Old Mar 26, 2010, 10:48 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Wicked Powered Banana Hobby JPower 50mm F-18
This is the build thread for my JPower 50mm F-18. The kit arrived today so will post photos tomorrow.
Don
The Don is online now Find More Posts by The Don
Old Mar 28, 2010, 10:29 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The F18 parts.
Old May 02, 2010, 01:37 PM
keon718nyc is offline
Find More Posts by keon718nyc
Joined May 2008
Hey Don, Was just wondering if you are still doing the F-18 build? I feel stock this is the fastest and modded would be insane and best of the pack!
keon718nyc is offline Find More Posts by keon718nyc
Old May 02, 2010, 01:51 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Yep going to start today I hope.
Old May 02, 2010, 06:16 PM
BigGuyJT is offline
Find More Posts by BigGuyJT
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
Patiently waiting
BigGuyJT is offline Find More Posts by BigGuyJT
Old May 03, 2010, 11:42 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Ok did some measuring today on the outlets and here is what I found. Both outlets are 30mm in size so that means the "outlet diameter" is area is:
30* 2^.5 = 42.42mm which is basically 100% FSA
For 80% FSA we need 37.54mm "equivalent diameter" so that means each outlet needs to be:
37.54/2^.5= 26.54mm
So looks like a nip and tuck needs to be done, just need to figure out how to do it on a bifurcated outlet!
Don
Old May 03, 2010, 11:45 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I am going to start with the wicked 5400 and 3S1300 and see how it goes. I do have some new higher KV motors on the way for 3S operation. Will post test data when I get them.
Old May 08, 2010, 10:10 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Higher KV motors are here. I am assembling a few now. Plan to do some 3S tests tomorrow. I am hoping one of these is about 350-380 watts on 3S, if so I will use it in the F18 :-)
Old May 09, 2010, 06:14 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Don, you don't usually carry motors higher than 5400kv so what are these motors you are playing with? Also, with the split thrust exit, a nip and tuck is more challenging. Have you considered just putting an extra inside layer of something in the back end of the exhaust cone in order to clamp down on the exit thrust? I know it doesn''t sound as sophisticated but it may do the trick just as well. I'd have to think a bit about what would work since the outlets are so small and it would be hard to "bend" something in that tight of a circle.
alexandermh is offline Find More Posts by alexandermh
Old May 09, 2010, 09:34 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Same as the Wicked motor now but just higher KV winds. I plan on making small thrust tubes actually I need to cut them out then will post photos.
Old May 09, 2010, 10:36 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Mu ah ah ah ah!!!!!!
New "Wicked Wemo Extremo" motor: 350 watts 57,500 rpm on 3S
Compare to wicked 5400: 250 watts, 50,500 rpm on 3S.
I am very very happy!!!!
Old May 09, 2010, 12:02 PM
BigGuyJT is offline
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
Can't to see the results!!!
Old May 09, 2010, 09:58 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have hit a new level of model area mess, I cannot find one wing
Old May 10, 2010, 12:39 AM
bulldog2 is offline
Find More Posts by bulldog2
Kuala Lumpur ,Malaysia
Joined Nov 2008
Don,
it flew away on your new high KV motors!
bulldog2 is offline Find More Posts by bulldog2
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 10:32 PM
Question The new F-18 from banana hobby j3tman Foamy EDFs 3 Jan 21, 2010 07:31 PM
