Old Sep 18, 2010, 11:26 AM
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
maiden
Just got back from the F/A-18 maiden. Taxi and takeoff went smoothly. But then it needed a ton of "up" trim. I had set the elevators where they looked to be faired with the stabs...but I had to put full "up" trim on the transmitter before it felt neutral. The next problem was that my throws were too small...the roll rate was so slow that doing a full roll was out of the question.
The worst problem was that this plane with the Blue Angels paint-job looks virtually the same from the top or the bottom. Combine that with it's small size, and it was terribly hard to orient on. I was constantly losing orientation. So I decided to bring it in before I crashed it, and on final approach, I lost orientation one more time, and got too slow while trying to get it back. I ended up just chopping the power and letting it fall into some long grass. Damage was not too bad...gear mounts yanked loose and a bit of nose damage.
So I'm going to put some bright-colored packing tape on the bottom, and move the pushrods for increased throws.
herk1 is offline Find More Posts by herk1
Old Sep 18, 2010, 12:45 PM
herk1's Avatar
Maryland, USA
Joined Oct 2006
Should be easier to tell the difference between top and bottom now!
Old Nov 03, 2010, 07:55 PM
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Hey Don! I have a few questions about the F-18 build. The first would be When installing one of your wicked combos do you remove any foam from the -fuse- to fit the fan unit other than the slot for the wemo fan? I felt like I had a bad thrust angle or something like that on my last F-18. I think I read somewhere on the threads here that you used regular ca on these models to put them together. Can you confirm this? Hot glue has warped two of my epo models so I would like to try something new. Thanks in advance
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Nov 03, 2010, 08:01 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sometmes you need to remove a little piece of foam near the front of the fan unit. If you use a pen and trace the ends of the fan housing you cen see if there is a foam bump that needs to be removed. Also I have forgotten to make sure the access hatch was also modified like the body as well. Yes I do use Ca, I use Pacer Zap medium CA+.
The Don is online now Find More Posts by The Don
Old Nov 03, 2010, 08:17 PM
NEW JERSEY U.S.A.
Joined Mar 2010
Thanks Don! You are always helpfull I removed some foam from the rear of the stock fan cradle. I think thats where I went wrong..
Old Oct 27, 2011, 04:46 PM
chuck
santa barbara, CA
Joined May 2009
don , i just got one of these used w/ your setup in it. any chance u still know the cg spec, i cant find it anywhere.
tia , chuck.
chas650r is online now Find More Posts by chas650r
Old Oct 27, 2011, 05:00 PM
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
chas650r,
http://www.rcgroups.com/forums/attac...mentid=3051278
FoamJunkE is offline Find More Posts by FoamJunkE
Old Oct 27, 2011, 07:40 PM
chuck
santa barbara, CA
Joined May 2009
thanks!!
Old Sep 16, 2012, 10:45 PM
Joined Jul 2008
deleted
ledouxmike is offline Find More Posts by ledouxmike
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 09:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 09:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 11:32 PM
Question The new F-18 from banana hobby j3tman Foamy EDFs 3 Jan 21, 2010 08:31 PM
