
Discussion Crash-Proofing Biplane Wings? rotagen Foamies (Scratchbuilt) 3 Jan 25, 2010 12:37 AM
Discussion a collection of my DIY foamies hokonghing Foamies (Scratchbuilt) 7 Aug 10, 2006 07:55 AM
