Old Aug 07, 2011, 08:44 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by Razors edge 29 View Post
Would doing this step (narrowing exhaust without t tube) help the stock unit?
It may make it fly worse depending how much power stock really is. I have never flown one of the 50mm models stock so not sure if there is any excess power or if they need WOT to fly around. If they need WOT all the time to fly then narrowing may make it fly worse.
The Don is offline Find More Posts by The Don
Old Aug 08, 2011, 11:18 PM
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
hmm
might choke it off you mean?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Aug 08, 2011, 11:35 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Smaller nozzles reduce low speed thrust but maintain thrust at higher speed. So large diameters give more low speed thrust but less top speed, smaller gives less low speed thrust but higher top speed. I fly these 50mm models on ~350 watts so I have plenty of power even when the nozzle is reduced so I get the top speed. I have no idea if the stock setup will work that way or not.
Old Aug 08, 2011, 11:58 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
thanks Don
EDF noob here obviously lol
I was pondering cutting out 1/2 or less.
BUT
if it reduces thrust at low speeds, then it may be even more of a bitch to hand launch.
something to consider definately.
Although; I am running 6 blade fan on 4S ... so.. who knows
Old Aug 11, 2011, 09:43 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Don
So, I removed 1/2 inch of foam from the exhaust (same way you did), and also reduced intake by 3/8 of an inch and it flies
Not exactly sure how much quicker, but it seems to be faster nonetheless.
Question:
How long of a flight time would you get on a 1000 mah 40C 40S lipo if WOT?
Old Aug 11, 2011, 10:02 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I know nothing about the stock power system and the watts/amps it uses so no idea how long it will fly.
Old Aug 11, 2011, 10:05 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
alrighty then
Old Feb 15, 2014, 09:17 PM
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
Don, any new info on a Wicked system for this jet ? i found a JPowers F86 kit buried in my stash. i'm thinking i have the 6000kv in my T-45 running on 3S with a wemo 50mm fan(been in there awhile)...works great
will this work on the 50mm F86
KCinNC is offline Find More Posts by KCinNC
Old Feb 15, 2014, 11:20 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That setup will work. Just watch the outlet on this model as it is huge and needs to be reduced and mine had CG issues due to lots in tail incidence so check for that as well.
Old Feb 15, 2014, 11:28 PM
KCinNC's Avatar
Joined Aug 2007
yes, i read this build log..which made me ask about the update? stock is just tooo slow for me
thank you for the reply !
Old Feb 15, 2014, 11:40 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I never bought a new F86 and started over on this one I went on to other airframes but it can be made to go ~85 mph once got the CG setup right.
Old Feb 15, 2014, 11:50 PM
KCinNC's Avatar
Joined Aug 2007
now thinking of selling this kit...doing a 4S t-45
thank you Don for your info man !
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 09:42 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 09:19 PM
Build Log Wicked Powered Hobby Lobby F-86 Skyblazer The Don Don's RC 49 Mar 17, 2011 11:32 PM
